Results 1 to 6 of 6
    Established Member Two Rings 029kid's Avatar
    Nov 13 2006
    Audi A4 2017 Avant 2.0 TFSI
    Oslo, Norway
    Auxiliary heating wont start by remote control ?
    Hi.
    I got a 2011 B8 avant 2.0 TFSI with aux heater.
    I experience that the remote control won’t start my aux heater, it just blinks red. I know that if you are low on fuel it won’t start and blink red, what other scenarios is the aux heater programmed not to start ?
    It wont start if I stand 1 or 20 meter from the car, it used to work from inside of my house.
    My 90.000KM service has exceeded by 2500KM, so it should have been at service.. may that be the reason my aux is not working remote ? It start and works if I manually activate it in the MMI.
    Could it be the battery on the remote? (I doubt it.. )
    May 25 2011
    Norway
    Not sure if this is the same solution,but it is a known issue with Webasto diesel heaters that they fail to ignite a certain number of times, they are disabled and need to be "force cycled" to revert to normal starting cycle.
    Since yours is a gas system it might be different, but diesel burn chambers are known to fail. I replaced both of them on my oem Webasto equipped my10 Passat TDI.
    Nov 13 2006
    Oslo, Norway
    Thanks for replying. FYI I got the OEM auxiliary heater, not Webasto or Eberspächer.
    Do you know if the problem also affect the OEM aux heater?
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    This exact same thing happened to someone else a couple years back
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    I believe it also checks the battery level, and will not start if the battery is low. I am not sure if that is true or not, but if I recall correctly from DavidB8's DIY, the aux heater queries the battery and fuel level to determine if it can start.
    Do you have your battery meter enabled in your MMI?
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Nov 13 2006
    Oslo, Norway
    Good point, Ill check the battery level. Got it on my MMI.
    Ill let you know..
