Results 1 to 8 of 8
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    Please help! Heater core or Air Bubble in the cooling system
    Heater core or Air Bubble in the system? Researched around and tried a lot of different things
    I have a 2003 Audi A4 1.8t Front wheel drive. Just finished changing the T-stat (old one was stuck open) and flushing the coolant. Added an new mixture of coolant to the system, turned on heat to HI and fan to Low. Results:
    • Temp gauge finally started working
    • Radiator fans turned on
    • Car reached proper operating temperature
    However heat that was coming through the vents was lukewarm.
    Burped the car through expansion tank at least 6 times by running the car for 4-5mins with RPM at 2500 to 3000 and then slowly opening the cap to burp it.
    Nice heat finally started to come out of the vents.
    The next day heat issue again. Very mild air coming from the vents. At that point I started purging the air through a little hole on the hose connected to the heater core. I would let the air bubble out and then let stream coolant out as well. Heat came back, however only when the RPM were higher 2500 to 3500, and both hoses going to the heater core were hot, bottom one too hot to touch, while the upper one with the breather hole was hot, but I could hold it.
    While at lunch I drove the care today for about 15min on the interstate with heat on, mild air coming out. I parked and checked the hoses going to the heater core. Same results, bottom one extremely hot, while upper one was hot, but I could hold it with my bare hands.
    Any help would be appreciated or pointers if this is the air bubble in the system or heater core issue. I flushed the heater core about 1.5 years ago.
    Thank you.
    Zlaja
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Pull off the rain tray that goes over the battery, brake booster, etc. There are 2 coolant hoses that go into the firewall. The higher one should have a hole in the top of it. With the car off loosen the clamp and pull the hose out but not all the way off, just enough to where the little hole can breath. Start the car and let it warmp, eventually coolant will start to come out of the little hole. When you no longer see air blasting out of it then put the hose back all the way on and reclamp. Should be no more air in your heater core.
    Mar 09 2007
    03 A4 1.8T
    Richmond%2C%20VA
    See I did that while the car was running. I will try it when it is cold. Thanks.
    Quote Originally Posted by lyates1987 View Post
    Zlaja
    Dec 25 2004
    Earth
    This has been already posted here soooooo many times in the past that its rediculious!
    http://www.audizine.com/forum/showth...ht=air+coolant
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    so, out of curiosity, all of you that have had or currently have heater core problems...do you fill your coolant system with a mixture of coolant and DISTILLED water? or do you just use water from a hose, tap, faucet etc???
    it doesn't matter how cold it is out, my heater is blazing hot even when the car isn't fully up to operating temps...i've always used distilled water when refilling my coolant and never had problems with the getting heat...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Sep 17 2014
    Lakeway
    Quote Originally Posted by jonan View Post
    You're suppose to mix distilled water. Tap water has impurities in it that would be bad for the engine.
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    /\ especially with the all the tight passages and all aluminum cooling system in these cars. You should always use distilled water.
    Please Drive Right
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by Pothole View Post
    right, i've always used distilled water and i don't have any of the buildup that i've seen in these types of threads, which is why i asked to begin with...maybe i'm just lucky...
    i even cut my radiator up when i replaced it with a new one and it was relatively clean even though it had 140k+ miles on it...
    B6 Mods:
    RS4 Mods (sprint):
