I have a 3.0 that I recently replaced the VC gaskets on and started getting misfires right after. I was wondering if you guys have some suggestions on what I should try next.
Just a quick background, I did my TB 2 years ago and replaced the VC gaskets as well as installed rubber heater hoses for the upper PCV hoses. Since then I've been having some slow oil leak on the passenger side. I finally decided to look into it two weeks ago, and found that the VC gasket was leaking slightly. So I decided to replace both passenger and driver side gaskets.
A couple days after the VC gasket install, I got a low oils warning and a CEL for misfires (p0300, 171, 352, 351, 301, 302). Checked under the hood again and found that the passenger side VC gasket is blown, and I have a huge puddle of oil in my garage. After further inspection, I found that the rubber PCV hose for the passenger side had a kink, which I though was probably preventing the pressure from getting relieved and eventually blew my new gasket.
So last weekend I replaced the passenger side VC gasket again, and redid the PCV hose by adding some 90 degree elbows to make sure it no longer has any kinks. I also went ahead and replaced the PCV valve, just in case. When I was redoing the VC gasket, I noticed some slight oil in cylinders 1 and 2, which would be consistent with my kinked PCV hose issue.
Got all of that done last night (had to wait for the PCV to arrive). I started the car and it idles really rough, as in I can feel the vibration on the seat. CEL is also flashing. I looked at the codes quick I remember p0300 is still on there and 301 at least, there's a couple more that I forgot to write down.
Any thoughts on what I might have messed up during the last VC gasket job?
On my way home today I'm planning on picking up some spark plugs. I will try wiping down the coils thoroughly in case they still have some residual oil, and I'll switch them around to check for bad coils. Anything else I can look into?
Thanks
tldr
- had passenger VC gasket leak so I replaced gasket
- newly replaced gasket blew + oil in cylinder 1 and 2 and misfire CEL
- found out PCV hose is kinked which probably caused pressure build up and blew gasket
- redid gasket and PCV hose + replaced PCV valve
- still getting misfires and rough idle
edit: are duralast (autozone) coil packs good? in case I need to replace mine. thanks
