New to the mix,
random no hot start. Will check for DTC(s)
I popped the hood and re-plugged the CPS, it worked. Maybe it would've too, by re-connecting the battery.
I heard somewhere this is all due to a faulty relay not allowing the ECU to get power at times.
Considering the CPS is good, what else could it be.
Hence why it cranked but didn't run.
Cranking only requires a starter and battery.
Running requires an ECU.
I didn't check the spark plug yet but I'm sure it's fine, same for injectors, they're freshly serviced (flow-tested, cleaned, etc.).
-------OR-----
Could it be lack of RFI/EFI shielding on the CPS->ECU harness? The wire wore out and broke so I put a crimp, the shielding contact no longer established.
But that was like a year ago. And these symptoms seem random.
If it was a shield issue, maybe it would happen consistently.
Not sure if the shield works as a ground.
Maybe I can wrap some aftermarket, or tear apart the harness to put a whole new wire..
Originally Posted by
zachjf
The shielding is to block interference "to" the CPS not "from" it, if the CPS receives any electrical interference it could cause it to not relay the proper information to the PCM. My advice? redo the job with the shielding in place.
