Results 1 to 16 of 16
    Apr 06 2015
    Murrieta
    Some fun comparisons between STI and S4
    Thought Iwould change the subject from all of the APR stage 3 jibberish
    My roommate just purchased a 2016 STI, and we did a couple of 20-80 pulls in Mexico =) wanted to share the results!
    stock vs stock (i had a Roc Euro intake and AWE track exhaust) , i pulled about 4 car lengths at 80
    Cobb Stage 1+ (intake and tune) vs me w/ intake/exhaust Pretty much dead even until i shift, then I pull faster 1 car length and 80
    Cobb Stage 1+ vs GIAC stage 1 plus intake and exhaust
    , i pulled about 3-4 car lengths at 80
    really cool to see consistent results with what you would expect,
    I do wish i would have seen a larger gap at GIAC stage 1 though. considering how much power I get to the wheels now.
    next test is him going stage 3 (turbo back and injectors) in December, so we will do another couple pulls. I'm excited to see the results of that!
    2013 Glacier White S4 GIAC Stage 1 / 6 Speed Manual / Sport Diff / Keyless / MMI Navi / 19's / Silver Alcantara / Bilstien PSS10's / H&R Sway Bars / Roc Euro Intake / AWE Track Edition Exhaust _____ Build Thread
    Veteran Member Four Rings skiracerblah's Avatar
    Jan 03 2011
    Evo X MR : 290whp, 313 lbs/torque @ 24psi; Evo IX : 383whp, 383 lbs/torque @ 28psi E85
    San Fernando Valley, CA
    over here in SoCal for Evo's, Injectors, fuel pump, Boost controller, ECU tune are considered a Stage 1
    Sorry for newbie questions, this is my 1st Audi
    Current: Phantom Black '2011 S4 S-Tronic Premium Plus, Sports Rear Diff, JL Audio subwoofer upgrade, Milltek Resonated Exhaust
    Old cars:
    Evo X MR-Touring stock, but tuned by RRE: 290whp, 313 lbs/torque @ 24psi 91 octane
    Evo IX tuned by RRE: 383whp, 383 lbs/torque @ 28psi E85 ethanol fuel
    Apr 06 2015
    Murrieta
    Quote Originally Posted by skiracerblah View Post
    wow! i wonder if that's because just a remap doesn't do enough?
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Techincally a stage 3 for them would be a turbo upgrade at that point. Does your room mate have a Downpipe? The sti is lighter vs out cars
    Mar 07 2015
    Central New Jersey
    Nice I raced a buddies sti from a roll as well... Beat him by about 1-2 cars everytime. Both stock
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    these outcomes sound dead on, i had same exact experience when i had my 2015 STi and ran my buddys S4
    2014 Audi S4 DSG
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    That's really impressive, since the STi is actually faster 0-60 than the S4, stock. Stock S4 (2015) is listed as 4.9 seconds 0-60, while a stock STi (2015, but probably about the same for 2016) is 4.6. If you had him beat 4 car lengths at 80, the guy doesn't know how to drive his car. There's no way the difference should be that big.
    Senior Member Two Rings roadawg's Avatar
    Jan 09 2015
    Quote Originally Posted by hotleadsingergu View Post
    Certain tests on the S4 have it as low as 4.4 to 60, you are cherry picking numbers. The S4 is a faster car period. You make it seem like 0 - 60 with one test is written as gospel. Sti's really slow down at speed, without a perfect launch their crappy torque curve, and much lower WHP they aren't really that fast. At speed the S4 will walk one pretty easily.
    Here is an example, in this one the stock S4 is almost trapping 109 mph. FF to 2:45.
    https://www.youtube.com/watch?v=Nr3YrHMuLgw
    Dec 03 2014
    Denver Colorado
    I've seen the S4 get tested consistently in the 4.4 to 4.5 second range 0-60 by more than couple of mags. Specifically, Motortrend got the 0-60 time of S4 at 4.4 for the S4 while the 2016 STI was at 4.6. The time you quote is Audi's factory conservative time (which is typical for Audi and all other German brands). I'm not surprised by these results at all.
    Established Member Two Rings paulo6's Avatar
    Apr 17 2014
    Ford Explorer, Honda Element. retired a Cobb Tuned E60 535xi for the S4
    Ann Arbor, MI
    4.9=6MT in most trade publications results
    Paul. S4 Prem+, Grey, Optic Black, Sport Diff, Nav+, BO
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    I traded my '15 sti for my S4. The S4 is definitely the faster car. With the STI I trapped between 99-103mph (stock) and between 105-109mph (stage2 protune) at Capital raceway in MD. One thing was, after shifting to 4th gear the power just dropped off because the VF was close to being maxed out. The STI was a fun car but its build quality was lacking, had horrible bucking problems in 1st gear, and the god damn rattles drove me crazy. Also, I had to get warranty work on the two pistons due to cracked ringlands. Luckily, I kept it stock for the first 6 months when it happened, but I couldn't get over the glass engine and it was ALWAYS on my mind after going Stage II.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    Mar 21 2015
    Quote Originally Posted by shoe3k View Post
    The infamous ringlands, lol. I was going to get an STI this year but they didn't change the motor like everyone was hoping. When they do change I think a lot more people will be buying them up. You throw a DP, exhaust and a pro tune those things will fly. I miss my WRX a little bit.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Former STI owner here. I absolutely loved my 2007 and legally raced the hell out of it (autocross), but I also went through the EJ257 struggle. I went through 4 motors in that car, one of which was "built".
    These results seem correct. Keep in mind though that weight plays a huge factor. A 2015 STI has a curb weight of ~3386. The S4 comes in at about 3850-3950. That's a ~500 pound difference.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Jun 11 2014
    Ny
    When I had my STI 2011, I was murdering m3s all day. I didn't keep it stock long at all, rotated turbo, equlal length headers, dp, uppipe,exhaust , professional tune. Dynoed the car at lower 400 and almost 450 tq.
    Jun 28 2012
    North NJ
    Ah ringland failures. That's the reason that I have my B8 now. My '11 STi (bone stock) got a new short block at 8,000 miles and had been to the dealer with misfire CEL's from 2,500 miles. No racing, no track. Just daily driven. Subaru bought it back after it threw another CEL 80 miles after new motor installed.
    2012 S4 Prestige - Ibis and Titanium - 6MT - MMI - B&O - Rear Parking - Advanced Key
    - Clear Bra - Vag Mods - 8500 Hardwire - Intercooler Screen - Roc-Euro Short Shifter - Eurocode Rear Sway Bar - CR-15 - Matte black rear valence - Show N Go Front Plate
    1991 Ducati 851 - 888cc High Compression Pistons - Big Valve Corsa Heads - High Flow Fuel Injectors - Open Airbox - Braided Steel Lines - Corbin Seat - Fast by Ferracci Chip and Mufflers - Carbon Fiber bits
    Hex-Can-USB in Northern NJ
    Aug 01 2017
    2017 BMW X1 2012 Audi S4
    Gaithersburg,MD
    Grave digging
    But maybe will help someone else
    I've had 3 sti (05 fbo,13 stock,16stock)
    After the 05 bought a 330i
    After 2013 sti picked up a 2011 335i
    Now I just sold my 2016 sti for a 2012 s4 dsg sport differential. Went with a 2012 cause I wanted hydraulic steering.
    I find the s4 superior every way except going into corners.
    This car keeps up with my super raw 05 sti. A car I dumped a stupid amount of money.
    Sent from my SM-G955U using Audizine mobile app
