Originally Posted by
FormulaElement
I wouldn't rule out carbon buildup. At this point the cause is between carbon buildup, spark plugs/coils, fuel delivery, and/or the crank position sensor.
A easy thing to eliminate would be the fuel filter. Mine was really plugged when i changed it recently and was causing my car to have a really hard time starting. Its cheap and takes about half an hour to change.
Just as a test, turn your ignition to "on" and let it sit for 5-10 seconds and then try turning it on. If it turns on quickly after that then it might be a fuel delivery or computer related issue. If it doesn't help then its most likely carbon buildup.
If you wouldn't mind posting a video of it turning on. Your definition of "lots of turning over" can be very subjective and it's normal for a car to turn over more when cold and not being driven recently compared to when it's warm and was just driven...
SinCityA6
Carbon buildup (though not impossible) is very rare in the 3.0t motor. If he had a 3.2 or 4.2 I would think carbon was an issue.
Thank you for the input, Formula. Turning the ignition on (with the actual key) before turning it over seemed to operate the same. I will look to get a video, but I would say that the turning over sound is completely normal, but can take about 5 seconds (counting 'one thousand one, one thousand two, etc). It's not overly bad, but enough to make me think, "I hope it doesn't get my stuck here!" when I'm out and about.
The fuel filter could be something to try, as well as the plugs. As Sin mentioned, there really hasn't seen to be much carbon buildup on the 3.0T, even though it is another FSI motor. I would be surprised at enough carbon build up on this motor at 47k miles to cause any problems.
Thank you both - I will grab a quick video and consider either rolling with it or go ahead and replace the plugs and fuel filter. Thanks!
