Results 1 to 25 of 25
Thread: Custom intake
    Jun 26 2012
    Rockford, il
    Custom intake
    So I decided to make my own custom intake for my S4. I couldn't justify spending $200+ on a tube with a filter. I don't really care for any crazy HP gains (HP gains are negligible with intakes) anyways, I just wanted to hear the supercharger whine more. Well I added a pic so you guys can see what it looks like. It cost me roughly $50 to make give or take, so for a quarter of the price I'm ok with it. I know people are going to bitch about how I could do this to a $50k car but I like it. Let me know what you guys think. I'm still a noob to uploading pics to forums so you'll have to copy and paste the link.
    http://s1108.photobucket.com/user/Fo...7.jpg.html?o=0
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    I think it looks fine. Sucking in hot air but I'm sure you don't care about that.
    Edit: Id watch that fuel line or wrap it to protect it from that pipe.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Jun 26 2012
    Rockford, il
    Thanks bud. Well I initially installed the cover and it was very quiet so I put a few holes in it. I have a multi meter that measures the temperature of the ambient air with a wired probe. I ran that probe to the actual box before and after I drilled the holes and the temp when driving is exactly the same, it only gets slightly hotter when sitting. As for the fuel line I'm planning on maybe wrapping the intake with some sort of exhaust wrap but I'm sure it'll do more bad than good. I'll have to find a clip and simply clip it to it. like the stock one.
    Oct 19 2014
    PA
    Quote Originally Posted by Fociracr View Post
    A few holes, you mean like 22? :) Kudos to you for coming up with your own ideas. So how's the sound/whine now?
    Jun 26 2012
    Rockford, il
    HaHa well I started off with a handful but ended up with "22", the sound is fantastic not as loud as with the cover completely off but loud enough to echo when going under a bridge, its not cobra terminator loud but loud enough. I might make another cover without holes for the winter just in case.
    Aug 25 2013
    florida
    details on the cover? mounting points, how you made the joints, how many sides are closed, if you decide to box the filter in if it isnt already?
    2014 sfeux p+ 6mt bo nav w/o sd
    Nov 23 2014
    North Carolina
    not bad honestly. I agree about wrapping the rubber hose, and make sure there is no contact on the metal pipe (AC line maybe?) underneath. I don't care for shiny though under the hood, so I'd personally paint it a matte black but that aside, I'd just enjoy
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Looks great! I wish I would have gone this route! Someone should find a Honda kit on eBay that has perfect size tube for our car.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    What filter and pipe size are you using? I would definitely log IAT's, air mass, and air pressure to see what it is really doing if you care about its performance beyond the increased sound. In general, the best performing intakes I've tested do a good job at blocking heat with a heat shield between the engine/exhaust manifold and intake, and then run the largest filter possible (without the restrictions of the stock airbox). The stock filter size itself is OK.
    There is a little more to most of the intakes available than a pipe and filter. Most come with a breather hose adapter, some form of the aforementioned heat shield, and an intake pipe with a 3.5" opening on the filter side and 3" opening on the TB side to allow for use of the largest possible filter while maintaining smooth airflow. The shape of the intake pipe makes it hard to use a generic pipe for this purpose, and still safely clear the coolant and fuel lines.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Jun 26 2012
    Rockford, il
    Well here's a couple of details if people are interested. The intake tube is 3". All it is is a intake tube for a completely different vehicle (dodge Durango I can give more info if people want to replicated) but it actually works really well. The filter is just a generic filter that came w/ it with a 3" opening. I left the stock air box in place till I figure out how to block of the whole section off all together so I can remove the stock box. so basically I removed the top cover and ran the pipe to the stock box with the filter mounted to the pipe (like the injen style intake). The cover itself is made out of aluminum sheet metal. I traced the stock air box cover onto the sheet metal and cut it out. I sanded the edges and made them nice and smooth and removed all the burrs so that I don't inadvertently introduce any metal into my engine. I'm and airplane mechanic so I have access to air tools and a plethora of metal. Once I cut it out and drilled the holes in the top I wrapped it with vinyl wrap. I also utilized the stock air box cover screws and screw holes to fasten the cover down. I'd be more than willing to run some logs I have a vag com but I'm not too familiar on how to run logs so if someone wants to school me on it I'd be more than willing. I'll take some more pics tomorrow.
    Jun 26 2012
    Rockford, il
    Almost forgot I drove it the other night and let it sit for awhile. I touched the intake tube and it was very hot to the touch (heat soaking under the closed hood) which I'm sure they all do, so I decided to take it for a spin to see if the temp would increase or dropped, well to my surprise I popped the hood and touched the tube and it was as cold as the ambient air outside.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Here is my thread on logging. Let me know if you have any questions. Obviously, it would be best to get a before and after, but it sounds like you could switch back pretty easily.
    http://www.audizine.com/forum/showth...rmance-Logging
    Jun 26 2012
    Rockford, il
    Tx I'll update soon I hope.
