Results 1 to 35 of 35
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Can you run a 5x114.3 with a M12 stud conversion?
    Hey all,
    I found a set of 5x114.3 wheels i like and was curious if you could run them on the 5x112 with a m12 stud conversion.
    I know you could run 5x114.4 with wobble bolts, but would i need wobble bolts (or wobble nuts) If I have the stud conversion?
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    Or a 3rd option you can do a fill & redrill.
    Veteran Member Three Rings audi-hammer's Avatar
    Aug 28 2009
    Buffalo,NY
    project B5 sells a stud conversion to 5x114.3 for like $85 I think, or run wobble bolts, $80 plus $20 for hubcentric rings or what he said fill and redrill
    Silvia = 02 s4 stageIII
    Veteran Member Four Rings bobkatkat's Avatar
    Jun 07 2012
    North of the 49th parallel
    Quote Originally Posted by CJ_ View Post
    Hey all,
    Yes you can.
    Oct 27 2014
    Flag/Phx, AZ
    with regular lugs?
    IG: CJ_s4
    Jun 07 2012
    with regular lugs?
    Tuner lugs. But depends on the wheels.
    Sep 14 2009
    s.e. mass
    yes you can, they work quite well.
    IG: @PB5S4
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    I've run the project b5 dot com stud kit for three different sets of 5x114.3 wheels for several years. Good product
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Veteran Member Three Rings ltipcke's Avatar
    Dec 02 2012
    st paul park, mn
    Bringing this back from the dead. Those of you running the m5x112 to m5x114.3 stud conversion with your 5x114.3 wheels. How large are your wheel bolt holes? Im trying to get my wedsport wheels (super light weight japan wheels) to fit with one of these stud conversions and theres no fucking way. The wheel bolt holes on these wheels are 12mm and the wheel gets hung up on the threads immediately and wont go on at all.
    I know people use wobble bolts. But that wouldnt work either since the wobble bolts are 14mm and the stock 14mm bolts dont fit through the 12mm wheel bolt holes. Im assuming my small bolt holes are the reason these wheels arent working with the 5x114 stud conversion...
    (race car) https://www.audizine.com/forum/showt...54-with-a-2-7T
    (daily) 05 S4 avant, built 2.7T swap, BW rs6s, corn
    Nov 04 2013
    stg 3 widebody, 1990 miata, '05 gsxr 1000
    Palo Alto, CA
    just bore out the holes... there are wheel refinishing shops that will do it, some for like $5 a wheel, others like $200 a wheel. Fill and redrill is another option, and would be what I'd do. I'm sure they make the appropriate wobble bolts too.
    Dec 02 2012
    st paul park, mn
    Quote Originally Posted by james 408 View Post
    Im sure ill have to bore them out. Just trying to make sure this is my problem first.
    Junior Member Two Rings
    Aug 09 2016
    Las Vegas
    Getting the 5x112>5x114.3 stud conversion doesn't actually change BCD it just allows you to wobble nuts?
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    any reason you cant just take a drill to the hole and go the next size up ?
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Veteran Member Four Rings Devious27t's Avatar
    Mar 02 2004
    2001.5 S4 Avant on Corn
    Orange County
    Quote Originally Posted by landfill View Post
    you don't need to fill and redrill. you need to drill like 1mm on 2 holes for 114.3 to fit. I've done it many times with zero issues.
    2018 Navarra Blue S5 Sportback
    2001.5 Blue Raspberry S4 Avant w/ hybrids on E85
    Past Audis:
    2015 Glacier White Allroad 2.0T
    2012 Ibis White S4
    2001.5 Nogaro Blue AWE/GIAC Stage 3 S4 16,500 mi
    Fast Intentions Wide Mouth DPs and custom 3.5" exhaust
    2000 Silver A4 Avant 1.9tqm 217k mi.
    2000 T28 A4: SOLD
    Nov 04 2013
    Palo Alto, CA
    the reason you wouldn't take a drill to it because it wouldn't be centered. not a big deal, just not best practice for avoiding vibrations. I mean do the math on drilling out 2 holes to make it fit, and tell me how that could possibly be centered properly, it simply can't.
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why wouldn't it be centered ? never knew the wheel was centered by the lugs . guess hub centering doesn't matter .
    pretty sure a wheel rotated 1mm to the left or right has noting to do with it being centered on the hub .
