Results 1 to 17 of 17
    Veteran Member Three Rings 98A4TurboAWD's Avatar
    Jan 06 2013
    Charleston, SC
    How to DIY Repair a malfunctioning third brake light
    My third brake light has been out for a while throwing an annoying light.
    I decided to take it out just to see what was in there.
    I noticed it was an LED strip and thought to myself that it was weird that none of the lights worked.
    So I pulled it apart and threw 9v of power to it. I noticed that the connector prongs were loose and that when I moved them the lights would come on in certain positions.
    I soldered it down tight and it is working good as new.
    Probably pretty common. Easy to pull apart and fix yourself if you have a soldering gun.
    The loose prongs.
    Powering it up.
    Good as new.
    2018 Audi S4 3.0t - EPL Stage 1 93
    09 Audi A4 2.0t Quattro - Automatic - CTS K04 - ECS HFC & 3" downpipe - Integrated Engineering K04 93 Octane Tune - K&N Filter - S Line 19" Peelers - H&R Sport Springs
    98 Audi A4 1.8t Quattro - Stock - Automatic - AEB
    Sep 28 2015
    WA
    Can you provide some tips how to pull apart from beginning, especially how to take it off from a car? Thank you.
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Did the same thing. When I got my car the 3rd brake light would go out on hot days so I pulled it off and soldered the two leads. Fixed it right up. I didn't take the board out of the housing though so if anyone has trouble with that like I did it's not necessary.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Thank you for the quick update!!
    Jan 06 2013
    Charleston, SC
    Quote Originally Posted by lettuce View Post
    Yep, not necessary at all. I was expecting a break in the LED and thought I'd have to buy an LED strip to replace it.
    Once I got it out I noticed that the prongs were loose.
    You can totally avoid pulling it apart.
    Jan 06 2013
    Charleston, SC
    Quote Originally Posted by dand. View Post
    Just put your fingers underneath the plastic and pull it along the same plane as the glass. It takes a lot of power to do it. TBH it's a ridiculous design.
    Sep 28 2015
    WA
    Quote Originally Posted by 98A4TurboAWD View Post
    I have watch some how to video, the hardest part is the first step. Afraid to break something. Does it covered by the warranty? My A4 is 2014.
    Veteran Member Three Rings endy1's Avatar
    May 04 2014
    Sweden
    Have/had the same problem but it works fine now but i guess thats why its cold(er) outside now?
    Thanks for this DIY !
    Nov 05 2014
    chicago
    I thought I might have been the only one having this problem. My mechanic saw this and soldered it for me. Great post thanks for sharing with others! I actually cracked the plastic when I tried pulling that light out, its a pain in the ass.
    Jul 26 2012
    Atlanta, Ga
    I brought a new one install it works fine then a couple days later it doesn’t. Warning light came back on. Exactly how do you solder it? I see the pics but what parts needs to solder?
    Jul 26 2012
    Atlanta, Ga
    I fix it today. Apparently my issue was the connector was somewhat loose I guess bc I pull the old piece out too strongly and also crack the old one. I reclamp the connector by squeezing the metal piece of the connector and put electrical tape around it and a zip tie. It’s working fine now fingers crossed it won’t go out again. For me the first time was hard to remove the assembly but piece of advice use soapy water around the glass make it easier to slide, pull toward trunk with both hands with fingers underneath the 3rd brake light, try to be careful but a little force is needed. To reinstall I got oem so it was easy, just pull your headliner down a little just enough for the assembly to click back into place.
    Jul 26 2012
    Atlanta, Ga
    By connector I mean the piece of wire/connector that is hanging off the headliner of the car
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by NguyenerA4 View Post
    Nice work. I don't know if I'd call this brake light issue common, but it's not unusual. I think I was too afraid to damage the headliner (I probably wouldn't have) so I had a window tint shop pop it back in. Popping it out wasnt too hard, but the popping back in was a no go for me, even with the OEM part.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Jul 26 2012
    Atlanta, Ga
    Quote Originally Posted by audrobotic View Post
    Yeah, when I tried to install the first time around it wouldn’t go all the way in bc it was hitting the headliner then I pull the headliner down slightly and the oem piece just click back in easier. As long as you don’t pull the liner down too far it will fine, my liner is still perfect lol
    Jun 23 2008
    Can you solder it in place? I notice little corrosion around the outside of my 3rd brake light housing and getting an intermittent bulb out.. Don't want to pull the whole housing out and cause the corrosion to get worse.
    Veteran Member Four Rings RPMtech147's Avatar
    Apr 05 2014
    Texas
    Thread from the dead. I've been meaning to do this for two years, but mine only faults when it's hot out. It's cool now, so maybe in the spring.
    B6 S4, B8 A4, 8P A3, and something, something.
    Junior Member One Ring
    Dec 30 2016
    UK
    Red face ..hello Audi A4 B6 2001 - still going
    Quote Originally Posted by RPMtech147 View Post
    Have a Audi A4 B6 2001. Engine still going strong. Had people tell me the AWX ones turned out to be decent engines. Seems so.
    The central light warning has come on so found this. Will have a go fiddling with the prongs.
    Just curious if anyone is still going with a A4 B6 out there?
