Results 1 to 34 of 34
Thread: Parts Clean Out
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Parts Clean out UPDATED 1/14
    UPDATED 1/14, I have added more parts and tried organizing it some.
    Hey guys, stuff left over from previous S4 and RS4 part outs. Cleaning out the garage of the rest of the parts. THIS IS ALL I HAVE LEFT. The popular items are gone. If its not listed.....I really don't have it. Willing to let most of this stuff go pretty cheap. I can ship internationally with USPS flat rate. Can be available for local pick up but shipping is usually easier for me unless its big. Located in zip: 08826, which is Central NJ. I am on fourtitude and audizine if you are looking for some feedback. Just make me offers on the items, I don't have set prices really.
    Steering Wheels/Modules/Controls
    BLINKER STALK - 4e0953513A
    CRUISE STALK - 4E0953521
    4 SPOKE MULTI FUNCTION WHEEL AND AIRBAG - 8E0 000 124 B & 8P0 880 201 G
    Clock spring - 8E0 953 541 D
    Windsheild Wiper Stalk - 4E0 953 503 B
    3 Spoke B6 S4 Steering Wheel -
    Window Motors/Regulators
    SUN ROOF MOTOR - 4B0 959 591 G
    SUN ROOF MOTOR - 4B0 959 591 H
    WINDOW MOTOR REAR RIGHT - 8E0 959 802 E
    WINDOW MOTOR FRONT RIGHT - 8E1 959 802 G
    WINDOW MOTOR REAR RIGHT - 8E0 959 802 A
    WINDOW MOTOR REAR LEFT - 8E0 959 801 A
    WINDOW MOTOR REAR LEFT - 8E0 959 801 E
    WINDOW MOTOR FRONT LEFT - 8E1 959 801 G
    WINDOW REGULATOR REAR RIGHT - 8E0 839 462 B
    WINDOW REGULATOR REAR LEFT - 8E0 839 461 B
    WINDOW REGULATOR FRONT RIGHT - 8E0 837 462 B
    Modules/Sensors/Relays
    FAN CONTROL MODULE - 8E0 959 501 L
    FAN CONTROL MODULE - 8E0 959 501 AA
    FAN CONTROL MODULE - 8E0 959 501 Q
    HEADLIGHT MODULE - 4F0 907 357 E
    HEADLIGHT MODULE - 4F0 910 357 F
    HEADLIGHT MODULE - 4Z7 907 357
    TIRE PRESSURE MODULE - 8E0 907 273
    TIRE PRESSURE MODULE - 8E0 907 273A
    ESP MODULE - 8E0 907 637 B
    PARK ASSIST CONTROL MODULE - 8E0 919 283 D
    HOMELINK - 8E0 990 511H
    HOMELINK - 8E0 909 511A
    Pressure Sensor - 036 906 051 C
    Power Supply Module - 8E0 907 279 N
    Power Supply Module - 8E0 907 279 L
    ABS Module (RS4) - 8E0614517BE
    RELAY - 8d0951253A
    SERVOTRONIC RELAY - 8E0 907 307 A
    SERVOTRONIC RELAY - 8E0 907 307 C
    RELAY 53 - 141 951 253 B
    RELAY 370 - 8D0 951 253
    RELAY 614 - 8E0 951 253
    RELAY 81 - 431 951 253G
    RELAY 214 - 443 951 253 K
    RELAY 395 - 8Z0 951 253
    Engine Accessories
    ECU - 8E0 910 560 H
    Passenger front seatbelt - 8e0 857 706 F
    Driver Front seatbelt - 8e0 857 705 F
    EVAP - 8E0 201 801 J
    KICK BULSTER - 8E1 880 301
    AUX RAD (RS4) - 8E0 121 212 H
    AUX RAD - 8E0 121 212 D
    STARTER - 079 910 023 D
    STARTER - 079 911 023 D
    After run pump - 079 906 601 A
