Results 1 to 16 of 16
    Veteran Member Four Rings Tanzimur's Avatar
    Feb 21 2013
    97 Brilliant Black A4 B5 1.8T
    Warren, MI
    Free Vagcom Download
    Well i have seen a link way back when and it was a full on vag download that worked with my ebay, 3rd partie obd connector.
    I got a new laptop and now need this, but after searching and so on cant find it. So anyone have an active link?
    Established Member Two Rings clause$'s Avatar
    Jan 26 2015
    Mammoth Lakes, CA
    I use this with my eBay cable.
    http://www.ross-tech.com/vcds-lite/
    Veteran Member Four Rings BaseDrifter's Avatar
    May 18 2010
    Or you could like, buy it. And support the companies that support our cars. It's $100 bro.
    | Update thread / Youtube Channel |
    97 A4 1.8TQM: Frankenturbo|TyrolSport SMIC|034 HFC|Borla catback|Carbonio/007 DV|Vogtland GT3|034 RSB|Apikol Bushings|034 SD motor/tranny/strut mounts|A8 brakes/SS lines|JHM trio|Meyle HD CA/TREs|
    01 S4 2.7T: Stock
    Feb 21 2013
    Warren, MI
    Ye no i had the enitre full version not the lite, but thanks anyways!
    And beleiver ye i know lol but free is always nice!
    Senior Member Three Rings wolfe2118's Avatar
    Apr 09 2012
    Fort Wayne, IN.
    Seriously, just buy the full version. The cracked versions are full of bugs and the pirate environment has changed in just the past few years to the point that you are inviting a lot of problems by using some pirated software because you just don't know who has had their paws in the software. I'm all for free software but after owning a GM product, we really need to be thankful for RossTech because some manufactures don't have anything like this. The only thing better would be a DSM Link type software.
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    I know someone who has it ;) I don't believe it's worth what they ask. I bought maestro for 800$ and think that's worth it given it actually does something. Vagcom not so much. 409 is the newest you can have cracked. It doesn't have any bugs. Although if you .torrent it may. Just use a virtual machine.
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Quote Originally Posted by clause$ View Post
    http://www.ross-tech.com/vcds-lite/download/index.html
    This, still works fine. Paid on my laptop, free on tablet. Wish I had just bought a real cable though.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    How can you have the full version? The software key is built into the cable for using any of the new software that is VCDS Lite. If 409 is the latest "full" version you can have cracked, then just by a generic hand-held OBD2 reader from Autozone. Pretty much the same features. And VCDS Lite is on version what? 1.2? Lol. The full software is at version 15.7.
    "You know you have a bad idea when Ford guys are making fun of you."
    because vcds lite is k-line only. its built for the aftermarket cables that only work on the older cars.
    contact via email please.
    Nov 14 2011
    NW
    You can log albeit slowly with vagcom and you can utilize it for block 098. Neither of which any 'generic obd2' I've seen can do. The point of vagcom is well beyond clearing codes and checking emissions status. When I think about it like that it does have some value :p still not anymore than 50$.
    Dec 23 2009
    Boulder, CO
    Since when can generic obd2 scanners access ABS modules, or your alarm system? A ten dollar ebay cable, and free vcds kills it.
    Nov 14 2011
    NW
    I'm 98% sure I can do both of those. But maybe not. If discovering which alarms went off like trunk or drivers door I can do that. And I can also find what wheel speed sensors have problems.
    You can't do a throttle body adaption with the free one right?
    Veteran Member Four Rings Silverstreak98's Avatar
    Dec 11 2006
    Minnesota
    Buy a real cable, has been probably the best purchase I've made for my car.
    In addition, if you ever sell your car you will be able to easily sell the cable for 80-90% of what you bought it for, aka these things don't really depreciate.
    ~Brian
    1998.5 A4 2.8QT
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Quote Originally Posted by Avant Nate View Post
    Some actually can do things like ABS codes- http://www.amazon.com/gp/product/B00...=sr_1_2&sr=8-2
    VCDS is still better, but I keep one of the above scanners in the car with me.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Veteran Member Three Rings mosnet99's Avatar
    Oct 10 2015
    2004 USP 1.8T, 1993 Jeep Cherokee Country
    Detroit, MI
    If all I want to see are DTC and emission data for making sure I'm not running lean, vacuum and fuel are good. Could I just get this: http://r.ebay.com/qR2Dg4 and download the free lite version? Sorry only had my A4 B5 for 2 weeks now.
    Nov 14 2011
    NW
    Yes
