Results 1 to 8 of 8
    Registered Member One Ring Knighthawk24's Avatar
    Sep 02 2015
    california
    Unhappy P0302 Misfiring! Help!!
    okay so about a month ago when I started my 2010 Audi A4 2.0T, it starting misfiring. At idle, RPM was about 850 and the CEL came on and after a few seconds being at idle, the EPC light came on and the shaking got worse. I connected the OBD II and it gave me fault code P0302. so I automatically suggested it was the spark plug or coil pack. Had all 4 cylinder spark and coil packs replaced, cleared the codes, turned the car on, car started to misfire again, CEL and EPC came on. When driving, sometimes it stutters when I pick up speed, but after that its running good. its only at idle that it starts to misfire and CEL, EPC come on.
    My car is around 98700k miles right about now.
    There is this kind of whistle coming from under the hood at idle. Strong suction when taking the oil cap off. I have read that the whistle might be a vacuum leak or the PCV.
    Any ideas on whats wrong with my audi or anyone else had the same problem?
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    if you only have code P0302 (cylinder #2 misfire detected); http://wiki.ross-tech.com/wiki/index...6/P0302/000770 and replaced the plugs and coils i would say you have low compression (bad rings), however it also sounds like you have a bad PCV valve (usually you get a system to rich/lean code for this). Replace that first and see what happens: http://www.europaparts.com/catalogse...?q=06H103495AC
    Stage 1 more than you RS3
    Veteran Member Three Rings schaefer921's Avatar
    Nov 25 2009
    2008 RS4 Daytona Grey Ti
    Westchester NY
    +1
    Quote Originally Posted by o1turbo30v View Post
    Sep 02 2015
    california
    Bad rings where or what is that?
    Sep 02 2015
    california
    http://youtu.be/bTIsNwLkcQI
    Here's a link of the sound my car makes. Or look me up on YouTube.
    DaV3NOM24
    Veteran Member Three Rings STA4's Avatar
    Jan 12 2012
    Mississauga, ON, Canada
    I recently read that you can spray brake cleaner around suspected leaks. If the engine idle changes, then you have found the location.
    Another potential problem is a sticking injector.
    Also, please only create a new thread when necessary. You already have a thread about this problem (http://www.audizine.com/forum/showthread.php/666738).
    Peter
    2009 A4 2.0T Quattro Premium 6MT
    Meteor Grey/Black | B&O | STaSIS Tune/Exhaust/Springs/RSB/Wheels | K&N Filter | Eurocode TIH/HFIP/IHK/HFC/Alu Kreuz | GFB DV+ | R8 Coilpacks | Strat O2 Spacer | BFI OCC | Podi Boost Gauge | Rieger Rep Spoiler | RS4 Rep Grille | A4L Foglight Grilles | LED Interior/Puddle/Plate/Signals | Morimoto 5500K HID Foglights
    Veteran Member Three Rings Jacon's Avatar
    Jan 05 2009
    B8 A4 6MT P+
    Ft Worth TX
    Quote Originally Posted by STA4 View Post
    Is it just me or why does brake cleaner generally sound like a bad idea?
    My current rides...
    Audi
    Jetta
    Jan 12 2012
    Quote Originally Posted by Jacon View Post
    Good question. I assumed that in small quantities the non-chlorinated cleaners would be okay.
    Here's an example of the ingredients:
    Acetone 45-55%
    Toluene 25-35%
    Methanol 10-20%
    Carbon Dioxide 5-10%
    I just did some more reading, and supposedly brake cleaner is bad for rubber and plastics, so perhaps stay away. I also read someone using propane from a propane torch... http://www.ehow.com/how_12170503_vac...k-propane.html
    Peter
