Porcelain broke off of my spark plug(i guess recently. probably why it was misfiring yesterday) and I think it may have tweaked a valve or something to that effect causing a chatter knock sorta thing. I didn't pull the plugs since it definitely sounded like rod knock upon deceleration so I pulled my pan just to find out my bearings are good(then I found the spark plug(ngk bkr7e's)). I didn't have any metal in my oil when I drained it, but every forum I looked at there was that one guy who said he had a shot bearing with no metal in the oil...
My cam chain in good and lined up. Piston pin being loose maybe?
Any input if it's possibly a valve? It has 175psi. It was 180 a few days ago.
What it doesn't really show in the video is that it really did have a knock exactly like rod knock. It has kind of changed tones I guess. It may be that warm it sounds like rod knock and cold which is the video, it does not.
