Results 1 to 2 of 2
    Registered User Four Rings GMP Performance's Avatar
    May 11 2009
    Charlotte, NC
    NEW RELEASE Audi R8 V10 Fabspeed Exhaust | R8-Rated Sound At the Push of Button!
    Enjoy all the benefits of Fabspeed's world-renowned Supersport X-Pipe Exhaust System, now available with more power and sound at the push of a button! Maximum gains of over 24whp and 18 ft/lbs of torque with full V10 exhaust sound!
    Fully-controllable Valvetronic catback exhaust system includes a quad-resonated center x-pipe section which controls exhaust volume while the valves are closed. When the valves are opened, the exhaust exits straight out through the dump pipes for maximum sound and power.
    Fabspeed's Valvetronic Supersport X-Pipe Exhaust for the Audi R8 V10 offers...
    Significant Real-World Power Gains
    Quantifiable horsepower and torque improvements that you can actually feel all the way from 3000 RPM up through 8000 RPM. With gains of over 24 whp and 18 ft/lbs of torque at 7000 RPM, the Fabspeed Supersport gives the R8 V10 the power that it deserves.
    Lightweight Design & Construction
    Weighting in at only 43 lbs, the Fabspeed Valvetronic Supersport saves you 38 lbs vs. the factory muffler. This equates to a significant reduction in exhaust weight, lightening the rear of the vehicle and improving acceleration and handling.
    Sound Control At Your Fingertips
    The Fabspeed Valvetronic Supersport gives you full control over the tone and volume of the exhaust simply by selecting Open or Close on the included keyfob remotes. Set the valves to the Closed mode and enjoy a sophisticated exhaust note which still turns heads without waking up the rest of the county. Switch into Open mode, and revel in a full-out assault on the senses as the ferocious V10 screams straight out of the 70mm bypass pipes.
    Premium Materials & Craftsmanship
    Fabspeed has been a leader in premium stainless steel performance exhaust systems for over 20 years, and the R8 V10 Valvetronic Supersport Exhaust is no exception. Crafted from polished T304L stainless steel and beautifully TIG welded for a show-quality finish, the Fabspeed Valvetronic Supersport Exhaust is a piece that you'll want to show off for years to come.
    Industry Leading Support
    As with all Fabspeed performance products, the R8 V10 Supersport System is backed by a Lifetime Limited Warranty. Fabspeed's experienced techs and engineers are standing by to assist with any comments or concerns.
    Contact us directly at [email protected] for pricing and with any questions or concerns.
    May 11 2009
    Charlotte, NC
    All PM's replied too.
