Results 1 to 7 of 7
    Established Member Two Rings realax's Avatar
    Jul 10 2015
    los angeles
    Right dipped headlight??
    Hey guys so yesterday my xenon headlights were working great, then all of a sudden i got a right dipped headlight code. Checked the light and sure enough it was out. but when i turned the car off and back on it was fine. It comes off intermittently.
    Any ideas? Am i going to have to replace the entire headlight? Is there a simple fix?
    Any help is appreciated!
    Switch the dipped bulbs between the two housings and see if the problem moves with the bulb. If it does, just replace the bad bulb. If the error stays on the right headlight, swap ballasts between the two housings, and check again.
    2008 B7 2.0T Quattro 6MT
    Sold:
    2013 VW CC R-Line
    2005 B6 1.8T Quattro 6MT
    RIP:
    2002 B6 1.8T - April 2019
    2004 B6 3.0 - August 2018
    Feb 25 2011
    Seacoast NH
    I fucking hate our headlights
    Jul 10 2015
    los angeles
    Quote Originally Posted by A4 Quattro View Post
    good ol process of elimination! lol thanks for the tip. Driving home from work today they were just fine
    the last thing i want to do is opt for one of those cheap eBay headlights...
    Feb 24 2004
    Minneapolis
    Next time the headlight is out, leave the car running and do some diagnostics. Do you have 12 volts to the ballast? I've found the Vehicle Electric module to have a mind of its own. So before you start shopping for new headlights, do some basic electrical testing.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Senior Member Two Rings mitchell.'s Avatar
    Oct 27 2014
    Toronto, Ontario
    I had the same thing with my Xenon's. I purchased a replacement bulb over eBay and it fixed the issue. Diagnostics could be helpful but honestly if you can get a high quality bulb for decently cheap, and luckily passenger side (at least on the 3.2) is very easy to replace and doesn't require the bumper off.
    Drive On, Brother!
    Jul 10 2015
    los angeles
    Quote Originally Posted by mitchell. View Post
    thanks for the advise! luckily it is a 3.2
    do you happen to know which bulb i should look for on ebay?
