Results 1 to 40 of 46
    Veteran Member Three Rings Noel Artiles's Avatar
    Jan 12 2009
    2011 E90 M3 , 2006 B7 Audi A4, 2016 Chevy Suburban LTZ
    Miami
    Full Mesh Grill Build Tutorial with Ebay Parts
    After cleaning out my garage this past weekend I uncovered some extra grills I had lying around for the B7. I already have a full mesh grill but I decided to make a spare so I thought I would document my process while building it.
    I know a tutorial to build a Full Mesh grill for the B7 A4 already exists, but I thought it would be good to have another version for those who want to build one on a budget. The original tutorial uses OEM parts which can run you up a couple hundred bucks more than just exclusively using only Ebay parts.
    You'll end up spending anywhere from $200-250 for all the materials including both grills, plastic welding rods, body filler and paint (Depending on what you have available already).
    Materials & Tools
    First you'll need these:
    1) A spare B7 A4 Grill (Non-Sline). I used the all black version. There's a silver trimmed version and an all black version. They are both the same grill except the silver framed one is painted silver. For a chrome trim you'll have to go OEM for donor grill.
    http://www.ebay.com/itm/05-08-AUDI-A...776a89&vxp=mtr
    2) A full mesh grill:
    You don't necessarily need an RS6 grill. The merchant who sold me the Rs6 grill sent me an B8 RS4 grill instead by mistake and I used that instead. They will both work. Go with the cheapest version you can find. There are also different full mesh grills. One is the larger honeycomb grill with a ring base that attaches on to it as a separate piece. The other version has the ring base molded on to it with 2 different mesh styles on it (honey comb, and small diamond mesh in-between rings). I went with the molded version.
    http://www.ebay.com/itm/2009-2010-20...981e89&vxp=mtr
    http://www.ebay.com/itm/like/1818651...466&rmvSB=true
    3) ABS Plastic welding rods and plastic welder/Soldering Iron ( I used this as it will have the strongest bond as I merge the grills)
    4) Dremel with cut off wheel or carbide cutting tip, sanding bits
    5) Body filler or JB plastic weld (to help shape the edges where both grills meet)
    6) Orbital sander
    7) Satin/Matte black paint, and primer
    Step 1: Prepping base grill
    I started by gutting the Ebay B7 RS4 grill. Carefully remove the center and once you've done that sand all the high spots in the inner lip, making it smooth. Once your done it should look like this:
    You'll see that the grill frame will have some notches left over. That is where the filler plate / license plate holder once was. We're going to patch them up.
    I personally cut out and used a chunk of the discarded filler plate to weld onto the gap. Carefully trim the edges back so it fits flush up against the edges. It's ok if there are holes as you can fill them later.
    You'll want to clean this up by carefully trimming off the excess plastic and lining it up with the edge of the rest of the grill. Be careful to not cut off a screw post. Next sand everything smooth and fill any holes with melted plastic weld rod and sand it smooth. I should look like this when done.
    Step 2: Cutting out mesh grill
    I did not get any pics of this, but it's pretty straight forward. Just make sure you leave enough of the grill along the edges, especially up to and on the bottom. I used the carbide tip to quickly cut out the grill. If you cut off to much it's also ok as you can just melt welding rod up, and fill the gap. Think like 3d printer.
    Step 3: Merging them together
    Once both pieces have been cutout it's time to rough fit. You'll want to cut as close to the edge as possible. I like to leave to leave a little more material and cut it down little by little, spoke by spoke to make sure it's a snug fit.
    Once you've trimmed the center down hold it in place with Zip ties to begin plastic welding. It took me about 3 hours to weld it together. I welded both behind and in front of all the spokes. This will make it a super strong bond. For me it's better than glue/fuser. Plus you can sand everything down to a smoother edge later better with plastic than with glues. Just make sure you blend your plastics well together. If your ABS rods are white make sure they end up black after to ensure a good weld.
    Step 4: Finishing touches
    After everything is welded up it's time to clean and smooth everything up. Depending on how anal you are, a this point you can just sand your welds down smooth and paint the grill. It will look good from far away but really rough up close. That my friends will drive me nuts so I'm going the extra step.
    For this step you'll need either the body filler or the JB weld to build up some bulk to sand and shape. I personally used the JB plastic weld as it has a stronger bond than body filler and sands just as well.
    To be continued...
    Got to finishing sanding everything down and I'll post the remaining steps.
    Hope this helps some of you.
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    Interesting. I think I might like to do this at some point.
    Mind giving a rough breakdown of price? Since it is a "budget build".
    And also maybe a rough time estimate.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Dec 23 2011
    Nice writeup.
    Jan 03 2014
    JERSEY
    Really good write up. Thanks a lot. Plan on doing this soon, as well as mesh for the fog light grills.
