Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 188
  1. #121
    Senior Member Two Rings LmG7119's Avatar
    Jun 03 2014
    MNN
    Quote Originally Posted by S4'ed View Post
    That is a 90AH battery, so I would use the 95AH BEM code: 8K0915105E MLA 180319JWV0
    Does it matter that it is made by Johnson Controls?
    2013 Allroad Premium Plus UM stage 1
    2003 Allroad EPL Stage1+ straight downpipes catless(sold at 187K miles)
  2. #122
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    No
  3. #123
    Jun 03 2014
    MNN
    This is my current battery. allroad battery.jpg I think it is H8 AGM
    That H8 AGM is actually 95AH https://www.pepboys.com/car-batterie...%202.0L%20DOHC
    I could go to H9 agm which is 100AH.
  4. #124
    Established Member Two Rings lenf's Avatar
    Oct 07 2014
    C NJ
    I purchased my 2012 S4 in August 2011 new. The car is still on the OEM original battery 8.5 years old. I don't have warning lights on my dash regarding the battery life. I live in central NJ, where winter can be cold and sommer hot. I'll change the battery when car will indicates it(maybe soon).
    This is from 2012 Audi A4-S4 owners manual:
    "Battery voltage:
    Applies to vehicles: with battery voltage warning. If battery power drops into the range where it can limit the ability of the engine to start, this the (•i symbol appears in the instrument
    cluster display with the following driver message battery charge low: Indicates charging by being driven. While t his driver notification is displayed, you have to be prepared for limited starting capability.
    Driver message appears and goes out again. If this driver message appears after the ignition is turned on or while driving and it goes out again after a while, the battery has been adequately recharged.
    Driver message appears and does not go out again. If this driver notification appears after the ignition is turned on or while driving and does not go out again, the battery's state of chargeis not in the optimal range. Starting capability is restricted. Have the battery checked at an authorized Audi dealer or other qualified workshop as soon as possible."
    Also from owners manual after replacing battery:
    "Your authorized Audi dealer must code the battery in the energy management system to enable you to use the energy management functions correctly after replacing the battery ."
    2012 S4 Prestige - Phantom Black; MT6; Sport Differential; Titanium package; Napa Black/Red seats; APR Stage II +; APR Carbonio Air Intake; Milltek Non-Resonated Cat-Back Exhaust; AK
    2019 Shelby GT350
  5. #125
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by lenf View Post
    I purchased my 2012 S4 in August 2011 new. The car is still on the OEM original battery 8.5 years old. I don't have warning lights on my dash regarding the battery life. I leave in central NJ, where winter can be cold and sommer hot. I'll change the battery when car will indicates it(maybe soon).
    "Battery voltage:
    You will need a new battery soon. No need to re- code if you replace it with an H8 battery. Electrical system will self adapt. H7 (not recommended) or H9 should re code
  6. #126
    Oct 07 2014
    C NJ
    So, I decide to replace battery on my 2012 S4 which is almost 9 years running on OEM original battery.
    I have no issue with original OEM battery, but don't want run into any.
    So, I decide to purchase either:
    1. AutoCraft Platinum AGM Battery, Group Size H8, 900 CCA
    or
    2. AutoCraft Platinum AGM Battery, Group Size H9, 950 CCA
    Can any of you guys comment which one should be better to replace with?
    P.S. My mechanic will re-code the battery for me for free, so I'll do re-coding regardless of the battery.
    Thanks in advance.
    2019 Shelby GT350
  7. #127
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I don't have any experience with AGM batteries, but I used a lead acid Autocraft Gold H9 950 CCA and it worked great.
    https://shop.advanceautoparts.com/p/...Autocraft+Gold
  8. #128
    Dec 10 2012
    1983 Honda CB1000 Custom
    granville ohio
    or
    Thanks in advance.
    My 2013 take an H9. It is 15 1/2 inches long. The H8 is a couple inches shorter. I am not sure all take the same size.
    2013 S4 Premium Plus, 6MT, Brilliant Black, Sport Diff, Red & Black Leather, B&O, APR Stage 1, AWE S-flo
  9. #129
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    any a4/s4/a5/s5 can take a h8 or h9. some came with h8's and some with h9's from factory depending on region and year. my s4 came with an h9 and i replaced it with an h8 agm, because they didn't have any h9 agm's at the time.
