Originally Posted by
Mad Cow
You might have to flash a 6 speed bin to the ecu, that's how it works with the 1.8t at least.
I have recoded several B6 1.8T ECUs from Auto to manual trans and vice versa. If the ECU could not be recoded for Manual trans, requiring a MT bin, there is no reason to include that function in the coding number. The AMB bin file is not specific to auto trans or manual trans. The same ECU part number is used with both transmissions.
OP, try logging into the ECU with Login II before trying to recode the ECU. Use login value "32767", then recode ECU 0016711. Next turn off ignition for 15 seconds. VCDS will not show the new coding value until the ignition key is turned on again after 15 seconds. Also, depending on the software version, the coding number may require one or two leading zeroes. Without the leading zero/s, the coding value won't be correct. Note the two "empty characters" 00 leading zeros shown in the coding chart. If you did not include the leading zeros before, try doing that before using the login step.
