Originally Posted by
The Overclocker
ok the update is that i forgot to mention that i hade 2 dtc that i cleared p1136 + p1556
P1136 = Long Term Fuel Trim Additive: Bank 1 System too Lean
P1556 = Charge Pressure Control: Negative Deviation
The first code means you have a low MAF reading at idle. Usually due to a leak.
The second code is a low boost pressure code.
The Overclocker
at idle i'm at 14.8% over fueling ... thats wayy to much according to him
He is correct. That is way too much. But the idle (additive) trim is half the story. What is the part throttle (multiplicative) trim? That would be the number right beside the 14.8. That other number will help us internet-diagnose your car a little better.
As it stands, I can say you have a leak somewhere. Air is getting into the manifold at idle, but is bypassing the MAF. Could be in the Turbo Inlet Pipe, could be in any hose connected to the manifold. Or anywhere in between those 2 things.
You also have low boost. This could be due to the leak. The turbo could be perfect, but you are just leaking all the boost out of somewhere. So one leak could *potentially* explain both issues. It could be sucking air IN at idle, and the blowing air OUT when in boost. All from the same tear in a single hose. It could even be a hole in the intercooler.
BUT, if you were losing that much boost (which, to trigger a low boost code on an AEB, would have to be like...all of it) we should also see a VERY NEGATIVE part throttle (multiplicative) fuel trim. It should be adding fuel at idle, and then pulling it back at the top end. We don't know that yet until you get us the part throttle trim details. Not to mention you said you did a boost leak test and didn't find anything. So while this theory is neat, it may not explain your problem.
So you may have a different reason for no boost (ie: missing wastegate flapper, dead N75, etc.) and the wonky additive trim could be due to a
vacuum-only leak that a boost leak test will never catch. Meaning a leak that is behind a check valve. Like a broken evap line or something.
So those are my 2 theories. 1 leak that explains both things, or 1 vacuum leak along with some kind of turbo/wastegate/control issue. The part throttle trim information would be helpful to narrow it down.