    Nov 04 2013
    Palo Alto, CA
    It's just geometry. If 5 holes are centered, you'd have to shave each hole evenly. If you only move two of them, it's not possible to be centered. Boring out for the wider thread yes, but 5x114.3 and 5x112 are different by 2.3 mm of diameter. By definition, you cannot center this freehand without extreme luck, and by only targetting 2 holes, you guarantee failure in this endeavor.
    https://www.tirerack.com/tires/tiret....jsp?techid=92
    Nov 04 2013
    Palo Alto, CA
    if you really want to freehand it you can do some math on each hole and either maintain drillbit size first and just use the edge, and then recenter with a larger bit between the two new centerpoints of an elongated hole. But as I understand it they just put it on one of their many wheel centering drilling machines, i've seen the shop, it's just a variety of drill-presses and lathes, each machine designed to do this exact sort of task. Just pay the man and avoid the headache. I mean i can probably freehand a direct line away from center decently too, but you know what you're trying to do sidebiting a bit into a hole like that. And really the problem is precision.
    Basically: 2.3mm divided by 2, divide that by 5 = each holes desired distance to move towards the outside.
    Edit: don't divide by 5 :)
    Nov 03 2011
    All Over!
    Spot on, James.
    Devious, the hub does centre the wheel - to a certain degree.
    The lug nuts / bolts do as well. This is why it’s important to use the correct nut / bolt seat to match the wheels. Drilling just 2 holes will mean as the nuts / bolts are tightened, there will be a natural tendency for the wheel to move towards the drilled holes. The centre bore will be tight on one side of the hub, and have a fraction more clearance on the other side.
    A fraction won’t be visible by merely looking at the wheel - indeed, there may not be any negative effects in driving at lower (city) speeds. At higher speeds though, that slight offset will cause vibration.
    We’re talking Japanese wheels here, so hub-centric rings will be used. Their tolerances will not be as snug as the OEM Audi 57.1mm centre bores either. I would pay a shop to get things done properly. Too much to go wrong free-handing, worse on just 2 lug holes.
    1986 Type 85 Audi 90 quattro
    Mar 02 2004
    Orange County
    I've had quite a few sets drilled and never had any issues with vibration or centering issues. While that might make sense in theory, with someone who knows what they're doing, it's 100% a non-issue.
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Mar 02 2004
    Orange County
    I've never free-handed, I've always used Supreme Power to get mine done. Like you said, just pay to have it done right.
    That said, they only drill 2 holes for 114.3=>112, not 5.
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Nov 04 2013
    Palo Alto, CA
    best practice imho is just redrill em. same thing they'd do a few miles down, in a machine shop. There are limitations here but I think that's exactly the redrill I did.
    each tapered evenly, centered, circular. Redrilled jap wheels. think i've been backwards in the direction... btw on the redrill. we're 5x112, sorry too many cars. Same advice.
    Jul 07 2009
    Alberta, Canada
    I ran my TC105N with 12mm studs and Kics lug nuts. Never had any issues. That was just with enlarging the stud bore. Keep in mind the seat is still slightly off center.
    If you want it to be PERFECT they should have the PCD changed. I think this involves some sort seat washer being welded in.
    - JVD
    Stage 6 B5 S4 - K&N Cabin Filter, PIAA Reverse Lamps, 4 Lug Conversion, Track Package, 4x 18" Pyle Subwoofers
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    I've ran wobble bolts on increased lug bore 5x114.3 for the last 2 years. Zero issues ever.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    Active Member Two Rings doo0T!doo0T!'s Avatar
    Mar 01 2019
    Auckland, New Zealand
    Quote Originally Posted by Devious27t View Post
    There is so much wrong with this. I'm sure you did get away with it but to my engineer type brain it sounds like fingernails on a chalk board!
    2nd'd, this is putting a whole lot of faith in your often plastic centric hub ring's abilities to hold up. Those wheel fixtures will be having a party in all directions.
    I chose to run M14 to M12 stud converters and then wobble NUTS over a hub centric ring and it works perfectly, everything is centered correctly and torques up evenly.
    IMO it's the only way to do it if you don't want to re-machine your wheel bores. If you are ok with boring your wheels out then that can be perfectly ok too.
    Many Japanese 5x114.3 wheels were not designed to be fitted over M14 studs so often the bolthole bores will slightly interfere with the studs or wheel bolt shanks when offcentre. You can get around this by chasing out your wheel stud bores to 14/15mm but if you ever wanted to put them back over M12 studs again you've now compromised the seating area under the bolts/nuts. That's ok if the wheels are only going to stay on M14 vehicles.
    Everyone who is suggesting you can just ram a 5x114.3 PCD over a 5x112 PCD and send it home without concentric correction on the fixtures (i.e wobble nuts) you should not be listening to them.
    Doing this is side loading the fixtures severely and all 5 fixtures will be fighting each other as they seat on their tapers.
    Yes with a reduction to an M12 stud you will be able to make it through the holes without any interference on the wheel but your ball or conical tapers under the nuts will not be concentrically aligned and if you torque regular wheel nuts down like that you will deflect the studs to one side before the tapers self align.