    AC compressor Denso - 4F0 260 805L
    Powersteering Pump - 4Z7 145 156 G
    HPFP - 079127025AF
    HPFP - 079127026AB
    S4 throttle body - 077 133 062 A
    RS4 Throttle Body (Damaged) - 079133062B
    AC Compressor - 8E0 260 805 B
    Intake Manifold - 078 133 201 AK
    RS4 Intake Manifold - 079133185AS
    RS4 Headers -
    MAF - 077 133 471 K
    RS4 ECU - 8E1 910 560 A
    RS4 FUEL PUMP - 8E0919051CQ
    INTAKE - 8E0 129 617D / 8E0 129 618 M
    Fuel Level Sender - 8E0 201 317 N
    EGR Valve - 026 906 283 H
    RS4 Injectors - 079906036D
    Airbags & Sensors
    PASSENGER AIRBAG - 8E1 880 204 B
    PASSENGER AIRBAG - 8E1 880 204 C
    PASSENGER AIRBAG - 8E0 880 204 E
    AIRBAG SENSOR - 8E0 959 643 B
    AIRBAG SENSOR - 8E0 959 643 E
    AIRBAG SENSOR - 8E0 959 643 D
    AIRBAG SENSOR - 8P0 955 557
    Auto level sensor - 8E0 907 503
    Interior
    Trunk/Gas release button - 8E1 959 527 B
    Right Dash Vent - 8E0 820 902 F
    Center Dash Vent - 8E0 820 951 H
    Card Tray - 8E2 941 561
    Lock Switches - 8E2 962 108
    center console insert - 8E0 863 276 C
    BLACK DASH - 8E1857041T24A
    Rear Left and Right Brushed Aluminum RS4 Trim - 8E0 867 419 / 8E0 867 420
    Arm Rest -
    SIREN - 8E0 919 279
    Ebrake cover -
    Front Left Door Harness - 8E1 971 029 AC
    Rear Door Harness - 8E0 971 687 L
    Front Right Door Harness - 8E1 971 029 AH
    Tiptronic Shifter -
    b7 key fob -
    Tire inflator - 8P0 012 615 B
    Tire sealent fluid - 8D0 012 619 A
    Exterior
    Rear Tail Lights - 8E5945095AKT
    RS4 REAR TRUNK - 8E5827023AH
    BLACK WINDOW TRIM -
    B6 shark fin -
    B7 fuel door (avus silver) -
    PASSENGER FRONT DOOR -
    B7 BUMPER SHOCKS (pair) - 8E0 807 271 A / 8E0 807 272 A
    B7 bumper shock - 8E0 807 272 A
    B6 BUMPER SHOCKS (pair) - 8E0 807 272 / 8E0 807 271
    B6 bumper shock - 8E0 807 272
    REAR PARKING SENSORS w/ harness - 8E5 919 280 / 8E0 971 085 A
    Headlight Washer Left - 8e0 955 101g
    RS4 Bumper Guide - 8E5 807 454 B
    Fender Well Spoiler Right - 8E0 853 888 F
    Fender Well Spoiler Left - 8E0 853 887 F
    Rear Fender Well Spoiler Left - 8E0 853 833
    Bumper Wing Support Bracket - 8E0 807 284 A
    Left Front Bumper Support - 8E0 807 203 B
    HOOD LATCH - 8E0 823 480 E
    HOOD LATCH CABLE -
    S4 SWAY FRONT - 8E0411309B
    SPARE WHEEL 17X8 ET 38 w/ Blizzak LM-25V 235/45/17 (8/32") -
    HORNS - 8E0 951 221 A / 8E0 95 223 A
    HORNS - 8E0 951 221 / 8E0 95 223
    HORNS - 8E0 951 221
    Headlight Washer Pump - 3B7 955 681
    Windshield washer pump - 1T0 955 651
    Aux Water Pump - 8E0 965 559
    Remote Trunk Release Motor - 8E5 962 115 B
    Veteran Member Four Rings Ashtonts's Avatar
    Jan 17 2015
    How much are you looking for for the black window trim?
