    Jun 20 2013
    2013 Audi A4 P+, Sport
    ATL
    Driver seat side bolster creak
    I have an 2013 A4 P+, 35K miles, with sport seats. When cornering or shifting weight the driver seat left side bolster (next to door) makes a lot of creaking and cracking noises. Dealer "tightened up some bolts" but the problem was not resolved and seems to be getting worse. Is there any way to tighten up the interior bits of the seat bolster (not the extendable thigh, but the one under your left thigh) to keep it from creaking? It may even be the seat riser mechanism on that side having some give, or something like that. It's not a major problem but annoying in such a quiet car.
    Veteran Member Four Rings B G 8er's Avatar
    Sep 28 2011
    2011 A4 Quattro Premium 6MT, 2016 VW Golf Sportwagen SEL Gone: 2013 Q5 2.0 Prem.
    Valencia, CA
    Have you tried conditioning the leather? I recommend Zaino Z9 and Z10.
    Jun 20 2013
    ATL
    It's definitely not a conditioning issue - the noise comes from inside or under the seat structure. I've been using Griot's leather conditioner recently but do want to try Zaino at some point.
    Jan 10 2007
    VA
    To fix it you have to locate the exact source of the noise.
    It could be inside the seat, the mechanism under the seat, or the plastic trim on the side.
    Oct 01 2014
    Pittsburgh/PA/Penn hills
    i have the same issue but it doesn't do it all the time only when i get out.
