Page 1 of 5 123 ... LastLast
Results 1 to 40 of 188
    Junior Member One Ring
    Jul 16 2015
    Belarus
    Replacing OEM battery S4 B8
    Hi guys!
    Did not find any thread related on battery for our S4 B8. Mine has OEM Varta 110ah, CCA 850 EN with Part Number 8K0 915 105 F .
    However, it seems this battery is old one, and I found a replacement battery VARTA Silver Dynamic 110ah but 920 EN with Part Number 610 402 092 316 2
    It is also possible to get Exide EB1100 110AH , CCA 850 EN. The same specification as in my original battery.
    The question is: is the new Varta with CCA 920A is OK to replace, or it would be better to get Exide with the same specs as original one (110AH / CCA 850 EN)? Some people say it is even better especially during winter, but other think it may be additional load on Starter. What do you guys think?
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Don't have an answer for you, but did find this thread on a B8 S4 battery replacement that may help.
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Oct 30 2006
    B8 A4 Avant 6spd
    Mind you, if you have your battery replaced, you need to perform a adaptation for the gateway, instructing it that there is a new battery. Otherwise the battery management in the car is not going to regulate the voltage correctly. Could lead to premature failure of your new battery.
    -18 718 GTS
    Jun 05 2013
    Massachusetts
    According to this article, the car's computer will self-adapt if the battery has no BEM code.
    Read This
    Mar 26 2010
    US
    Quote Originally Posted by Militant-Grunt View Post
    One can just make up a code using the first few letters of the old code, then serial number digits from the new battery (entered with VAGCOM). It worked fine with my battery. It just needs to identify it as a new battery.
    BMW M3 Competition X-drive
    Jul 16 2015
    Belarus
    Thank you guys! Will study given links .
    Sure, I am gonna code the new battery , even if it has the same specs.
    Jun 05 2013
    Massachusetts
    Just called Audi Parts for a cost on a replacement battery... $269.10.. Ouch..... That's quite a bit more just to get one with a BEM code....
    Mar 26 2010
    US
    Quote Originally Posted by breyton490 View Post
    I coded the Autozone Duralast battery, no problem, just used the same old letter code with the new serial number digits.
    I fould this forum posting very useful for the battery recode: http://www.audiforums.com/forum/b8-m...2/#post1430403
    Coding is not hard with a VAGCOM (Ross-Tech): http://wiki.ross-tech.com/wiki/index...8T/8K/8R%2B%29
    "[Select]
    [19 - CAN-Gateway]
    [Long Adaptation-0A]
    Channel 004
    [Read]
    VCDS will populate instructions in the form of a pop-up balloon with the formatting. For example:
    Format: NNNNNNNNNNN XXX ZZZZZZZZZZ
    N = Battery Part Number (11 Digits)
    X = Battery Vendor (3 Digits)
    Z = Battery Serial Number (10 Digits)
    [Add to Log] Saving the original value to a log is strongly recommended.
    Type the New Battery details into the New value field.
    Note, the New value must be 26 (alpha numeric) total characters including the spaces! If in doubt check the saved log for the original battery formatting details.
    [Test]
    [Save]
    Providing the value was accepted by the controller the new battery coding is complete.
    [Done, Go Back]
    [Close Controller, Go Back - 06] "
    Apr 20 2015
    ND
    Read This
    So I just had my OEM battery fail on me this weekend after filling up (2012, just hit 30k miles, seems rather soon?)... had driven it twice that morning, but then that third start, without any sort of low-battery indication, it simply would not start. Heard the starter clicking, but not enough to crank. Anyway, got a jump, headed to Interstate Battery and had them hook me up with a new one and fired right up.
    Now I'm curious as to the "coding" since there is a bunch of conflicting data... Have done a search through the forums and people say you need to do it, yet others say they've never done it and no issues after replacing battery. I called my dealership and service manager said that if there were no warnings / advisories / CEL when I started with the new one, that I did not need to do anything further.
