Originally Posted by
FlyboyS4
What qualities make an IDC controller much better than the progressive controllers, and how do you plan to realize an advantage with an IDC controller?
With IDC controller you can dial in amount of meth precisely to the amount of fuel/air going in, it makes it independent of ambient temp as well since IDC reflects O2 mass and current requested AFR on the ECU.
Progressive controller is very crude in comparison as it only works off boost pressure. 15psi at 3k and 15psi at 7k looks the same to that controller but the amount of air and thus fuel going into the engine is vastly different.... factor in ambient temp changes through the year and suddenly you might have a difference of 200%+ of amount of meth injected at the same boost pressure but different RPMs leading to engien flooding or simply inadequate amount of meth injected WHEN you need it most.
With progressive controller you'd normally tune the car to not get flooded at low rpms (injection start PSI) and inject max at your max boost pressure. The result is that you reach optimal mixture at your first boost peak and then you sustain the amount of meth injection to red line... problem is that as RPMs go up, so does the amount of meth needed to curb the knocking but that's not happening with progressive controller since it is tuned to not flood engine in mid RPMs at boost peak....ooops.
With IDC you're free to somewhat linearly (or at least in much more controlled fashion) inject based on some arbitrary "min" IDC and "max" IDC (it works similarly top boost triggers in progressive controller). Since IDC is simply a unit the amount of fuel injected per cylinder cycle and it is not RPM dependent in this context, it allows the system to ramp up and sustain chosen % of meth to fuel until engine rpm cutoff.
I am of course not touching the subject of pump delay, time delay to build the pressure up and non-linearity of pressure/injection amount vs Pump duty cycle, this is why I said before that to truly realize precise control of meth you'd need bypass system with solenoid nozzles...
Edit: I just realized that something need clarification. Both controllers are actually "progressive". The difference is that DO one can only read analog 0-5v input voltage so you can only tap either MAP sensor of MAF sensor (this is what I did with mine) and live with shortcomings of system. Aquamist can tap IDC as well which is really a sort of PWM signal. So if you could make a circuit to convert PWM to linear 0-5v voltage, you can use DO or any other controller as IDC/PWM controller.
If I knew what I know now, Aquamist would be the syste to get due to its IDC signal pickup ability.
