Results 1 to 40 of 45
    Active Member One Ring Ablankoff313's Avatar
    Nov 21 2012
    2018 A6 2019 Ford Raptor
    San Francisco Ca
    When is everyone doing Oil Changes???
    Hey everyone! Wondering if everyone is changing their oil every 5k or 10k. I know audi says 10k - but was just wondering what others are doing!
    2014 s4
    Established Member Two Rings Mike'S4's Avatar
    Sep 01 2015
    Northen VA
    When I got my 15' S4 I went ahead and got the Audi care to cover my first 4 services, just got the 5K done, they reset my service interval to come back after 10K 15K total. I guess I don't have enough experience with this engine to give you a good answer, my plan is to continue with the Audi care and after service every 10K with the mobile one 15K extended performance full syn.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I use full Amsoil fluid @ 10K with filter changes every 5K.
    Apr 05 2012
    Earth
    Whenever the info display says that it's time for servicing.
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    I haven't had my first one yet but I plan on doing it every 5k. Why? Because Race Car. IMO 3k was always too soon and in todays more modern engines I think 5-7k is good. Been doing 7.500 on our minivan since 4k on the ODO it's at 100k now and all is great.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Veteran Member Four Rings jl87's Avatar
    Jul 25 2010
    WI/IL
    Full change/filter every 5k with Motul.
    Aug 15 2014
    Quote Originally Posted by jl87 View Post
    same
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    Every 3000 miles, Mobil-1 0W-40
    Established Member Two Rings Justin R's Avatar
    Jun 07 2014
    Del Boca Vista
    every 5k
    2014 S4
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    every 5k
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Three Rings Francois's Avatar
    Mar 26 2007
    Montreal, Canada
    Same in Kilometres (5k) instead of Miles means 3100miles
    MontrealAudiClub membre #3
    S4 Premium 2011, 19", Meteor Grey, 7 speed dual clutch S-Tronic, black Napa, MMI, black optic, advance key, advance parking system with camera, side assist and more.
    Previous: TT S-Line 2012, Mag Ride / A4 Sport Package 2003.
    Oct 31 2010
    Lafayette, Colorado
    Quote Originally Posted by Shimmy View Post
    same
    +1
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    Every 3k, oil and filter.
    Summer time = Rotella T6 5w-40
    Fall, winter and spring = Castrol 0w-40 or Mobil 0w-40 whichever is on rollback @ walmart.
    2018 Carrara White Audi Q7 3.0T P+, Cold weather package, Vision package, Warm weather package, Driver Assistance package and towing package
    Stock
    2016 Mythos Black Audi S3 P+, Black Optics Package, Tech Package, LED Lighting Package, B&O, Red Calipers
    Modded
    2001.5 Brilliant Black Audi S4 Sedan 6MT
    Stage 3
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    every 5k. 3k is way to soon unless your beating the piss out of the car every day. There is enough volume of oil in there to warranty 5K oil change even with beating on it. a normal 6 cyl holds 5qts. Ours holds 9qts. Thats 4 more than a conventional engine. I will do mine every 5K. I was going to get audi care but i think theres a time limit on it as well. I will run out of time on the plan over milage. I only put about 8-9K a year on the car. Someone else can confirm but i thought i saw that audi care had a time limit on it as well.
    Veteran Member Three Rings tanklee's Avatar
    Dec 31 2004
    NJ / Miami
    oil change and pollen filter change every 5k miles. but i only reset the service light every 10k miles.
    2000 B5 A4 Quattro
    2000 B5 S4 6spd Stage 3
    2014 B8.5 S4 DSG
    2005 B6 A4 Quattro USP
    Dec 07 2014
    Mn
    5k
    Sent from my HTC One_M8 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
    Jun 26 2012
    Rockford, il
    Holy s%t you guys are a wasteful bunch. Why do it so early when Audi recommends 10k. There's no reasoning behind it, Audi invests millions in they're engineers. It's not 1980 anymore so 3k-5k is an overkill. Modern oils and engines are far more advance to go beyond 5k, just my .02 cents tho. This subject's been beat to death . . .
    Jul 21 2004
    South Florida
    10k miles for normal duty on a VW502 oil.
    Mike
    2018 Audi S5
    Gone-
    Mar 21 2015
    O
    Quote Originally Posted by chaos2984 View Post
    Your's holds 9 qts? I hope your not putting 9 in it.
    Audi care is 12 months or 10k miles. Whichever comes first.
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I'm going to do my first oil change next week around the 7500k mark. I'm planning on sending a sample to Blackstone to get tested. If it looks good, I'll go to 10k and see what it looks like.
    2021 Audi S4, P34 Intake
    Mar 21 2015
    I just sent one in with 5500 on it and everything looked good and they recommended I go 7500 on the next. It was my first sample so nothing to compare to.
    Jul 16 2012
    Mid-Atlantic
    Quote Originally Posted by Fociracr View Post
    10k only came into effect after car companies started paying for scheduled maintenance. Look at all of the sludges 100k BMWs that were a child of the first free maintenance programs.
    10k is probably fine. But for 60$ every 5k, it's peace of mind to me.
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
    Veteran Member Three Rings neubs's Avatar
    Nov 07 2009
    SOLD: 2005 B6 A4 TQM 6 Sp
    Washington, DC // NoVA
    Audi Care "expires at 57,000 miles or five years from the original vehicle in-service date, whichever occurs first." -- this is for the 5/15/25/35/45k "non-select" plan. So yes, the standard plan can expire.
    There are the Audi Care Select plans, which have different parameters.
