Results 1 to 8 of 8
    Oct 11 2013
    United States
    Damn Water Cooled Alternator
    Yeah! I won the Delphi lottery... Two months ago my battery dies. New battery from dealer, then it dies again, dealer reconnects the posts, says I'm fine. FF and the other day I'm getting this joyous error on my B6 S4 dash, so have it towed to the indy. They tell me it's because oil from the heads are dripping down onto the serpentine belt, and the belt is spinning freely. Replace the belt, new gaskets & oil change $730. I pick the car up, start to drive home and I make it half way home. Car dies. Call them back... alternator.
    Dealer pricing on a new Hitachi alternator $665.00
    Unfortunately I'm an '04 so I don't have the Hitachi, I have the Delphi, which AoA doesn't sell anymore, instead they sell the DX kit which converts to the Hitachi for $1,490.04. Plus labor.
    Fortunately there's JHM, who sells a DX kit for $740.00
    And there's my local Generator/Alternator shop who said they can't even get parts for a water cooled unit, but legend has it they fixed one for $100.
    My question for you guys.... I've searched here & revolution and haven't seen anything... have you heard of anyone converting to a non-water cooled alternator setup? Why can't this be done?
    Jun 04 2015
    Southeastern MA
    I think a conversion is totally possible. I was staring at my alternator the other day thinking WTF is this shit when I pulled the motor. I think the major problem we would run into is there would be some genius Audi system that would throw errors or make crazy things happen. Actually finding an alternator to fit I think would be the simple part as it is just a 2 bolt attachment and a fairly large space as the stock unit is enormous.
    Veteran Member Three Rings quattro guy's Avatar
    Nov 30 2014
    06 audi a4 quattro 2.0 6sp
    rockford il
    http://www.wolfautoparts.com/0799030...FZCCaQodPtADtQ
    If you want to save some money i found this
    02 audi a4 Quattro 1.8 6sp, milltek exhaust, Motoza e85tune,f21 @26psi,stage 2 ra4 clutch, hyperboost diverter valve, 18z brakes, rear s4 brakes, TR11 FMIC, je pistons,ie rods 2.0 coil convertion kit (best 1/4mile time on stock engine at 21psi 13.4 @101mph)
    06 audi a4 quattro 2.0 6sp, gfb diverter valve, 2.5" test pipe, apr stage 2, r8 coil packs, s4 front brake
    05.5 a4 2.0tq 6sp, r8 coils, motoza e85 tune. S4 front brakes.
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    or just get it rebuilded !
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Senior Member Two Rings viridia's Avatar
    Apr 13 2011
    ham best meat
    Quote Originally Posted by Teledog View Post
    The water circuit is there to prolong the life of the alternator. It keeps the alternator at a constant temperature regardless of electrical demand.
    If you search "ARK104 alternator" there's an eBay UK dude who sells repair items. Might be able to point your rebuilder to that.
    87 4k, 90 f350, 91 v8, 93 v8, 04 s4, 0a3 transmission
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by viridia View Post
    This.
    Why reinvent the wheel on something simple like this. These V8s get hot as hell and the longer that I can get my alternator to last equals the happier that I will be. Also some of us have a set of SC brackets in front of our alternator that make it more time consuming to deal with.
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    I also have an 04 B6 S4 and had to replace the alternator. I upgraded to the Hitachi with JHM pipe kit for $120. I purchased used alternator for couple hundred bucks and its been fine. Was a pain to install, but all worth while. Good luck.
    Veteran Member Three Rings evolution2147's Avatar
    Mar 25 2012
    AZ
    Quote Originally Posted by JimmyBones View Post
    This.
    The alternators on these cars have zero free space around them and minimal airflow, not to mention they sit in an oven underneath the head and next to the block. The water cooling solves that issue.
