Results 1 to 14 of 14
    Aug 22 2014
    Northern California
    AC Not Blowing Very Well/ How to Repair Blend Door
    Question my AC is not working well. I recharged it but the air is only nominally cooler than the outside air. I finally got my heater to work by flushing out my heater core. I don't think its the climate control unit myself as if that were the case I don't think the AC would work well at all. I suspect it is the blend door because 1. the 'modified' air only blows out the central vents the side vents have very poor air flow and 2. If it were the just the fact that the AC has a leak I think it would be blowing any cool air by now seeing as I charged it a year ago. 3. On some lucky days I will have good AC
    So any suggestions on how to fix the blend door or any other suggestions on what the problem could be?
    Mar 02 2015
    miami
    use vagcom and check if you have any codes. I did once and I simply cleared them and my ac worked fine again. that's where I'd start
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    If you don't have any HVAC codes stored, what are the high and low side pressures with the system running, as well as the ambient temperature?
    Sent from my Nexus 6
    Jun 30 2008
    Erie, Pennsylvania
    you can do basic settings on the HVAC module so it will relearn all the door positions/limits and such.
    Aug 22 2014
    Northern California
    And how do I do I do that? So you don't think the blend door control mechanism is faulty or anything?
    Mar 24 2017
    Va Beach/VA
    I have the same issue. My blend doors dont move though i took the cabin air filter out pushed recirc and no movement. I dont have a vagcom cable so anyways to reset without vagcom.
    Sent from my SM-G935V using Audizine mobile app
    Established Member Two Rings irishpride's Avatar
    Oct 14 2007
    to many to list ....
    somerset ky
    I had to replace all of the flap motors, red (PITA), violet, and light blue.
    my obsession. 06 A3 3.2l Q s-line, 04 Golf (2.SLO), 91 jetta 16v, 81 Rabbit 16v ITB'd monster.
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    Me too, but one flap motor...blue as i recall.
    I got the highest revision used flap motor I could find.
    Note the position everything is in as you take it out..PITA
    Mar 24 2017
    Va Beach/VA
    Where did you get the parts and how did you attack the location.
    Mar 24 2017
    Va Beach/VA
    I mean i have a b7 but they cant be too different
    Jun 12 2014
    Tampa FL
    ebay..used for me.
    wolf parts..as I recall.
    Veteran Member Three Rings john_gonzo's Avatar
    Feb 03 2009
    Florida
    The flap actuators get stuck. Here's a fix:
    1. Remove glove compartment.
    2. Turn key to ON. Engine off.
    3. Play with HVAC controls and watch for movement in flap motors. No movement? Tap it with a screwdriver handle.
    If you are lazy or pressed for time, try thumping the center console in the footwell area.
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    http://www.audizine.com/forum/showth...otor-Repair-B6
    The trimpots on the servos are usually the problem, not the motor itself. See my link for an easy fix.
    Junior Member One Ring
    Jan 30 2017
    MN
    Quote Originally Posted by Kevin C View Post
    You're a genius! My AC was mildly cool at best. I figured out the recirc mode wasn't working. After a ridiculous amount of searching I came across your comment and boom! Ice cold AC again.
    The entire job can be done in less than an hour. Taking out the glove box took up the majority of the time. When it cools down, I think I'll spin the other servos preemptively.
    Motors and gears looked brand new so I pulled out the trimpot and spun it in my fingers a dozen times. Problem solved! Thank you!!