    With a wobble nut or bolt the conical tapers self align themselves as they are tightened and there is no side load produced. The whole assembly is relaxed and resting on the centric hub ring as it is tightened up and once tightened the only force remaining is pure clamping force between the rim and the hub/disc.
    Studs/bolts are not intended to take shear load in braking/acceleration. They should only take tension load.
    It's the friction provided by the clamping force that stops the wheel spinning. (like a clutch) The shanks of the fixtures should never touch the side of the wheel stud bores in proper application.
    If you run studs you need wobble nuts.
    If you run bolts you need wobble bolts.
    There will be plenty of people that argue with me on this and say they have never had a problem and that's fine but I would implore them to think about it logically before they do.
    Mar 02 2004
    Orange County
    Quote Originally Posted by doo0T!doo0T! View Post
    Your engineer type brain is over complicating this. I've been running multiple sets of wheels like this for more than 15 years on Audis. Nothing wrong about it. I've done over 180 mph on wheels like this with ZERO wobble or vibration.
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Nov 04 2013
    Palo Alto, CA
    sure, but you're more likely to have snapped lugbolts as well. It's not really up for debate to be honest -- it's just asymetrical. The tire guys balanced your wheel/tire combo, and this just doesn't always work especially under hard driving conditions. Further, it's balanced off your centerbore, not how the wheel is finally mounted.
    IIRC one of my buddies with an E30 drift car did this, he kept snapping lugs, not to mention there was a bit of extra care needed when mounting. Not sure what other contributing factors there were including really old crap and the fact nothing was balanced cause it's a drift car and that would be worthless in about 5 minutes. Think he sold the wheels after snapping a few studs as well. I'm pretty sure this was a homedrill but he read this same crap on a forum which is why he tried it in the first place.
    Edit: personally I wouldn't wobble bolt it either, plenty of longterm complaints on that stuff -- snapped bolts primarily, presumably fatigued metal.
    https://www.youtube.com/watch?v=33KljLVvTM0
    asymmetry is a bitch.
    Veteran Member Four Rings mikeb17's Avatar
    Oct 27 2012
    Lamborfeetes
    Washington
    This whole thread is giving me cancer... buy the stud conversion from PB5. Buy some tuner lugs and the right hub spacer. Fit your wheels. Done.
    Jul 07 2009
    Alberta, Canada
    It doesn't take an engineer type brain to figure this out.
    It takes a human with eyeballs.
    I ran straight 12mm studs with "tuner lugs." Yes, it worked. No, it isn't the proper solution.
    It doesn't take a genius to realize there's a difference between the two bolt patterns. As you tighten your lug nuts you'll be pulling all outwards away from the hub. This was not a problem for me as I had hub centric rings. The wheels would always center properly.
    Someone is trying to share CORRECT information and you guys are acting like he's the idiot.
    - JVD
    Dec 02 2012
    st paul park, mn
    https://photos.google.com/share/AF1Q...9JcHctcGZEMmtn
    i did have them bored out and im definitely not a fan of the side load it puts on the studs....we will see what happens i guess.
    Jul 07 2009
    Alberta, Canada
    Quote Originally Posted by ltipcke View Post
    Same setup and issue I was describing.
    Anyone else in the peanut gallery want to tell this guy he's wrong too?
    - JVD
    Mar 02 2004
    Orange County
    Quote Originally Posted by JVD View Post
    My drilled wheels fit 100% like OEM and do not load the studs. Yes, I will tell you that M12 studs and tuner lugs are garbage.
    Past Audis:
    2012 Ibis White S4
    2000 T28 A4: SOLD
    Oct 27 2014
    Flag/Phx, AZ
    Wow, blast from the past.. funny thing is I never ended up with 5x114.3 wheels. Found a set of BBSs that we’re 5x112 that I liked better.
    But man I miss that stud conversion, I should’ve pulled those hubs before that car went to the wrecker.
    IG: CJ_s4
    Jul 07 2009
    Alberta, Canada
    I'm still curious how this is possible. The lug holes and taper are centered on the 114.3 pattern. Regardless of stud size the stud will be slightly off center in each hole.
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    Yes, run 5x114.3 no issue on 112 car with a hub centric ring and stud conversion. M14 studs make it harder to fit some wheels because of the bore size on the holes, but a quick drill pass to make the wheel stud hole bore larger and they slip right on.
    Do the stack up if youre bored, the bending moment caused by the difference in size is not huge and the machining/casting tolerances of all the mating components ends up being pretty large differences anyway, so the difference in diameter of the pattern isn't really that big of a deal.
    RIP Daz, you will be missed.