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by Ashtonts View Post
    If you are willing to pick it up, $100
    Active Member One Ring 4marko's Avatar
    Nov 09 2013
    Mercedes C320 2002
    Battle Ground, WA
    Will the powersteering pump go on a 2.0 b7?
    Sent from my LGMS345 using Tapatalk
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by 4marko View Post
    It will not
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by 65vetteC6 View Post
    Is that all of the black window trim? Like the Titanium window trim black?
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by JDillon15 View Post
    Its the OEM trim paint gloss black (by a body shop, not rattle can). To go true titanium you need to remove the quarter window.
    Jul 11 2014
    Chicago, IL
    Yeah I knew you'd have to break that window out. What would it cost to ship? Just ball park?
    Jul 28 2007
    V8's
    In an Audi
    If I can find a box probably all of 50-75, finding a big enough box is the problem.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    AC lines?
    Established Member Two Rings B7dailyracecar's Avatar
    Sep 14 2015
    Oakville Ontario Canada
    S4 front and rear seat bars how much?
    Sent from my Nexus 5 using Tapatalk
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by Jake@JHM View Post
    AC lines?
    You got my last set before
    Veteran Member Three Rings midnight407's Avatar
    Oct 21 2011
    Brilliant Black B7, '06 STi borrowed/stolen from the roommate
    Northcenter/Ravenswood Chicago
    TOOL KIT MINUS LUG CAP PULLER -
    Rear Tail Lights - ?
    how much for these shipped to 60618
    midnight407
    Chicago, IL
    Jul 28 2007
    V8's
    In an Audi
    Bump
    Veteran Member Four Rings seal66's Avatar
    Aug 05 2011
    2008 Audi A4, 2015 Audi A3
    CO
    Are the vents black or no?
    2008 Audi A4 2.0T
    320awhp/420awtq...E85---UnitedMotorsports Tuned
    2015 A3 8v P-Stock
    2003 A4 Avant 3L-sold
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by seal66 View Post
    yea
    Aug 05 2011
    CO
    Full front set?
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 28 2007
    V8's
    In an Audi
    Full front set?
    Think I just have drivers and center now
    Aug 05 2011
    CO
    Okay. I need both outers, the center, and the two defrost ones, plus front center speaker one
    2008 Audi A4 2.0T
    2015 A3 8v P-Stock
    Jul 02 2012
    Yokota
    How much for the headlight switch connectors?
    Jul 28 2007
    V8's
    In an Audi
    updated 1/10, parts added
    Jul 28 2007
    V8's
    In an Audi
    control modules, belly pan, trunk latch, fog grills, ebrake handle all sold
    Veteran Member Three Rings P1Racer's Avatar
    Nov 18 2014
    Santa Cruz,California
    Hello, im interested in the right dash vent. 8E0 820 902 F. Is it black?
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by P1Racer View Post
    Yes it is
    Jul 02 2012
    Yokota
    What color is the arm rest? Please say tan!
    I'm also curious as to what difference it makes if you were to put an S4 throttle body in an A4, but I want to youtube it first, before searching here. Anyways, what color is the arm rest?
    Jul 28 2007
    V8's
    In an Audi
    Armrest is black
    Jul 28 2007
    V8's
    In an Audi
    Bump
    Senior Member Three Rings dba4's Avatar
    Sep 02 2010
    Markham/Ontario
    any chance you have a working hood strut? how much shipped to toronto canada
    Jul 28 2007
    V8's
    In an Audi
    Yes but I don't think shipping would be worth it. They are super hard to compress back down and pretty long to ship, I think you can get aftermarket ones for like $20 on Amazon, they might have a better shipping option?
    Jul 26 2013
    Arizona
    How much for a tpms module? I'm thinking of retrofitting one into my b7
    Jul 28 2007
    V8's
    In an Audi
    Bump
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    how much for these items??
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Bump
    I assume this is a sedan?
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by drewgold View Post
    Yes
