Originally Posted by
namvar
Please elaborate.
OK, so no single modification can broadly void your car's entire warranty. If you were manually flagged "TD1" by your Audi dealership due to an intake (which seems to be fairly rare), then Audi would simply review any powertrain claims more closely.
For them to deny a claim, the failure needs to be a direct result of the aftermarket part. They CANNOT simply blame any engine issue on your intake. For example, if you had a coil pack failure, PCV failure, timing issue, etc... those couldn't be blamed on your intake and would be covered. However, if a foreign object or large amount of sand, etc... was ingested through the intake path and caused engine damage, they could certainly deny the claim as the aftermarket part played a direct role in the failure.
It may be wise to consult your service advisor if you are concerned as this is something that the dealer has direct control over- a technician would need to manually enter the intake into the computer system and send it to Audi for you to be flagged TD1. I think this is a fairly rare thing to happen. I've seen a few cases of it occurring on the S4 forum but many/most there leave their aftermarket intakes on for service and never have any issue.
Also, another option is to re-install the stock intake prior to any warranty work being done if your dealership is not mod-friendly. I'm not sure how difficult this is on the RS with the dual intakes, but it takes ~10 minutes on the S4 and may be worth it if you're not visiting the dealer often.
