I first noticed an odd intermittent noise about a year ago and posted this thread about it: http://www.audizine.com/forum/showth...ify-this-noise which led me to believe the noise was probably the intake manifold flapper. Well it turns out it wasn't the flapper, and the noise gradually started happening more and more often while getting louder and louder. Now, I hear a pretty loud clacking from the back of the engine every time I drive long enough to get it thoroughly warmed up. I believe the signs are pointing towards bad cam adjusters and I'm worried it could skip timing but I haven't had time to really tackle the problem so I've pretty much just had the car parked for the past 6 months or more, other than going for a short drive once every few weeks.
here's a recording I made of a cold start -
and here's what it sounds like when it's warm -
The odd thing is that there are no codes related to timing or cam adjusters or misfires at all. Looking at the misfire counters in vcds I may see an occasional misfire on a random cylinder, but it never logs any fault codes for misfires. Here is an autoscan that I saved right after recording those videos -
Code:
Monday,14,September,2015,07:31:05:18368 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 15.7.1.0 (x64) Data version: 20150904 www.Ross-Tech.com VIN: WAUPL58E34A106488 License Plate: Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUPL58E34A106488 Mileage: 244940km-152198miles ------------------------------------------------------------------------------- Address 01: Engine Labels: 079-910-560-BBK.lbl Part No SW: 8E0 910 560 A HW: 8E0 907 560 Component: 4.2L V8/5V G 0020 Coding: 0007711 Shop #: WSC 22309 444 58966 VCID: 23450E7EE192382660-5140 No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-517.lbl Part No: 8E0 614 517 Q Component: ABS/ESP allrad 3033 Coding: 04595 Shop #: WSC 06435 VCID: 3663C72A1200BD8EB7-5124 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 AD Component: A4 Klimaautomat 1319 Coding: 00000 Shop #: WSC 63351 VCID: 63C54E7EF112782620-5124 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl Part No: 8E0 907 279 F Component: int. Lastmodul USA 0517 Coding: 01013 Shop #: WSC 63351 VCID: 3561C0260F06B696BE-4B1A 1 Fault Found: 01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8E0-959-655-84.lbl Part No: 8E0 959 655 C Component: Airbag 8.4EP 3001 Coding: 0010707 Shop #: WSC 63351 000 00000 VCID: 377DCA2E450A4486AC-5140 1 Fault Found: 01217 - Side Airbag Igniter; Driver Side (N199) 002 - Lower Limit Exceeded - MIL ON ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 N Component: Lenksáulenmodul 0611 Coding: 04041 Shop #: WSC 63351 VCID: 3E73DF0A3A3075CE6F-4B00 3 Faults Found: 01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent 01303 - Telephone Transceiver (R36) 49-10 - No Communications - Intermittent 01301 - Control Module for Voice Recognition (J507) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl Part No: 8E0 920 980 M Component: KOMBI+WEGFAHRS. RB4 D37 Coding: 03200 Shop #: WSC 22302 VCID: 3663C72A1200BD8EB7-5140 WAUPL58E34A106488 AUZ6Z0C0268136 3 Faults Found: 00779 - Outside Air Temp Sensor (G17) 29-10 - Short to Ground - Intermittent 01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent 01320 - Control Module for Climatronic (J255) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl Part No: 8E0 959 760 Component: Sitzmemory R2 F 0305 Coding: 00002 Shop #: WSC 63351 VCID: 71E934363BEEDAB6A2-4B00 1 Fault Found: 01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 BB Component: Komfortgerát T7B 1411 Coding: 11852 Shop #: WSC 63351 VCID: 72EB3B3A3EE8E1AE5B-4B00 Subsystem 1 - Part No: 8E1959801 Component: Tőrsteuer.FS BRM 0003 Subsystem 2 - Part No: 8E1959802E Component: Tőrsteuer.BF BRM 0003 Subsystem 3 - Part No: 8E0959801A Component: Tőrsteuer.HL BRM 0004 Subsystem 4 - Part No: 8E0959802A Component: Tőrsteuer.HR BRM 0004 7 Faults Found: 01331 - Door Control Module; Driver Side (J386) 49-10 - No Communications - Intermittent 01336 - Company Data Bus for Comfort System 80-10 - Single-Wire Operation - Intermittent 01331 - Door Control Module; Driver Side (J386) 80-00 - Single-Wire Operation 01811 - Supply Voltage for Door Controller; Drivers Side (J386) 37-00 - Faulty 01559 - Drivers Door 37-10 - Faulty - Intermittent 01561 - Rear left door 59-00 - Can't Unlock 01562 - Rear right door 59-10 - Can't Unlock - Intermittent ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4Z7-907-357.lbl Part No: 4Z7 907 357 Component: dynamische LWR D09 Coding: 00060 Shop #: WSC 63351 VCID: 04076DE2145CDF1E79-4B1A 1 Fault Found: 01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49) 30-10 - Open or Short to Plus - Intermittent ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 195 H Component: symphony II NP2 0400 Coding: 01225 Shop #: WSC 87808 VCID: 2C57E542DC4CF75ED1-5092 No fault code found. ------------------------------------------------------------------------------- Address 75: Telematics Labels: 8E0-035-616.lbl Part No SW: 8E0 035 616 A HW: 8E0 035 616 A Component: Telematik USA1 Coding: 0005303 Shop #: WSC 22302 444 54575 VCID: 23450E7EE192382660-5140 1 Fault Found: 01531 - Emergency Battery 002 - Lower Limit Exceeded - MIL ON End-------------------------(Elapsed Time: 05:22)--------------------------
but when it's warm and making that noise, I've seen the actual cam adjustment value go as low as 8 and as high as 15 degrees, while the spec is steady at 12. Both sides vary by about the same amount. Apparently this is still not enough variation to throw a code, but I'm thinking it must be the source of the noise. So is this a case of bad cam adjusters? Or could it be something else like the timing chain tensioner? Thanks in advance for any help!
