Results 1 to 6 of 6
    Sep 24 2015
    Olympia Wa
    Camshaft Position Sensor Replacement help
    Hey guys, new to the forums so I'm not sure if this has been covered in a previous thread for the b7s but, I have a 2006 b7 and am running into some issues. The car recently had some work done to it, with both timing belts replaced and tuned correctly (I'm assuming). Although, the engine seems to have some shaking to it and it idles quite low (barely below 1,00 RPMS). In addition the car doesn't seem to have a whole lot of power to it, its quite slow to accelerate as if it's misfiring. Yet, after it reaches 1,500 rpms or so it runs perfectly smooth and especially better when its on the freeway and at higher speeds. I had the ECU scanned, and it came up with a P0300 random misfire code subsequently giving it misfire codes for all 4 cylinders. Also, it gave me a p0340 camshaft position sensor (bank 1 or single sensor) code. The spark plugs are new on the car, the coils are fine, thus I'm fairly sure it's either the camshaft position sensor or the timing is off by a tooth. Although, it runs fairly well so I would assume it would run much worse if the timing was off.
    SO, I was hoping someone could point me to a guide on replacing the CPS, or at least a diagram/picture of the location of the CPS. Thanks!
    Veteran Member Three Rings audihere06's Avatar
    Nov 11 2013
    Charlotte NC
    Both timing belts? Sounds like the timing is off a tooth or so.
    Jan 05 2015
    London
    Would also be interested in knowing exactly where this is!
    May 05 2014
    B6 A4, B7 A4 and B8 A5 all R Black
    Adelaide Australia
    I would be checking the timing at the cam and crank are correctly aligned before spending $ on a new sensor, lack of power after a belt change usually indicates incorrect position.
    Veteran Member Three Rings Older_not_Wiser's Avatar
    Mar 16 2012
    2006 A4 Quattro 2.0T S-Line Avant Quartz Gray - Project Car
    Lomita, California
    IIRC the cam pos sensor is forward of the intake runner for cylinder 1. Before spending on the CPS, I would verify timing as stated above as well as look at cam follower. I thought a fair number holed cam followers also had CPS code.
    Image from another thread - not mine
    2008 A4 2.0T Quattro S-Line Titanium Sedan Phantom Black Pearl - Daily Driver
    2006 A4 2.0T Quattro S-Line Avant Quartz Gray - Project Car
    Mar 24 2013
    Oakdale, CT
    ^That's it. It is held in by a single bolt below the connector. Never tried but it's probably a pain in the ass to change. Pulling the intake manifold would probably help a lot with access to it.
    Edit: The bolt is a triple square IIRC.
    -Adam