    Also the new battery does not have a BEM code label... so from the quoted bulletin from 2010 (references A6s, but suggests all models?) it says it will self-learn that there's a new battery. I get that I could have it coded with the same info as the previous battery and just change the serial number to something random so it knows there's a new battery, but is it actually necessary?
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Y'all are kidding... right? Coding a battery replacement? Damn Germans. No wonder they lost the war (and thank God for that).
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Mar 26 2010
    US
    Quote Originally Posted by DeltaHawk60 View Post
    There is probably a code number on the side of the battery, look for a symbol like a QR code, with a number under it. It may require a flashlight on the side of the battery to see it. Mine was a Autozone Duralast, but it is made by Johnson Controls, same as Interstate.
    I used JCB for Johnson Controls Battery Vendor 3 digit code: http://www.johnsoncontrols.com/conte...ry-brands.html
    "Johnson Controls is the leading supplier of batteries to many of the largest aftermarket battery retailers, including Advance Auto Parts, DAISA S.A., AutoZone, Costco, NAPA, Interstate Batteries, Walmart and more. Powering virtually every type of passenger car, light truck and utility vehicle, our batteries are globally sold under private labels, as well as our own brands – VARTA®, Heliar®, LTH®, MAC® and OPTIMA®."
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    The battery has been acting up lately (advanced key working intermittently, hesitated starting and the length of time the radio was on while car was off had decreased dramatically) and the batteries' life had declined appreciably this week so much so, it wouldn't start when I went to wash it. I had to decide on a battery and find one to install.
    As you know your choices vary a lot for this battery size (95R/ H9 in my case) between several brands and also between wet and AGM. Because they all weighed about the same- this was not a deciding factor. My choices on a Sunday were quite limited, so I couldn't really get a few exact prices, but made the assumption based on some web searches that AGM would be another $60-$100. I called the dealer the day before- they wanted close to $250 for the battery (list) and another $150 to install it. OUCH. I know the days of a "free battery install" in a car like this are over, but really?
    I called a few mechanic buddies for their opinions: They agreed AGM was not worth is since this is not a hi vibration application and a wet battery would be perfect. Pep Boys had a Bosch for about $160 (after coupon), but one mech. friend said he has seen a lot of newer Bosch battery failures lately and suggested against it. I have had bad experiences lately with Interstate in other cars, so that was out. I like Deka batteries a lot, but I would have to wait until Monday to find one, plus if I ever needed service on it- they are 25 miles away from me.
    I decided AGM, Bosch and OE were not worth the extra cost and I settled on buying one from Advance Auto. I am extremely glad I did too! I used a 30% off coupon and received another $20 reward perk back dropping the final cost to about $125. The best news is that the battery is made in Germany by Varta and came with the proper BEM code on the new battery. So you can disregard the info above on "tricking" your car to accept any BEM code you conjure up.....the Advance Auto is ready to go complete with a proper code! I drove to my local A/A to pick up my order...unfortunately the battery on their shelf was OVER 2 years old already. Buying a battery is like buying groceries- read your date codes!. I called around and found another store that had one in stock a little over a month old. Perfect!!
    I got the battery installed and car coded with the proper BEM and now I am ready to enjoy the car again....and head to the car wash
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Jan 21 2016
    Cincinnati
    Quote Originally Posted by wwhan View Post
    "[Select]
    [19 - CAN-Gateway]
    Channel 004
    [Read]
    [Test]
    [Save]
    [Done, Go Back]
    Im trying to CODE my battery Autozone Durmast battery please help me
    Jan 29 2013
    2011 Q5 2.0, 124" HD Dyna Wide Glide
    Philadelphia, PA
    I'm about to change my battery to a stinger battery for my audio system, what needs to be coded I don't get it
    2010 Phantom Black S4 Prestige DSG, Silver Nappa, APR stage 1, Milltek Non-res, AG M510s, BC Racing BR series coilovers
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    So, i'm getting conflicting information on if i need to code a new battery or not. I can get a OEM battery from the dealer at the same price as the Autozone battery described above http://www.autozone.com/batteries-st...47009&cmpid=cj
    Do i need to have some sort of memory saver so i don't lose any of my settings. Or can i just simply just remove old battery, install new OEM battery and everything will work ok and i won't lose any memory settings or other electrical problems?