    Jan 12 2009
    Miami
    Quote Originally Posted by JDillon15 View Post
    Estimated pricing is up top. If I were to buy the materials new it would be around $225-250 I would guess. Not including tools.
    For Step 1 I spent about 3 hours
    For Step 2 I spent about 30 minutes
    For Step 3 I spent about 3.5 hours
    For Step 4 I've spent about 1 hour putting on putty, sanding Im guessing will be another 4 hours.
    It can be done in a weekend if you wanted.
    Veteran Member Four Rings mpv314's Avatar
    Apr 06 2012
    Audi A4 2006 Quattro
    New York, United States
    Fantastic write up and much more affordable. I should have done this
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by Noel Artiles View Post
    can't wait to see the finished product. Thanks for the breakdown of time.
    Nov 13 2011
    b7 s4 avant
    Very nice man. My grille looks rough so I tell everyone to stay ten feet away lol
    Sent from my SM-N900V using Tapatalk
    I drive a truck now.
    Forum Moderator Four Rings docurley's Avatar
    UK London
    very good write-up
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Established Member Two Rings realax's Avatar
    Jul 10 2015
    los angeles
    sweet!!
    sell me that one tho loll
    no..but really.
    Apr 06 2012
    And for anyone that might need further steps, Phil's DIY is great too. Same process just different grilles. What did everyone use to black out crash bar? Plastidip?
    Link here
    Jan 12 2009
    Miami
    Quote Originally Posted by mpv314 View Post
    Link here
    I built a custom fiberglass cover that goes behind the grill.
    Here's what it looks like installed.
    Old look but you can see it here.
    Jan 12 2009
    Miami
    I was thinking of cutting the damn center off but my eye just felt it needed something in the middle optically. Especially since the rings are positioned up high.
    Jan 12 2009
    Miami
    Quote Originally Posted by realax View Post
    sweet!!
    no..but really.
    Sorry brother this one's going in the parts bin, lol. I was actually contemplating making a plastic injection mold made and getting them replicated in China. Since it'll be pretty sculpted once it's done. But it's about 6k for 10k units. Not sure there is even a demand for it.
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    Attempted this and failed, one of the big issues was I didn't use an RS4 style grille, so its riddle with these big gaps all around the edges..
    Noel, I would bet there is absolutely a demand for it, but the question is if its financially viable at that number of them.. Could be interesting to see.
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Jan 12 2009
    Miami
    Quote Originally Posted by pw211 View Post
    That is exactly why I did not go with the standard OEM grill as the donor. On my first attempt I cut out the center of my OE grill and I was like WTF, this is a f'n mess. To much work to get it to look clean. I tried it with this Ebay grill the next time around and it was so much easier to handle.
    Jan 12 2009
    Miami
    Might look into a couple hundred units and see what those numbers look like. If I can get the production down to at least 2k I can swing that for a project like this. Gotta ask a friend who gets shit made in China to see if he can get me a good connect. I'll keep you guys posted.
    Apr 30 2014
    B8.5 S4, A3 e-tron
    CA, Bay Area
    I'd buy one, for guys with DTM like me and want to match the look of the fog grilles, the euro plate RS4 eBay option just doesn't cut it.
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Sub'd! I just got myself a donor OEM s-line grille and some gloss black autodip (aiming to replicate my current TI grille). Hoping I can get my cuts clean though. Going that extra mile to sand things down looks like a major PITA. Kudos for the detailed write-up! I already put all my gadgets aside from what you've listed
    2008 A4 2.0TQ Ti - 6MT
    1991 MR2 Turbo - 5MT
    1997 Pathfinder 4x4 - 5MT
    ~Marc
    Jul 25 2010
    Spare engines!
    Denver, Colorado
    very nice writeup
    Veteran Member Four Rings Lastsummer's Avatar
    Nov 25 2011
    2021 B9 Audi SQ5 Black Optics
    Grayslake, IL
    Quote Originally Posted by QuattriumMT6 View Post
    Im curious to see how the black autodip turns out. I have a brilliant black car and I would like to have more of a gloss or semigloss finish. Plastidip can do it but you have to mix gloss or topcoat to get the finish and then that still fades.
    I definitely subscribed to see more results.