    -Eric
    New: 2014 Ibis White S4 -- 6 Speed, Sport Diff, ADS, B&O, Black Optic Package
    Sold: 2005 B6 A4: APR II+
    Jun 26 2012
    Rockford, il
    Quote Originally Posted by Works2shoot View Post
    Free maintenance programs have nothing to do with this. I've had early 2000 VW TDI's, VW at the time recommended 10k oil change intervals. I used to commute alot for work so by the time I sold it it had 318k miles on, there would be times where I wouldn't do an oil change for 15k-18k miles, and I had an oil analysys done around 250k miles and it came out perfect and this was actually done with the engine oil being at 12k miles. And this was done on a diesel engine which "looked" dirty 50miles after you did an oil change. Now i wouldnt recommend doing this but it's held me over the years, I dont do nearly as many miles in my S4 so I can/have the time of day to do the 10k miles oil service.
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    While interesting you cannot compare diesel engine oil change intervals to gas engines as diesels have always had longer intervals...impressive though that you went 318k on it....my buddy picked up a jetta TDI a few years ago as he commutes over 150 miles per day and loves the milage it gets
    [B]Current: Shopping now....
    Jan 14 2009
    pasadena md
    O
    Yea whoops. I was thinking of my B7. I haven't changed my oil yet. Im getting ready to. The dealer did my first one for free. yea ours hold a little over 7 qts.
    But yea For normal people and how we "normally" drive the car I would say 5K is a decent starting point. But realistically anywhere from 5-7500 is fine.
    But back to increased oil change interval. They have only increased it a lot because the engine can hold more oil than a typical engine that same size. And requires synethic. But yea has to do little with who was flipping the bill. But not that much. I think BMW was 15K was it not. But some companies employed that philosophy since they were paying and stretched the oil changed out but didn't up the quality of oil and volume of oil. Look at GM prime example with their oil change life monitor. Talk about dumb. If you listen to that your engine wouldn't last 100k. If it did it would hate you severely. Most of their engines wouldn't have any oil left by 7500 due to oil consumption.
    But it you drove the car truly normal it would probably be fine for 9-10K oil change.
    Established Member Two Rings flixman_420's Avatar
    May 21 2013
    Los Angeles, CA
    5k
    2013 S4 Estoril Blue / DSG / Sport Diff / MMI with Nav / Advanced Key / CF Atlas Inlays / Black Napa Leather / 19" peelers powder coated matte black- Returning to AUDI
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    I do mine every time the service indicator comes on. I do need to add a quart in between depending on how I drive. use 5w40
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Jun 26 2012
    Rockford, il
    Quote Originally Posted by k9lovr View Post
    Honestly If i could pick a cheap TDI right now i'd make it my DD, those things are bullet proof. If you do the timing belt, water pump every 100k and change the oil those things will run forever while returning 50 MPG. I have buddies that have TDI's with well over 400k miles without any issue, clutch, wheel bearings etc., amazing cars, proabably the most reliable engines VW has made.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Every 5k, and I have AudiCare.
    The dealer did my 5k and 15k oil changes. Like most Audi dealers, they use Castrol 5W-40 Synthetic. I don't have a problem going 10k on a quality oil, HOWEVER, Castrol 5W-40 has been proven not to last 10k miles without negative affects. This has been proven using Blackstone oil reports.
    I'm at 20k now, and I just did a change myself using a Mann filter and Motul Specific 5W-40. I'm sure it's partially the placebo effect, but I swear my car runs much better now and the engine is far smoother.
    I will be going back to the dealer at 25k for an AudiCare change, but I'll likely supply them with my own Motul oil.
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Jan 14 2009
    pasadena md
    Quote Originally Posted by Acejam View Post
    So if your changing the oil every 5k then y does it matter what the dealer uses. Im sure castrol can last 5K easily now with the reduced interval. If you paid for audi care then why not get your money out of it? The only thing i can think of is that you will get your money out of is if it's a DSG for the 35K service. will pretty much cost about 85% of what audi care costs.
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Every 5K
    Ducati gets 3K
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Once a year for me that would be 6 k miles. In fact audi tech asked me during my first service if I was goiing to go 10,000 miles between changes. He did NOT recommend that. I told him. once a year which would be about 6K miles
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    My S4 has 31K but for the first 25K, I changed oil @ 5K intervals using dealer's supplied Castrol OE synthetic oil 5W-40 (Audi Care) and samples sent to Blackstone. Finally, after the 20K oil change all deposits dropped drastically. Blackstone suggested 7500 miles interval but I'm going the full 10K for the first time too see what happens.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Apr 04 2012
    MSP
    5k
    Oil => life-bllood of a car. Change often and regularly for best protection.
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    At Audi recommended intervals, which for me is every year, as I never drive more than 10,000 miles per year.
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Jul 12 2013
    8V S3 and B5 S4
    Old Bethpage, NY
    I do the 3k due to NYC traffic. I sit in so much traffic I'm sure the hours of engine operation with my car idling in stop and go traffic adds to the 3k miles.
    Stock
    Modded
    Stage 3
    Veteran Member Four Rings shadycrew31's Avatar
    May 27 2013
    West Chester, PA
    I do every 5k because it makes me feel good inside.
    Jan 09 2008
    Winnipeg
    Every 7500 km for me. Have had the car less than a year (bought it used). Did my first oil change late June using Mobil 1 0W40 then went on a 10 day long road trip putting on almost 5000km. Car went in for it's 100,000 km Audi Care yesterday and got their oil. I will stick to 7500 for the life of the car unless I start hating it which is unlikely. I like the Mobil 1 oil and didn't have to do any top-up in between. Prior to doing my first oil change I had to add a bit but my car then had the fuel rail recall service done and they did the thermostat and PCV at the same time. So I assume the little bit of oil I lost was due to those components and not the oil...time will tell.
