    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Question Android/iOS phone with a VCDS VAGCOM cable?
    So I've searched a bit and haven't found an answer to this, but any chance there's a way of using the RossTech cable (non-WiFi or Bluetooth) with an Android or iOS phone? Assuming we have an official cable and a USB > Lightning or USB > MicroUSB connector...is there any chance? I don't want to have to buy another adapter when I have a $350 one sitting in my glove compartment.
    Sep 16 2010
    Central Wash
    Never heard of it. Some hacker out there somewhere might have done a workaround, but generally the drivers don't exist on mobile platforms and the code isn't written for it anyway. I can only imagine that maybe you'd find a tiny windows tablet /phablet and VCDS might install / run with the drivers. But not on IOS, nope.
    Ross Tech's Hex-Net is the closest I've seen- but the price / limitations for the normal version makes it not worth it when I haave a decent touch screen laptop and a CEL like once a year.
    Jun 18 2015
    Cleveland
    Well I use a Surface Pro 2 for my laptop, so it's super portable, but it would just be nice to be able to plug the cable into my phone, if I were out and wasn't stopping at home to get my laptop.
    Apr 21 2009
    '03 A4 Quat, '75 Bronco
    Austin, TX
    Quote Originally Posted by rollerton View Post
    Just to clarify your point, the Windows tablet/phablet would have to be running the regular version (x64/x86) of Windows. I.E. This would exclude most, if not all, of the cheaper "Windows" tablets/phablets that have ARM chips (e.g. Qualcomm Snapdragon) and run Windows Phone or Windows RT. And for most intents and purposes this means that getting the HEX-CAN and/or VCDS to run on a cheap Windows RT tablet sits firmly in the "not possible" category. But under the "impossible" of getting it to work on iOS.
    (As a disclaimer for any nerdy types out there... I can think think of a few approaches that might result in at least a semi-functioning copy of VCDS on one of the cheap ARM-based tablets. But you could easily pick up a second minimum wage job and work fewer hours to buy a used Surface Pro 2 than you'd spend trying to get it to work reasonably well on a cheap Windows RT tablet. But of course for the nerdy types out there often the more effort it takes to hack it, the more worthwhile the hack is.)
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    i use a cheap windows tablet, cost me around $70 from cowboom. works great, has full windows on it.
    There are 10 kinds of people in this world, those who know binary and those who don't.
