    Veteran Member Three Rings mistral cytz's Avatar
    Nov 13 2013
    Source for Voltage Regulator?
    My Alternator's voltage regulator is dead since my car was reading 17 Volts at the battery during engine idle along with some intermittent electrical issues with the windows and environmental controls not working while driving. Everything works electrically with the car once the engines not running but unfortunately just a short drive with the bad regulator meant my battery was puffed and smoking like crazy..
    Anyways, I've checked with a few Audi dealers and the only voltage regulator (OEM part# 077903803C) according to their online parts database in all of North America is in Calgary Alberta and I called that dealership and they said it was pre ordered for a customers car as I suspected. So this part must be ordered directly from Germany with a couple of weeks ETA... ECS Tuning doesn't stock them and would have to order one through a dealer so same problem while JHM only sells the complete alternator which from California to me (Toronto) including shipping, duty and import fees and the insanely bad US-CDN exchange rate right now would mean about $1200+ for the alternator which would be even more than just buying a new one at a local Audi dealer IF they even had them in stock which they don't (Germany shipped again)!
    No other Canadian Audi dealer has any voltage regulators or complete alternators and apparently no US dealer has a voltage regulator. A few US dealers have complete alternators but it would end up being way more than even JHM. so I was planning to have a very reputable electrical shop refurb my alternator and just swap in a new voltage generator.
    So... end of rant...Anyone know how I can get my hands on a new regulator or fairly priced alternator?
    Thanks.
    2007 Ibis White S4 6MT Sedan. Fast Intentions 2.5" HFC downpipes and resonated catback, JHM Short throw shifter. JHM intake manifold spacers.
    Veteran Member Three Rings SprintBlueWorld's Avatar
    Sep 16 2013
    08 Hemi Big Horn, 08 Honda civic, 08 Audi S4 Cab MT6
    Pa
    Fleabay has a few, not too badly priced. Somebody round here should have one BCsniper or 65vetteC6 maybe Lucca.
    http://m.ebay.com/itm/AUDI-S4-AUDI-A...767?nav=SEARCH
    Oem RS4 Reps, RS4 Pedals, KN Air Filter, JHM 93 tune, JHM Intake Spacers, Rear Stoptech Slots & SS Brake lines, JHM 6-Rib Pullys, 034 Snubby Bracket, Dimple/ECS Oil & Diff Magnetic Drain plugs, Apikol Diff Mount, 034 Carrier Mount Inserts, Corsa RSC Cat-Back, 034 Sway Bar & End Links, Piggies in a Blanket, Front JHM LW Rotors, Hawk HPS pads, 13mm Spacers
    Nov 13 2013
    Quote Originally Posted by SprintBlueWorld View Post
    Thanks. I never even thought of checking eBay. I'm still a little unsure of buying a refurbished one only because the voltage regulator although likely bench tested is still likely original that could have years of heat damage to it and could fail at anytime. I'll contact the seller and find out more.
    Veteran Member Four Rings Blackstallion's Avatar
    Sep 22 2009
    No help with your thread but I saw/heard you around Mt Pleasant and Davisville. Car was fucking purring--Makes me miss my catless JHM headers FI setup...
    Ever tried www.germanoem.ca for OEM parts
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Anyone have a source for the VR, 077903803C, can't believe there isn't an aftermarket that doesn't cost $130
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
