    Lifetime fuel filter???
    Hi Guys
    I was trying to get Audi to replace the fuel filter at 45,000km service but Audi Centre Sydney insist that fuel filter for my S7 is lifetime (No need to replace) and if you change it, you may brake the fuel pump.....
    I kind of skeptical so if anyone knows more info please chime in.
    Thank you
    2013 Audi S7 - APR stage 3 & TCU tune - RS6 turbo - APR Cast downpipe - Pilot Sport Cup2 295/30/20 - KOYA semi forge 04 (10.5kg) - RS7 front bumper/side skirt - Flat bottom steering wheel - Eurocode Überlegenes Stabilisatoren System (ÜSS) & front rear end link - 034tranny mount - Avery Satin black wrap
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Quote Originally Posted by playwithonehand View Post
    Hi Guys
    Thank you
    I believe that is correct. AFIK there is no mention of replacing the fuel filter in the maintenance schedule for the A or S C7 models.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Established Member Two Rings PB4UGO's Avatar
    Oct 12 2010
    '14 A6 TDI - Previous RS4, 4.2 allroad, A4, A5
    Earth
    Quote Originally Posted by jrsAudiA6 View Post
    Unless it's a TDI, then yes.
    Thanks for the info guys, now I feel better was wondering if guys from Audi are drunk or not.
    I always fill decent quality fuel BP/Shell Vpower 93aki/98RON so should be fine for now.
    Established Member Two Rings porksoda's Avatar
    Jul 07 2015
    GTA
    Good to know.
    Fuel filter now part of the pump, sounds like designed to be costly when one or the other needs replacing.
    Maybe having it next to the pump adds benefit in detecting contaminants and or higher pressure when needed but in any case sounds like another thing that gets closed up for the end user to replace.
    __________________
    C7 A6 3.0T
    Garnet Red w Nougat Interior.
    Premium Plus w Sline
