Results 1 to 12 of 12
    Mar 18 2015
    2015 GL450
    IL
    Where is the lug nut cover tool?
    I know this is a dumb question but I can't find the darn thing. After anyone does anything where the wheels had to be pulled I always drive a few hundred miles and then pull out my torque wrench and make sure the lugs are all torqued properly. Maybe I'm paranoid but I like to be careful ever since I saw a guy lose his entire front driver's side wheel while diving.
    If someone could post a picture of where it is in the trunk kit it would be very helpful.
    2016 S5 6MT - Brilliant Black, P+, High Gloss Black, Sport Dif, B&O, Tech, Nappa
    Engine: GIAC Stage 2 & SC Pulley / ECS Carbon S-Flow Intake
    Suspension & Wheels: H&R Street Performance Coilovers / Vorsteiner VFF-103 (Carbon Graphite)
    Exhaust: AWE Touring
    Cosmetic: OEM RS5 Grill / PPF & CQuartz Finest Coating / 35% Pinnacle Tint
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    It is a wire hook device that is in the Styrofoam tool holder in the trunk under the spare tire (I think). Easy to loose.
    Veteran Member Three Rings S4V8's Avatar
    May 19 2010
    It's a plastic pincher like tool, found in the trunk. If you have lost yurs, just get one from the dealer...they stock them. Not expensive.
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    If you lost yours just get a wire clothes hanger and cut the top hook piece off. I keep one in my glove box especially since it takes a lot more time to remove things from my trunk (including the spare tire) to get to the OEM center cap puller.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Mar 18 2015
    2015 GL450
    IL
    Yeah, it's the little plastic one. Either my detailer forgot to put it back or I'm blind because I can't find an obvious cut out that is missing it. Found the wire one, no problem.
    Sep 28 2010
    NW NC / DE
    @NPuter Where did we find yours? I remember it was not in plain sight.
    Oct 27 2009
    Miami, FL | Boone, NC
    Yea OP, look under the whole styrofoam tool holder if you can't find it - mine was just sitting between it and the metal trunk floor.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Mine wasn't included when I bought the car. I ran down to the dealership and picked one up. It's about $8 after tax.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Oct 27 2009
    Quote Originally Posted by HazeMyth View Post
    If your car came with wheels that use lug caps, the car is supposed to come with the tool. They should have just given it to you.
    Nick NPuter
    RS6 | S5 | A4
    flickr | instagram
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Mine was in the glove box
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Nov 10 2014
    Apex, NC
    mine was in the wheel lock case
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Jul 17 2015
    Colorado
    They're supposed to send me one, but I had a project where I had an immediate need for it, so I also bought my own. My spare is just going to sit at home in my toolbox, just in case the one I keep in my glove box ever gets lost.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
