Results 1 to 15 of 15
    Established Member Two Rings flashc90's Avatar
    Nov 13 2012
    2004 a8L
    bronx ny
    Bought a 2004 a8L for $800
    So I came across this deal for a 2004 a8L that the previous owner drove the the car 5 miles after it over heated and couldn't get it to start after...
    After fixing the coolant hose that caused the overheating I replace plugs, coolant temperature sensor and thermostat in the car and it was able to start
    After having the car idle for about 40 minutes it started to misfire and overheat again...so I have to do the head gaskets
    Sent from my SM-N915T using Tapatalk
    Nov 13 2012
    2004 a8L
    bronx ny
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    That car looks beat up bad. Good luck but it might be better suited as a parts car.
    Sent from my SM-N900V using Tapatalk
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Jul 10 2012
    buffalo
    Just sharing the experience from our shop but the cost to replace the engine is usually not far off from replacing head gaskets. Plus it gets you away from all of the unknown history from that engine.
    Warped head or block are always concerns on overheated engines.
    1995 camaro with taurus SHO engine
    2001 audi a8 gutted because race car
    2009 chevy express 2500 duramax built 4L85E trans and tuned for around 400hp
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Nov 13 2012
    2004 a8L
    bronx ny
    Quote Originally Posted by somedude View Post
    yes I am aware of that stuff but I bought it a as project car and ill be doing the work my self..
    Nov 03 2011
    All Over!
    That car looks like an absolute ruin.
    Besides the engine issues, there's the bodywork. Aluminium isn't cheap to work on, then there's the air suspension, which seems to have sagged.
    I can see this turning into a money pit, good luck getting it straight.
    1986 Type 85 Audi 90 quattro
    Jul 10 2012
    buffalo
    Quote Originally Posted by flashc90 View Post
    I am aware you are doing the work your self. Complete engines are cheap enough many times that they are the same cost as just a upper gasket kit for many audi engines. Plus if you have a warped head forget it. It is more cost effective to replace the entire unit. There is no harm is stripping it down and checking it out though. Before you pull the heads pull that water pump off and make sure it is not a plastic impeller that is slipping on the pump shaft causing it to overheat. I have seen it many times in the past.
    You got it cheap enough you can always gut it and turn it into a track car if you can find coilovers for it that is. My gutted D2 A8 is a beast on track. We can battle it out on the road course.
    2014 Audi S8
    2015 Audi A6 2.0T
    2013 Audi RS5
    2018 Audi RS3
    Nov 13 2012
    2004 a8L
    bronx ny
    Where can I find an engine just incase...and yes I plan on having fun with it, I might do a custom single turbo setup for it just like I am doing on my 2.7t
    Nov 13 2012
    2004 a8L
    bronx ny
    The suspension is stuck in jack mode at the moment...the PO had all the shocks replaced 5 months ago
    Veteran Member Four Rings ENV²'s Avatar
    Nov 04 2010
    If I were you I would do an LS swap into that thing and put coilovers in it and then worry about body work. You will likely spend less or equal to what you are doing anyway but more reliable and fun when you are finished.
    500AWHP/500AWTQ
    @Driven_Not_Hidden
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Quote Originally Posted by ENV² View Post
    Dude LSX swap would be much too difficult. I would just engine swap that and get it running. Those engines are only like $1500
    Keep up the good work man!
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Nov 13 2012
    2004 a8L
    bronx ny
    I like that idea
    Dec 22 2011
    s
    Make a rat rod style car out of it. slam it, nice wheels, embrace the beat up body..maybe sand some paint off and expose the aluminum in areas....
    Active Member Two Rings Y888's Avatar
    Jun 24 2015
    2002 S8///2014 Lincoln MKS
    Chicago
    Greatest joy comes when you fix something with your own hands!
    Good luck with project!
    Aug 28 2015
    RI
    I would look for another complete car maby somthing smashed in the back with a good engine and nose. There should be another car out there that has all the parts you need to repair yours for a decent price. Just my 02. It is extremely rewarding to fix these cars correctly.
