Another issue is that there is oil dripping from the bottom of the coil packs, however I cannot tell if it is just from the filler cap or not..
I just recently did my valve cover gaskets & everything appeared fine, my passenger side valve cover is completely dry.
Idk if something went wrong with the spark plug gaskets or if I somehow put them on wrong; I will be removing the coils soon to see if there is oil inside or if anything is wrong...
I got some photos of the leak...
You can see at the base of the filler cap oil is seeping out
Here are the leaks at the bottom of the coil packs...
I have not found anything online on how to remove the "housing" to the actual oil cap... If you have taken it off please let me know how..
Thanks
