Originally Posted by
Segaman2002
Hi,
I am about 500 miles overdue for an oil change per the reminders set up in my car by the dealer at my last service.
A few days ago I got a notification / error message in my dash that said my oil was very low and recommended adding up to 1 quart.
I don't have a dipstick to check my oil level. Is this likely to be a major concern?
I want to take it in for an oil change sometime this week but am wondering if I should rush due to oil quantity being below minimum specifications.
Also, can everyone please advise if there is a consensus on whether or not Jiffy Lube is OK?
The dealer quoted me about $195 including taxes and Jiffy Lube quoted about $100. Would like to avoid the dealer if possible because I'm likely to get flagged TD1 if they scan me (though I sort of trust my guy would avoid connecting to the scanners).
Thanks.
Jiffy lube ROFL. Its like going to a Dr. that has no schooling and just winging it. You wouldn't let that happen. I wouldn't let a kid work on my vehicle let alone a 50K vehicle. Honestly its about the dumbest thing you can do it take your car there. Yes the price and the quickness seem appealing but you want it done right. I've seen way to many issues come from them since they have 0 training. I worked at a mazda dealership and we saw atleast once a month a blown up Mazda 3 engine come from them since they have no clue what they are doing and man handle the oil filter housing and break the cap and it leaks out out and locks the engine up. It got so bad at one point they were bared from doing oil changes on Mazda 3's. And it was a hassle for the customer to get jiffy lube to cover it.
Honestly you have just as much training as them and you can do it yourself just as well as they can. Its easy enough you should do it yourself. But if you look at the cost of what a dealer wants and what they do within the service its worth it. Divide it by 2 and you get the real cost of an oil change at normal intervals. It doesn't seem as bad since your changing it less often.
