Results 1 to 14 of 14
    Veteran Member Three Rings jamesj2k's Avatar
    Feb 17 2008
    Ashland, KY
    Question Exhaust smells bad?? (outside only)
    Noticed that over the past 10 days my exhaust (outside) smells different then I remember. More potent and"stinky".
    I don't smell anything inside cab, just outside after I park and get out of car.
    Any ideas?
    2019 SQ5, 2021 Q7
    Veteran Member Three Rings brainpan's Avatar
    Apr 11 2010
    sk8 banana
    ontario
    Bad cats maybe
    Sent from my Note 5
    Bryan
    Nov 13 2014
    Wife's MK7 GTI
    Land of Gold Chains, NJ
    Bad cats smell like rotten eggs... Most likely the problem
    2015 S4 / Ibis / DSG / Prestige / Sports Diff / ADS suspension
    Mods: CR-15 strut bar / EC sway bars / EC end links / Alu Kruez / 034 trans insert / AMS heat exchanger kit / ECS intake / SPC upper control arms / APR stage 2
    B6 A4 / 1.8t / stage1 / coilovers / sway bars : Sold
    1987 Buick Turbo T / Big Turbo / so fast, the motor was strapped to the frame Sold
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    I dont know about rotten eggs but if you have ever been by a catless car you would know.
    2013 B8.5 S4 | APR Stage 2 + DSG Tune | APR CPS | AWE Touring + Downpipes | RocEuro | H&R Coils | J-Codes | 15% Tint |
    435I 6MT - Daily
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Sounds like bad cats...
    Veteran Member Four Rings q5 dave's Avatar
    Dec 15 2014
    2016 F250, 2018 Q3
    driving
    Quote Originally Posted by B8 S4 View Post
    would smell like a gas station
    2013 Q5 3.0T Phantom Black
    1998 A4 1.8T Laser Red, Quattro, 5 speed manual
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Is there any color to the exhaust? If something new were burning up, like oil or coolant, you would likely see smoke of some sort. If you're exhaust is still clear, i would agree with the cat suggestion.
    2021 Audi S4, P34 Intake
    Dec 03 2008
    2018 SQ5
    E85 will also change the smell of your exhaust
    Feb 17 2008
    Ashland, KY
    Color looks normal. Definitely not like bad eggs. Smells different then normal gas station "smell". Filled up with shell 93 and still same smell. I guess If I had toe explain..it smells like nasty un-refined gas f there is such a smell
    I think I am still under my CPO warranty. Is cat converter covered under usual CPO warranty (my dealer should be TD1 friendly If I'm flagged).
    2019 SQ5, 2021 Q7
    Feb 17 2008
    Ashland, KY
    I also experience no los sof power or acceleration issues. Nothing seemed to have changes but the smell. I will get under the car and check it out later today. Wonder is there may be data from "road debris".
    If not damage, I will give the dealer a ring.
    Any other ideas?
    2019 SQ5, 2021 Q7
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Quote Originally Posted by jamesj2k View Post
    The cat isn't covered under CPO, but it would be covered under the Federal emissions warranty (8 yrs/80,000 miles) if it were malfunctioning.
    Feb 17 2008
    Ashland, KY
    Ok...new info. Just went outside. Temp is about 58 degrees. No damage noted under car.
    The drivers side exhaust is a lot smokier (no smoke from left exhaust pipe) and that is where the bulk of the smell if coming out of.
    Are we pretty sure its the left (driver) cat converter at this point?
    2019 SQ5, 2021 Q7
    Feb 17 2008
    Ashland, KY
    UPDATE:
    The exhaust was smoking because it was cool and warming up. Its ok once it warms up.
    I am taking it to the dealer for possible rear diff. fluid leak. The fluid leaks on back of exhaust and is the culprit of the smell.
    2019 SQ5, 2021 Q7
    Feb 17 2008
    Ashland, KY
    Probably my final follow up on this...I think I figured it out. I am finishing up this post for future members in case this arises.
    I always use to carry a spare quart of oil in the spare tire compartment. The bottle of oil for some reason leak inside and dripped out the back of the car where the spare tire compartment is. I am 99% sure that is what caused the bad exhaust smell. Saw dealer and they noticed some "grease sweat" around the axle but it was "normal".
    I hope that's all it was.
    2019 SQ5, 2021 Q7