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
  10. #130
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    Autocraft gold going strong for a year now. I didn't have to recode. The car's MMI didn't turn on first, but had to start and stop few times, and did a hard reset (3 button).
    If I have to do it again, I'd go with AGM platinum. they're $150 with the 45% discount code now.
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
  11. #131
    Feb 24 2013
    CA
    Quote Originally Posted by Midnight_Rider View Post
    What’s the 45% discount code? I’ve only seen the trt30 code lol
  12. #132
    Jan 25 2015
    VA
    c23 is 20% off - advance auto (3/5/2020)
    RAKUTEN25 is 25% off - advance auto (3/5/2020)
    And if you wait a while with your item in the basket with the tab open, the 45% coupon pops up. I think maybe it was Wednesday deal, since I can't see it now. Now I think of it, I should have written it down...
  13. #133
    Oct 07 2014
    C NJ
    I replaced battery in my 2012 S4 B8 (was original flooded battery H8, 850CCA for 8.5 years since new. I haven't issue with this battery, replaced it just to be on the safe side) with AutoCraft Platinum AGM Battery, H8, 900 CCA from AAP with 25% off and $22 refund for the old battery, total $161 with tax. Start the engine normally like its nothing changed. No lights or warnings came out. I used battery tender to save all settings, so nothing's lost. Still I'm going to re-code the battery tomorrow.
    AutoCraft H9 battery is 8 pounds heavier and larger than H8 battery. IMO, H8 is better for S4 B8.
    2019 Shelby GT350
  14. #134
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Do you have B&O sound? Mobile doesn't show signatures.
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
  15. #135
    Junior Member Two Rings Bshiau's Avatar
    Dec 15 2019
    I just replaced my original battery (10 yrs old and still working), but like another member said, it was like living on borrowed time. I have B&O. Not sure if that makes a difference. But I got the AutoCraft Platinum AGM H9, 950 CCA. My core charge was only $5, so I’m going to keep it. I also have a VCDS cable so I did the coding.
    ‘10 S4 6MT | AWE Track w/stock DPs | ECS CF Inlet Kit | modified airbox | Chipwerke Pro 5-1 | StopTech Street Performance Axle Pack - Drilled & Slotted | Fly Designs Flatbottom Carbon Fiber Alcantara | Carbon Fiber High Kick Spoiler | Spyder Tail Lights
  16. #136
    Sep 27 2019
    CA
    Will an H7 850 battery from costco work for a b8.5 s4?
  17. #137
    Oct 07 2014
    C NJ
    Quote Originally Posted by audistealth View Post
    Yes I have B&O in my car. FYI B&O included with Prestige package by default.
    2019 Shelby GT350
  18. #138
    Oct 07 2014
    C NJ
    Quote Originally Posted by serafik View Post
    It probably will. But I'm not suggest you to replace with H7. Replace with H8 this way you may not need to re-code you battery. In any case, check your current battery and replace with whatever it may be(H7, H8 or H9). In my case the old battery was H8, 850 and I replaced it with H8; 900.
    2019 Shelby GT350
  19. #139
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    Did someone connect external 12v charger during the replacement process ?! so the car won't lose 12 volts and don't go to the full system reset.
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
  20. #140
    Dec 15 2019
    Quote Originally Posted by Strong Man View Post
    I hooked up a battery tender to the positive and negative posts under the hood. Not sure if I really needed to, but others have suggested it, and I already have one for my bike.
  21. #141
    Aug 08 2018
    Why does B&O matter? I have it and just replaced my battery without recoding
    2016 S4 P+ Ibis White | DSG | Nappa leather interior | Technology Package | Sports Diff | Black Optics | CR-15
  22. #142
    Jan 25 2015
    VA
    Me too. No recode for autocraft gold. I have B&O - no issues on B8.5.
    definitely do a hard reset on mmi. The VAGCOM mods remained intact - play vid, secret menu, etc.
