Results 1 to 6 of 6
    Jun 18 2009
    Phoenix, AZ
    Resetting fuel level?
    Weird question, but does anyone know if it's possible to re-calibrate the fuel level sensor? The level sensor is the one on the driver's side, and it has the hose attached that sends fuel over to the other side of the tank. I had to replace my level sensor since the upper plastic "base" developed a small crack and was causing a leak, but ever since then I don't trust the fuel level my gauge is reporting. I just filled up a little while ago and put in 16.6 gallons with the fuel level still showing about 1/8th of a tank remaining. Something's not right :(
    Can I do it somewhere in VAG COM?
    2017 Camaro SS 1LE
    Veteran Member Four Rings TarlCabot's Avatar
    Feb 18 2013
    Can of Whoop @ss!!!
    Upstate, SC
    there are two sensors, one on each side, what your describing is an indication that one or most likely the other is bad/going out
    PAST 2004 Audi S4 4.2L 2006 Audi S4 4.2L 25th #167
    2015 Audi B8.5 A4 2.0T P+ S-line JHM K04-R Turbo 3" HFC/Downpipe FMIC Stage 3 K04 ECU and Stage 2 ZF8 TCU tunes ECS-Luft-Technik CIA/Air Scoop/Silicone Intake Tract GFB DV Bilstein Sport Struts/Shocks H&R Sport Springs 034motorsport Catch Can Kit D/L Control Arms/Bushing Rear Sway Bar with Front/Rear End Links 15mm-F/20mm-R Spacers Bullet Nose Studs/Nuts RS4 Honeycomb Mesh Front/Fog Light Grilles
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by TarlCabot View Post
    I only replaced the one on the driver's side, and immediately I noticed it behaving like this.
    I may try to take the parts off of my original one, and put it on the plastic base of this replacement. Dunno if it would help.
    2017 Camaro SS 1LE
    Veteran Member Four Rings PetrolDave's Avatar
    Jan 14 2007
    SOLD: 2006 B7 RS4 Avant
    Hampshire, U.K.
    Jun 18 2009
    Phoenix, AZ
    Quote Originally Posted by PetrolDave View Post
    Thanks much! Any instructions for doing this that you know of?
    2017 Camaro SS 1LE
    Jun 18 2009
    Phoenix, AZ
    For future reference, I found instructions:
    STEP 1 - CHECK THE INSTRUMENT CLUSTER FOR ANY INTERNAL ERRORS
    1. Turn the car ignition on, but do not start it. Using the VAG-COM, go into the Instrument Cluster control module (-17-) and select OUTPUT TESTS (-03-).
    2. Click on the START/NEXT button to initiate a sequence of tests. The first of these tests the sweep and calibration of the analog gauges. The needles for all four gauges (tach, speedo, coolant temp, fuel level) will drop to 0, sweep slowly all the way to their maximum, and then drop down to a calibration position. These positions are:
    Tach - 3000 RPMs
    Speedo - 62 MPH (100 KPH)
    Coolant Temp - 190°F (90°C)
    Fuel Level - 1/2 tank
    The Bentley CD indicates that if any of these settings in incorrect, then there is an unrepairable error in the instrument cluster and it should be replaced. All of mine are good, except for the fuel level, which displays just under 1/2 tank. This is obviously part of the reason for my incorrect fuel reading, but I'm not going to pay for another cluster just to fix it. Instead, you can use the VAG-COM to fudge the displayed level.
    3. Click the START/NEXT button to cycle through all of the remaining output tests. These tests will check the various warning lights, chimes and LCD displays in the cluster.
    4. Keep clicking the START/NEXT button until END comes up, click it once more and then click EXIT to go back to the main menu for the Instrument Cluster control module.
    STEP 2 - ADJUSTING THE DISPLAYED FUEL LEVEL
    These steps are based on those given in the Bentley CD and are intended to be used after the fuel level sender has been replaced. The proper way to calibrate the fuel gauge to the new sender is to drain the fuel tank, add 7 liters (1.85 gal) of gas, which is the exact amount in the "reserve" tank, and then adjust the fuel gauge needle so that it coincides with the red "reserve" line on the fuel gauge. I wasn't about to go through this, so I filled up my tank and adjusted the needle so that it read full (or as close as I could get it). The VAG-COM allows you to adjust the position of the needle an amount equal to 2 liters of fuel in either direction (+/-) of it's normal factory setting. To do this, do the following:
    1. Select ADAPTATION (-10-) on the main screen of the Instrument Cluster control module.
    2. In the CHANNEL box, enter 30 and then click on READ. This will display the stored value for the fuel gauge calibration and normally should be 128. You may enter a value from 120 to 136. Each number corresponds to a 1 ohm adjustment of the fuel level sender output and corresponds to 1/4 of a liter. You can use the UP and DOWN buttons to adjust the number while you watch the gauge needle move. If you're doing it the proper way, then adjust the needle until it lines up perfectly with the red mark on the gauge. If you're doing it a different way, like I did, then adjust the needle until it sits where you want it to.
    3. Click on SAVE. The new setting is now being used.
    That's about it. If you mess something up and want to go back to the original setting, it's 128.
    2017 Camaro SS 1LE
