So, a short presentation might be due first:
I have an Avant 1.9TDI 2002 with AVF PD engine, 6spd manual, ut has so far run 333203kms.
A short while ago I noticed that engine vibrations hade risen above my "this is okay and comfortable" - threshold, I have stiffer mounts around (except front buffer which is a new oem buffer) and idle vibrations increased a bit as expected when I had done the swap. The flywheel is new(and already diagnosed to be ok), the driveshafts are free from play and the boots are ok(which wouldn't matter anyway since the vibrations are there at standstill too and follow the rpm of the engine).
I don't have any errors pertaining to the injectors when I check codes, I do have the code referring to left motor mount broken circuit(since it's not there). I have however run the car for a short trip today using the flight recorder of my autocom adapter, I recorded fuel amounts, corrections, engine rpms and just about everything I could tick off in the list of stuff to monitor. Injectors #1 and #4 deviate more than #2 and #3 and I am going to swap the wiring loom tomorrow evening and also check up on camshaft and lifter wear to see if a new camshaft is needed anytime soon.
However, I thought I'd check how much blow-by the engine was creating and loosened the oil filler cap and had it sitting on the valve cover with engine running, it "chatters" around a bit but doesn't fall off(I also had a friend come over with his Passat, same engine, "merely" 278050kms, same gearbox and his does exactly the same apart from the rough running of mine), my car pulls fine, starts without a hiccup regardless of temperature, doesn't smoke except for a miniscule puff of black at start once in a while, never under acceleration or engine braking.
While I was rummaging around the general area I thought about vacuum leaks, I replaced all vacuum lines a year ago as most of them were rubbish, but now I noticed that the connection nipple(or vacuum inlet/outlet) on the tandempump could "wiggle", I suspect that this is not intended and thus creates a leak(brakes are fine so it cant be horrible). The question now is how this nipple is supposed to be attached to the pump body, pressed in or screwed? Since it's being subjected to vacuum I could probably just glue it in with something and the suction would make sure it seals good while running but I like to repair things properly and am not fond of swapoing out parts that can be repaired, my budget for keeping the car in good shape isn't that huge.
The exhaust fumes sting your eyes a tad, like all fuel wasn't perfectly combusted, could this be because of two injectors not playing along as happily as the other two? This has developed about the same time as the vibration increased, before this they just smelled as awful as pseudo modern diesel engine exhaust smells(compared to the quite aromatic smell of the exhaust on my father's 1964 pre-chamber diesel engine of his Fordson Super Dexta).
It doesn't consume water, it doesn't mix water and oil and there are no compression in the coolant system, I've only once had to top up engine oil with a whopping 200ml between oil changes(which I do myself every 10000-12000kms), am running 5W40 VAG 505.1 spec oil, oil pressure hovers around 1.6bar at idle with warm engine and usually around 3.something at 2000ish rpm.
Ideas and suggestions welcome as this is annoying me and it's not supposed to do this.