  23. #143
    Jul 03 2018
    SC
    Quote Originally Posted by MerkurRS View Post
    The battery has been acting up lately (advanced key working intermittently, hesitated starting and the length of time the radio was on while car was off had decreased dramatically) and the batteries' life had declined appreciably this week so much so, it wouldn't start when I went to wash it. I had to decide on a battery and find one to install.
    As you know your choices vary a lot for this battery size (95R/ H9 in my case) between several brands and also between wet and AGM. Because they all weighed about the same- this was not a deciding factor. My choices on a Sunday were quite limited, so I couldn't really get a few exact prices, but made the assumption based on some web searches that AGM would be another $60-$100. I called the dealer the day before- they wanted close to $250 for the battery (list) and another $150 to install it. OUCH. I know the days of a "free battery install" in a car like this are over, but really?
    I called a few mechanic buddies for their opinions: They agreed AGM was not worth is since this is not a hi vibration application and a wet battery would be perfect. Pep Boys had a Bosch for about $160 (after coupon), but one mech. friend said he has seen a lot of newer Bosch battery failures lately and suggested against it. I have had bad experiences lately with Interstate in other cars, so that was out. I like Deka batteries a lot, but I would have to wait until Monday to find one, plus if I ever needed service on it- they are 25 miles away from me.
    I decided AGM, Bosch and OE were not worth the extra cost and I settled on buying one from Advance Auto. I am extremely glad I did too! I used a 30% off coupon and received another $20 reward perk back dropping the final cost to about $125. The best news is that the battery is made in Germany by Varta and came with the proper BEM code on the new battery. So you can disregard the info above on "tricking" your car to accept any BEM code you conjure up.....the Advance Auto is ready to go complete with a proper code! I drove to my local A/A to pick up my order...unfortunately the battery on their shelf was OVER 2 years old already. Buying a battery is like buying groceries- read your date codes!. I called around and found another store that had one in stock a little over a month old. Perfect!!
    I got the battery installed and car coded with the proper BEM and now I am ready to enjoy the car again....and head to the car wash
    Advance Autocraft batteries aren't made by Varta, even the ones "Made in Germany". They are made by Clarios, formerly Johnson Controls. Not that it makes a big difference, but I didn't want there to be false info out there regarding manufacturer.
  24. #144
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    The car won't go into a full reset if it loses power. The only thing you'll lose is the clock and the Trip Computer 2 values.
  25. #145
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    Just bumping this helpful thread to add a data point.
    I just replaced the battery in my 2009 A5 after getting 11 years from the original battery. I went with the linked battery in this thread from Advance Auto. However, the batteries there are now labeled as DieHard instead of AutoCraft, so I assume they bought the brand name from Sears.
    I got the DieHard Gold H9 (non-AGM) and it was a perfect match for my original battery. It had the same AH rating and was even manufactured by the same OEM in Germany (Varta). It also had a BEM code sticker on it so that I could properly code it with my VAG-COM.
    I keep my cars a long time, but after getting 11 years from the original battery, I assume this one will last until I replace the car.
    2009 A5 3.2 6MT | Brillant Black/Black | Prem | Nav | Tech | B&O
  26. #146
    May 05 2018
    South Florida
    Funny enough I just replaced mine today with a diehard platinum agm h9 950CCA. Car starts way quicker than before.
  27. #147
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    Quote Originally Posted by killer_s4 View Post
    Same here.
  28. #148
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    If you can find the Battery at Advance Auto, you'll usually get a coupon code for 15-20% when you shop online.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
  29. #149
    Oct 23 2006
    2022 Chevy Tahoe, 2012 Acura MDX
    Houston
    I hate it that I am asking here and can't figure this out on my own with searching. And, I have been searching for over 2 hours now.
    I am in a 2013 B8.5.
    My battery is the H9 size 850cc but it is 110Ah. I can not find a replacement battery with the same Ah outside of the $250 one from Audi. Am I just a dumbass who can't figure out how to do a decent search?
    Advance Auto Parts has the H9 950cc that many here say is great but it is rated at 105Ah for the platinum and 100Ah for the gold. Does anyone have advice for me?