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Veteran Member Four Rings Gunnark100's Avatar
    Oct 21 2012
    Earth...
    Quote Originally Posted by skiracerblah View Post
    If you replace battery without connected power source under hood, all you need after is sync your key(some cases no need) and windows and adjust time and clear error codes, 2min job. No other settings will be lost(at least not on my car), had battery disconnected "few" times!
    And if you getting same battery as your old, just change last digit of your battery code(serial) under gateway module 19!
    Retrofits: FL taillights / MMI 3G & 3G+(Street view incl.)/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Sub(in sidepanel)/Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
    Jan 03 2011
    Quote Originally Posted by Gunnark100 View Post
    Will this work, if i have access to another 12V battery, can i run jumper cables from the other battery and connect it to the battery terminals in trunk of car. Then swap batteries. Then, disconnect jumper cables?
    Note, i don't have VAG-Com
    Old cars:
    Oct 21 2012
    Earth...
    You should have + terminal under hood, close to the wiper, connect + there and - to the clean bodypart...it will work, same procedure on elsawin, but i recommend find somebody later to change code!
    Nov 28 2015
    Montreal, QC
    whn it comes to battery.. i believe the odyssey are on top. On SQ car audio forum, they are well respected item. I remember 1 yr ago, sears were selling their own brand deep cycle and were about half price of what a regular odeyssey would sell, yet were made by them and performed flawlessly on my other car, but now that i read i need coding.. i might just buy the OEM stuff lol -.- !
    Apr 16 2010
    BC
    Are our batteries AGM?
    Jan 03 2011
    yes
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Old cars:
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Quote Originally Posted by purelife View Post
    Not always. I don't think mine was, or my dealer replacement part was AGM. Neither said AGM and both had translucent white cases where I could see the fluid levels. My car was built in 2011 and was a 2012 model year.
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    Since this thread has been bumped, the cheapest replacement battery out there with the best warranty is actually Home Depot! They started to carry auto batteries and are great prices.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Veteran Member Three Rings abamfo's Avatar
    May 12 2016
    Melbourne, Australia
    I went to a battery dealer to get mine checked out. He is a Varta dealer and had a special Varta testing tool to test the OEM battery, we ran the tests and it instructed us to replace the battery (who would've thought!). We then went to the Varta battery catalogur and looked up an S5 3.0 TFSI, it said the recommended battery replacement was a Varta G14 (95A | 850 CCA). He did say that the only other option is an H14 (105A | 950 CCA) but it might not fit in the battery housing in my car as it is wider.
    There is no issue with getting a battery with more cold cranking amps, just measure your battery and make sure the Varta one you choose is the same size or fits in the housing. See link below, obviously it's the Silver AGM ones. Also my guy did the coding for me and installation for free, just had to buy the battery through him but if you have vcds it's really quite simple.
    http://www.varta-automotive.com/en-g...ilver-dynamic/
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Quote Originally Posted by MerkurRS View Post
    Kind of an old post but thank you so much for this, I love advance auto and after running all over town looking for an interstate battery advance auto came through having this battery in stock. Was this one you bought 950 cca? The one I ordered was and it had the same part number and looks identical to yours.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Read This
    Replaced mine with no with Duralast from Autozone about a yr ago. Did no adaptation. No issues.
    Jul 05 2014
    Houston
    I can't reiterate how good the advance auto battery is. It even has Audi/vw markings on it. I got 30% with code TRT30 and didn't pay a core charge when I picked it up in store. Three year warranty and it was half the price of the dealer. I did not have to code the battery either.
    Veteran Member Four Rings jlaudio's Avatar
    Mar 26 2009
    SLC, UT
    Quote Originally Posted by fitzydude View Post
    Link to part number? dealer quoted me $350 for the battery/install today. i have a vag com and can code if needed.
