Simply put... POS
1) The factory missed about an inch of welding on the center pipe where it meets one of the middle "mufflers" or whatever that is, causing back pressure and a P0171 and P0455 faults.
2) The pipes are not the same size as the OEM, so mating the center pipe to the front/flex pipe, I had to make a gasket to get a good fit
3) The pipes for the pieces they sent were not sized properly. Where the right muffler pipe attaches to the center pipe, the size was so far off, that could fit 1/16 gasket all the way around, but the left muffler fit properly onto the center pipe
4) The oval exhaust tip on the right muffler was not welded properly to the tail pipe, causing it to be rotated enough to be noticable
5) The exhaust system so f'ing loud inside the cabin that my 10 y/o son says it hurts his ears. It's obnoxiously loud inside the car when you accelerate. Cruising is ok.
Just don't do it.
Now, I'm going to call Rockauto and see what kind of remedy I can get. I'd like to just return everything (on their nickel) and go with something better, but I'm not looking to jump up to a $800-$900 system like the one from EuroParts. I'm just looking for OEM grade. I looked up original Audi parts, and that would cost $2000. I need to figure out what I can get, hopefully for under $600, that's better than this Bosal crap, assuming I can be made whole by Rockauto. If they won't play, then I don't know what I'll do. Damn, I'm pissed
