Results 1 to 12 of 12
Thread: Gurgling sound
    Junior Member Two Rings
    Jun 18 2013
    Waynesville, OH
    Gurgling sound
    Just picked up a new RS7 (Nardo) about a week ago. Great car! When stopped (parked/at a light, etc.) , I can occasionally hear a sound like water running through a hose/piping form the dash area - sounds like coolant passing through lines. Doing a web search - seems like this can be caused by air in the coolant and system may need to be "burped"? Anyone hear this sound with theirs? I guess air could easily be in the system from the factory fill - all through have never heard this on another "new" car before.
    Veteran Member Three Rings Calimus's Avatar
    Oct 26 2010
    88' Scirocco, 89' Cabriolet, 16' A3 E-Tron, 05' FJR1300
    NW Georgia
    I'm assuming that you have the stop/start feature on the RS and that the engine cuts off when you are stopped and thats when you can hear the sound. If so, that is the cooling system, but most likely not because it needs to be burped, but the fact that electric pumps continue to flow the coolant to your turbos so that that they don't cook the oil that sitting in them when the engine stops. My 02' A6 2.7t did the same thing (had to replace the secondary electric pump once, what a pain).
    William
    12' 3.0T A6 Prestige - The white whale
    02' 2.7t A6 - Gone but not forgotten
    Senior Member Two Rings InvigR8's Avatar
    May 18 2009
    Audi R8 (2017 V10+, 2008 V8), RS 7, B8 A4 Avant, A6 Allroad 4.2, C6 S6 5.2, Ur Quattro
    Los Altos, CA
    I hear a water flowing like sound in my '14 when I am stopped at a light with my engine still on (no auto start/stop), but not a bubble or gurgle like noise that suggests air to me, FWIW.
    Senior Member Three Rings S6Express's Avatar
    Jan 14 2014
    Miami, FL
    My 2013 S6 does this too. Dealer said they fixed it, but they didn't - it still does it. Sounds like water running through a faucet.
    2013 S6
    Ibis White / Black Int / Innovation / Bang & Olufsen / LED Headlights / Carbon Inlays / Black Headliner / Sunshades / Cold Weather
    Mods:
    HRE P47SC 21" x 9.5" Wheels / RS7 Rear Diffuser & Oval Exhaust Tips / Red Bembos / Bigger Rear Spoiler / Dead Pedal S6 Badge / Black Wrapped Grille Slats / Black Wrapped Grille Edge / Black Window Trim / K&N Drop In / Escort Max360 Hardwired w/ Remote SmartCord / VAG COM Mods / 35% Tint
    Jan 02 2013
    CA
    Quote Originally Posted by broudav View Post
    Had the same thing on my 2013 S5. Convinced myself it's most likely normal, so never had it looked into. Even if not normal, seemed like any "cure" would quite possibly be worse than the disease. I try to avoid having mechanics mess with my cars unless really necessary.
    Feb 26 2010
    Los Angeles, CA, USA
    Quote Originally Posted by Calimus View Post
    The 2016 RS7 does not have start/stop feature in the USA
    May 31 2014
    Denville New JErsey
    Quote Originally Posted by chucky0731 View Post
    I have a 2015 RS 7 I hear the gurgling sound behind the dashboard also. It is not the radiator coolant. It is the water discharge from the AC condenser which is right behind the dashboard. If it was winter than it could be the heater core but I hope nobody has their heater on now. You would be surprised how much water flows out of the AC.
    Jun 18 2013
    Waynesville, OH
    Thanks to everybody for the responses. I got in touch with the Audi master tech at my dealer today and he said the following [quote]: "That car runs an aux water pump along with the water pump on the engine block. If there was a air pocket in the system you would be having an over heating condition. I wouldn't worry about it. There are a lot of coolant lines behind the dash. And they all have their own actuator that will let the coolant flow. And they open up at different times depending on being stopped or moving or temperature. It's a new coolant system they have, helps keep inside warm using less energy and helps keep engine block at a normal temperature. It's a pretty cool in depth system." Of course I'm not using the heater now - but sounds as if the noise (like water flowing around) is normal enough not to worry about it and luckily overall minor.
    Dec 24 2014
    No. VA
    Good thing I read this post. I have 2012 A6 3.0T, I have the same running water noise behind the dash when the car is idle, with fan speed running at low speed like 2-5... I thought about bring it in to the dealer since I have another 8 months of factory warranty left. I am a little hesitant to go to the dealer and have them take the dash apart. I guess I feel better now that this is somewhat normal :-)
    Jan 02 2013
    CA
    I wonder how long all this is expected to last before something goes bad, and then how do you even get there to fix things without tearing apart the car...
    Oct 26 2010
    NW Georgia
    The Aux water pump in my 02' A6 lasted 11 years and they had it in the valley between the heads, which is pretty much the worst place to put it heat wise. I haven't dug around in the engine bay too much in the C7 just yet aside from oil/filter/spark plug changes but I need to to locate those. However, with better engine design, more heat extraction and such, I'd say the pump should last on average 10 years. Though as with anything YMMV
    William
    Dec 24 2014
    No. VA
    I thought I should share this. I had the same issue with the running water noise behind the dash. It sounded like my home AC unit when the freon was low. So, that gave me the idea to check the refrigerants (R134a) with those off the shelf refilling kits from Walmart that shows the pressure reading. My was a tad low, so I added a few pump of the R134a to bring the pressure up to the higher end of the 'FILLED' zone on the gauge. The noise seemed to have diminished right after. So, not scientific proof, but it worked for me. Figured it doesn't hurt to try and it's pretty low cost ($20).