    '21 SQ5
    Previous: '10 B8 S4 6MT, 09 B8 A4, 06 S4 6MT, 07 A4 6MT, 02 A4 QM, 99 A4 QM
    Jul 05 2014
    Houston
    http://m.advanceautoparts.com/p/auto...920%7CL2*15000
    Seriously good deal with TRT30. And I was so glad they carried them in stock. Intestate battery was 220 and would take 10 business days to order.
    This battery is rated at 950 CCA and the factory is 850 CCA. It's the same size and the more cranking amps the better imo.
    Mar 26 2009
    SLC, UT
    $143 with the code. holy smokes thats a deal. any idea how i can recycle or return the battery in the car?
    '21 SQ5
    Jul 05 2014
    Houston
    Oh yeah any auto parts store will take it. Oops I guess they did charge me $22 for a core, just got even cheaper lol.
    Mar 26 2009
    SLC, UT
    Oh yeah any auto parts store will take it without a core.
    i was charged $20 for the core on checkout. i have no problem with that since it will provide an easy return/refund. $123.85 including tax. the store is only about 4 miles from me.
    really appreciate the quick responses, this saved me a bunch of money. i have an appointment for service with the dealer on thurs and can cancel the battery replacement. if you were local i'd buy you a few beers!
    '21 SQ5
    Jul 05 2014
    Houston
    Haha. Next time Im in Utah I'll hold you to that!
    Junior Member Two Rings
    Jan 20 2011
    2022 Audi Q5 and 2018 F-150 XLT Fx4
    Tennessee
    Thanks guys! The code still worked today. Although I went with the Platinum version because it was lighter weight, the code saved me $50!
    Veteran Member Four Rings Moose201's Avatar
    Aug 26 2012
    2013 S4 Ibis 6MT
    Was able to get an oem battery from the dealer today for $143. Normally $168 but they had a 15% coupon. It's been exactly 4 years so I thought I would be proactive with winter temps arriving.
    www.coldwartourist.com - Exploring ruins & relics of The Cold War
    Prior: 2006 S2000, 2005 S4, 2004 Mazdaspeed Miata, 1999 M3
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    When do people start worrying about the battery? I thought the OEM batteries where typically AGM, so are most aftermarket replacements also AGM?
    What happens if you don't code the new one?
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Veteran Member Four Rings Tanner's Avatar
    Markham, ON
    Quote Originally Posted by cjw View Post
    In one of the other posts:
    Yes, the battery needs recoded if you're replacing it. Our cars do enter a low power state when the battery begins failing and unless you update the battery code via VAG-COM the car will not recognize the new battery and exit the power saving mode. It's fairly simple but I did it with an OEM battery so I was certain it would have the correct numbers needed.
    I need a new battery also, it would have been three years old mid January, I would have expected to get *at least* four years out of a OEM battery as the battery is showing 50-60% after it sits overnight.
    So the question now is, what's a good battery that I can get locally here in Canada.... I'll have to check the dealer tomorrow as the last time I got just the battery from them the price was actually pretty decent.
    Mike
    Aug 11 2015
    Alberta
    I ask because a lot of older posts, guys didn't bother.
    CO
    I just replaced mine 1.5 weeks ago with the AutoCraft 95R/H9 (gold) recommended in this thread. It does have a BEM code on it, but I did not do any re-coding and have not experienced any issues.
    I'm not clear on what this power saving mode is that has been mentioned or its impact on the vehicle. I'm not following how the vehicle would be "stuck" in this mode if the battery were replaced and providing correct power. I could see it not going into power saving mode in the future because of incorrect coding.
    Regarding battery life: I think it's very situational, but I start considering replacement around the 4.5 - 5 year mark assuming the battery is showing proper health. Mostly because I live in a cold climate. I went 6 years on the battery in my B7 S4 and then it gave up on me on a very cold winter day. It showed signs of needing replacement long before, but I rolled the dice.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