    -Beck-
    2013 S5 Estoril Blue Crystal
    2003 A6 2.7T Silver
  30. #150
    Jun 25 2009
    2009 A5 3.2 6MT
    Southern NJ
    Quote Originally Posted by beckmaster View Post
    I bought that exact battery a couple of months ago (see my earlier post). The DieHard Gold from Advance is 110 Ah. Cost with the frequently available coupon was $128.
  31. #151
    Oct 23 2006
    Houston
    Quote Originally Posted by HobbesA5 View Post
    That’s strange. When I look online it is 100Ah for the gold and 105 for the platinum
  32. #152
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    I see a 10% off code, anyone know if there is still a 30% off anywhere?
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
  33. #153
    Oct 23 2006
    Houston
    After doing the battery replacement and coding in the new battery, I think the coding thing is garbage. My car was built in 2012 and the battery is brand new. There is no way a 2012 car will have any clue what I'm putting by the BEM code. I think it is just another scam to get you to use the dealer for something anyone can do themselves.
    My original battery went pretty low and I had a few fault codes I had to erase. Everything works just fine.
    -Beck-
    2003 A6 2.7T Silver
  34. #154
    Jan 22 2013
    Michigan
    Quote Originally Posted by Whitee View Post
    Of course when I need a battery, it seems like Advanced now caps the discount on batteries at 10%....
    Seems like Costco now carries Interstate AGM H8 and H9 batteries as well which is relatively new.
  35. #155
    Feb 07 2018
    PDX ish
    Quote Originally Posted by mavinwow View Post
    I neeed to get a battery. You pull the trigger on anything or find any good deals? Im seeing the 10% cap on Advanced Auto's webpage as well.
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
  36. #156
    Jan 22 2013
    Michigan
    Quote Originally Posted by hardfive View Post
    Tis the season for coupons so will see, have not bought one yet. Will get an H8/H9 AGM from whoever has the best price between AutoZone, Advanced, O'reillys, Costco. Seems to be a lot of coupon restrictions all of a sudden. PepBoys probably has the best deal right now but I dont have one super close.
  37. #157
    Feb 07 2018
    PDX ish
    Costco said there is a shortage. Mine sold out and doesent expect to get more until February. probably why coupons dried up.
    Sent from my SM-G973U1 using Audizine Forum mobile app
  38. #158
    Jan 26 2012
    Buick 1987 t-type turbo, Ram 2014 5.7 Hemi
    Northern New Jersey
    So it looks like after 9 plus years I have to replace my original battery. I like the Diehard gold 95R/H9 and if I use a battery tender to supply power thru the engine compartment while swapping batteries do I really need to "code" the battery? Have seen both opinions of do and don't but would like to ask of someone who didn't code, did they experience any issues after an extended period of time driving the car like that. Thanks in advance for any answers because I don't have vagcom and don't want to pay the stealership $150 to code if not necessary.
    2012 S4 6MT Ice Silver, MMI Nav, B&O Sound, Advanced Key, Rear Sensors, Carbon Inlays, 35% tint
  39. #159
    Senior Member Two Rings stoked_S4's Avatar
    Nov 10 2013
    2002 Skyline GT-R Mspec Nur
    Saw low battery icon on dash chime for the first time. Here is the read out from VAG taken 24 hrs after car was parked. Is my battery 78% aged or 78% life remaining?
    2022 X3M Competition
    2002 Skyline R34 GT-R Mspec Nur - 585hp Nismo Z-Tune
    2014 S4 Phantom Pearl Black | DSG | Sports Diff | Black Optic Pkg | MMI Nav | side assist | carbon inlays| Carbon Supercharged Badges | Michelin Pilot A/S 3+ | Eurocode Alu Kreuz | CR15 Bar | ECS SS lines SOLD
  40. #160
    Established Member Two Rings alarum_78's Avatar
    Dec 10 2012
    2007 VW GTI, 2018 GOLF R, 2010 Audi S4
    Ontario
    Just thought I would add I am on my OEM battery 2010 S4.. CRAZY!
    2010 S4 Quartz Grey, Sport Diff, Nav, Magma Nappa, 19" Peelers, S-Tronic.
