So here is the deal:
I have '09 B8 with about 100K
Got the APR stage1 a while ago.
After the last oil change I had done at Audi shop it kept telling me to drain oil for a couple of weeks. I only knew that because I accessed the car settings through the MMI to see the oil level after the change.
I did not think much of it for couple of weeks thinking it is settling down and the shop knows what they are doing.
They also serviced the transmission at the time and resealed the vacuum pump (it was leaking oil), valve cover gasket, changed spark plugs and coils (misfire). Anyway on Saturday my check engine light went on and while I was sitting at the light It kept telling me to shut off the engine and check oil. When I did it told me to drain it. I assumed the level was getting higher so I called the shop and went straight there. After some back and forth they determined that the oil separator unit was shot and it caused the pressure from the turbo blow into the crank case. I left the car there to change the separator. They have just called me back today and told me that my rear crank seal is bad from all the pressure in the crank case and is sucking extra air causing lean mixture and rough idle. Frankly I don't believe them as the engine is not leaking any oil. From what they told me there is some "wet" on the bottom of the bell housing but that could be caused by the positive pressure from the turbo in the crank case when the separator went bad. Obviously that's a big job and they want a lot of money for it but they claim this is the only way to make the idle smooth again and get rid of the check engine light.
I would think this is a known issue/problem with these 2.0 TFSI but could not find anything on this forum or the web...