    2021 B9 SQ5 - IE Turbo Inlet, IE CAI, 034 Motorsport Stage 1 ECU/Stage 2 TCU, O34 Strut Brace, 034 F/R Sway bars w/ end links, 034 trans bushing & insert, 034 RSF inserts, 034 rear diff inserts, 034 lowering links
    B8.5 Audi S4 - Monsoon Gray - EPL Stage 2 - Single Pulley, EPL TCU, ECS Carbon Intake, ECS Mid-pipe, Magnaflow Catback, ECS Drivetrain/Trans inserts, ECS Lower Control Arm Brace, CR-15, S5 Peelers, H&R sports, Bilstein Shocks
    Apr 06 2012
    Quote Originally Posted by Lastsummer View Post
    Veteran Member Four Rings DanKing's Avatar
    Aug 14 2014
    California
    I shall b doing my grill, fog surrounds, rear valance and cupra R lip in this stuff this weekend. I've had the auto dip since it was released ...just never had the time so far
    Sent from my Nexus 6 using Tapatalk
    '07 6MT Brilliant Red 2.0T
    JHM Stage 1 • JHM test pipe • ST coilovers • Smoothed Cupra R lip • Relak Skirts • 3sdm 0.06 • 034 mounts • Revo snub • GFB DV+ • S4 Recaro seats • RS4 Steering Wheel • Joey'd Bi-Xenons • Phils V4 LEDs • STI projectors • LEDs everywhere • APR Carbonio Intake • p3cars Gauge
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Quote Originally Posted by DanKing View Post
    Do a DIY for sure!
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Aug 14 2014
    California
    Quote Originally Posted by Copen-cisco View Post
    Do a DIY for sure!
    Will do ...keep ya eye out :-)
    Nov 25 2011
    Grayslake, IL
    Have any pics of the finished product?
    Aug 14 2014
    California
    Letting it dry over night currently....
    That cupra R lip install is alot harder than ppl say to get perfect
    I drilled half of it together whilst the bumper was off then the other half didn't match and there was a gap ...so I said fuck it and sprayed it and try and install it when it's dry.
    Currently
    Excuse the mess
    Nov 25 2011
    Grayslake, IL
    Currently
    Excuse the mess
    Looking good so far! How was your experience working with the autodip? Pretty easy to use?
    Aug 14 2014
    California
    super forgiving even more than plastidip dip .... Got really dark while i was spraying so did half of it in the dark... But layered the shit outta it ...ended up using 1 3/4 cans on just those parts. But hopefully it looks good in the am :-)
    Nov 25 2011
    Grayslake, IL
    Were you able to get any pics of the finished result during the day today?
    Aug 14 2014
    California
    I just took some pictures with a proper camera but it was kinda dark I'll post them tomorrow after I transfer them to my laptop etc etc
    Here is the parts dried up.
    I really like this stuff. My cupra R lip looks perfect in glossy black matching the glossy grill surrounds :-)
    Jan 12 2009
    Miami
    Does it have a smooth finish, or is kind of orange peel'y up close? Can't tell by looking at the pic.
    Aug 14 2014
    California
    It's smooth... I'll post some better pictures when I get a mo.
    The rear valance is kind or rough in texture so its hard to judge on that part. But its the same as say a vinyl wrap finish :-)
    the cupra R lip is flat black and bumpy... But now i think it looks great in glossy black
    I didn't use autodip on the fogs above ^ . I ran out of spray :-(
    PS. Sorry for the thread Jack....still wanna see this grill completed :-D
    Aug 14 2014
    California
    Here are some better pictures to show this autodip off (nights shots tho) :
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Very good write up. Here's a few shots of my grille. I used an OEM B7 s4 grille and got the mesh from an eBay RS6 replica grille. Keys for me were having OEM style rings and not the separate 'ring holder' as well as the smaller mesh inside the rings ala the OEM RS6 grilles.
    The eBay replica I bought is almost identical to OEM.
    I too used JB weld for mating the grilles but also used a lot of q-bond which worked really well. Q-bond is extremely strong, fills voids well and is very easily sanded. Worked perfectly for this application.
    Tough to tell from the pics but the grill mesh is gloss black. Not sure how I feel about the gloss finish, may still go matte black.
    I also wrapped the frame in brushed black steel Vinyl to match my window trim.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Aug 14 2014
    California
    Quote Originally Posted by drewgold View Post
    Looks good! Well done !
    Close ups of the joining of the mesh would be lovely :-)
    Sep 21 2004
    Ask and you shall receive!
    The top and bottom joints are nearly perfect. There are two small spots on the leading edges of the sides that I may sand and re paint.
    I used rust oleum ultra cover to spray the outer edge. It covered small imperfections very well. I had originally planned to paint, then sand again, fill any imperfections, and apply a finishing layer of paint but you have to look really close to see any signs of gluing of the mesh. If I end up plasti-dipping it, you won't be able to tell at all.
    Aug 14 2014
    California
    Wow you really did do an awesome job!
    Jan 12 2009
    Miami
    Yep looks good @drewgold. I would go back to matte though IMO. It does a good job of hiding any little imperfection because it does not bounce off glaring. Also touch up's are a shit ton easier to deal with when it's matte paint.
    Here's how JB Weld and Plastic Welding combined will eventually end up looking like up close. Still have to finish sanding the one I started up top.
    Jul 11 2014
    Chicago, IL
    Mind getting a photo from a few feet back? I'd love to see how this all comes together.
    Looks great from up close! I might be selling my grill and trying this out.
