Results 1 to 14 of 14
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Anyone use a magnetic oil drain plug?
    Hey folks,
    I have 20k miles on my car now and I'm going to do an "in between" [AudiCare] oil change today. When i bought my oil and filter, I also ordered a magnetic oil drain plug from EuropaParts. Does anyone else use a magnetic plug? It came with some copper washers, but I also ordered an OEM washer in case I just decide to re-use the OEM plug.
    Given my car is bone stock, I was also wondering if anyone has ever encountered any warranty issues with using such a plug.
    I have this: http://www.europaparts.com/magnetic-...metalnerd.html
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Established Member Two Rings goosedat's Avatar
    Jul 05 2011
    Woodinville, Washington
    Save your money. Those drains really are not going to catch much. Just ensure you are changing your oil frequently. It all depends on how you drive it (i.e. hard or normal). City driving (lots of stop and go's) highway driving (more longer drives where the car gets up to temperature and is not sitting around). For me I change my oil every 3k, because of the way I drive it. I use Motul 5w40 personally, but any top tier oil synthetic will do.
    2000 Audi B5 S4 stage 3: AMD tuned, PJK04's, RS4 inlets, EV 14's #52 injectors, AWE intercoolers with shrouds, KW V3 coils, SPC adjustable arms, AMD stage 1 clutch, Raxles, Brembo 355 front BBK, Apikol 300mm rear brake upgrade, Carbotech XP8 brake pads, Bosch 044 pump, Apikol rear diff mount, Stern engine mounts, APR bi-pipe, Milltek downpipes and cat back exhaust, Escort Redline radar (KA segmentation 2,5,6,8, lasar on, RDR off, SWS off, TSR off, POP off, X band off)
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    If the manufacturer wanted a magnet in there they would of put one in there. Most automatic transmissions have one in there from the factory stuck to the bottom of the trans pan. But while it won't really help or hurt you. There's really not a need for it in an engine. The metal that does float around the filter will catch it and its so fine it will not damage the oil pump anyways. The only way i see it helping you is if you have a cam or main bearing problem. But at that point the drain plug isn't going to help the problem.
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    I bought one, it's a magnetic drain plug on a a mostly aluminum engine.. kind of pointless tbh save your money
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Nov 29 2013
    Silver Spring, MD
    I got one from ECS as part of their oil change kits, to perform them in between scheduled services. Good to know that won't do much, because it would probably get tossed by the tech anyways.
    2017 BMW F80 M3 | Mineral Grey | BBS FI-R | AWE Non-resonated Exhaust | M Performance HAS | Ceramic Pro
    Gone but not forgotten: 2014 S4| Phantom Black| BBS CI-R Platinum Silver 19 x 9 ET 42 | 3M Crystalline 40 Tint | Opti-Coat Pro | Bilstein Coilovers | SPC UCAs | EuroCode ÜSS Sways/Links | Alu Kreuz | Roc-Euro | 034 Trans Mount | RS5 Front BBK | ECS Street Shield | AWE Touring 102s | AWE ColdFront | RS4 Grille
    Jul 05 2011
    Boca Raton, FL
    You need to be careful with those drain plugs that have the magnetic section in the center...I've had those come out and leave the threads behind when unscrewing the drain plug.
    A quick oil change turned into hours of knocking threads out
    2016 B8.5 S4 P+ - 6MT, Misano red pearl, black/black interior, fully loaded
    Apr 04 2012
    MSP
    I'm running one.... because why not - it is dirt cheap and maybe will catch a piece of metal some day lol - for 10 bucks why wouldn't you?... That being said - I'm not expecting much... This is the one I got - http://store.034motorsport.com/oil-d...-14mmx1-5.html
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    I have one but have never used it, why, I don't like the washers that came with it. I like the crush washers better.
    Jul 16 2012
    Mid-Atlantic
    To answer your other question - changing a drain plug should not affect your warranty.
    On another note - I have to say, the TD1 hype has seriously gotten out of hand if Audi has its owners scared of using non-OEM drain plugs.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Quote Originally Posted by Works2shoot View Post
    Lmao
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Mar 21 2015
    I thought i remember reading that ecs drain plugs were leaking
    Dec 22 2009
    MA
    Update: I changed my oil today but ended up re-using the OEM drain plug with a new OEM crush washer. I have also read that the ECS ones strip and leak very easily, but I have a MetalNerd/Europa one. (Which is now just going to sit in my tool cabinet)
    Aug 15 2014
    I ran one before and it never really made any difference. I now use an extractor for oil changes, so I just stick with stock.
    For Sale: Mini Part Out
    Jan 14 2009
    pasadena md
    Quote Originally Posted by Usa View Post
    Do what? The bearings for the engine are metal. The crank is metal. The rings are metal. The cams are metal. All the lifters and rockers are metal. The engine housing is all aluminum and the rods and pistons. But most of the moving components are metal bud. If you have the block or head or oil pan coming apart you have a bigger problem.