    Jun 26 2012
    Rockford, il
    hey i got some logs but they're quite lengthy i doubt i could copy and paste them here so let me know what way you'd like me to upload them. I used your guide to logging and i noticed something strange, on my #5 cylinder once the temp starts rising and i start getting on the throttle the timing pull maxed out at one point at -7.125 my car is stock and it was a cooler night 61 degrees F with humidity. So im not sure why its pulling so much timing. But anyways let me know how you'd like me to upload the logs.
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    You can post them to a google drive or Dropbox account if you have one. It's not completely uncommon to see 6-7 degrees of timing pull from time to time. It doesn't sound like the conditions, but maybe gas or other factors. I'll take a look at the logs if you can post them. If you want to email them to me, shot me a PM. Also, let me know what type of gas you are running and elevation if you can.
    Dec 19 2014
    Virginia
    I bought an intake tube and k&n cone filter from advance auto parts. It fits perfect I trimmed the end to shorten the pipe about an inch but overall it looks like it's supposed to be that way
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Kudos for taking it on but the hot air intake part is a negative IMO. Will be interested in seeing your logs from a stoplight as the car takes in a huge breath of hot engine heat.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Oct 19 2014
    PA
    Quote Originally Posted by pdqgp View Post
    I suspect it may not make that much difference. IATs heat up quickly at a stoplight even with the stock intake. The stock snorkel has little underhood holes facing up too. Besides, just take a look at how Audi themselves modified the 4.0TFSI airbox for the RS6/7 - look familiar? :-) The same airbox in the S versions of the 4.0TFSI does not have those holes.
    Aug 03 2014
    Queens
    It would make sense if those were there as vents. OP could be on to something.
    Previous
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    Quote Originally Posted by AZT View Post
    Quote Originally Posted by DGVR6 View Post
    It definitely makes a difference in IAT's, but probably doesn't impact performance too much in the long run. I just wouldn't go into it thinking you're gaining any power. I went back and looked at my logs with and without the snorkel (same effect as the holes basically), and you see something around a 5C increase in IAT's when breathing engine air. With that said, you're right, IAT's go up very quickly regardless, and this platform is particularly susceptible to timing pull as IAT's increase. At the end of the day, maybe you're talking 1-2% one way or the other. That may be a worthwhile sacrifice if you are after more sound.
    The RS6/7 shown has the manifolds/turbos in the V bank of the engine, and the engine cover has quite a bit of insulation on it. Those holes are pretty far away from the main heat source in the engine bay on the S6/S7. The manifold (albeit, not as hot) on the 3.0 TFSI is directly next to the air intake.
    If there is a real sacrifice with this particular setup, it is the 3" pipe. The stock filter has a much larger opening (over 3.5"), and all the high performing aftermarket intakes go from 3.5" at the filter to the 3" TB. I'd like to see what both IAT's and air flow/pressure look like stock and with this intake before making any conclusion....
    Mar 06 2015
    Columbus, Ohio
    [QUOTE=AZT;10994649]I suspect it may not make that much difference. IATs heat up quickly at a stoplight even with the stock intake. The stock snorkel has little underhood holes facing up too. Besides, just take a look at how Audi themselves modified the 4.0TFSI airbox for the RS6/7 - look familiar? :-) The same airbox in the S versions of the 4.0TFSI does not have those holes.
    Ironically the aftermarket for the RS7's also fully enclose the intake to insure Cold Air Flows in. Check out AWE's version. Pretty nicely done. We can debate it all you want, if you're fine with your car sucking hot air from under the hood that's fine. The better design is to pull colder ambient air from outside. Not just from a stand still but while rolling too.
    Been there done that debate even way back to the mid 90's on GM's L68 SC 3800's in the Buicks and Pontiacs. Lots of people would cheap out and simply slap a K&N Cone filter on the intake and it was proven many times over the sucking of that hot air didn't help outside making more noise.
    Jul 21 2004
    South Florida
    Quote Originally Posted by jran76 View Post
    Its true and I agree but just to point out that the popular roc euro/ CTS is still basically the same 3" tube that just flares out to a 3.5" filter for the last 1" of the tube. That is really the only difference in actual tube design. It may make all the difference. I'm not sure. I agree it'd be interesting to just try a 3.5" tube and filter too. It would actually be at least as big as most of the current options. Wouldnt be any harder to source i'd imagine. Anyways thanks for sharing OP. Be cool to see your ongoing results and see if you continue to develop this.
    Mike
    2018 Audi S5
    Gone-
    Oct 19 2014
    PA
    Could go with a 3.5" pipe and then use a 3.5" to 3" silicon reducer at the TB.
    Not sure how much it really matters to have the airway between filter and TB to be any larger than TB. Perhaps the transition is most important (that it is a gradual/venturi transition to the TB diameter and not abrupt). And ironically, APR's intake tube in the middle necks down to even a little smaller than the throttle body opening (and they gained horsepower)
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    ECS seems to have the best transition from 3.5" to 3". CTS, Roc-Euro, USP, and APR all do the same thing in one way or another. Maybe not the best, but hard to say....
    Either way, I think it's safe to say that just about any intake is pretty marginal in either direction. If you're not trying to set records, it probably isn't going to matter a whole lot. I've now logged just about every intake except the full AWE system and Eurocode, and most log slightly better than stock (keep in mind, logging only tells part of the picture). APR was a small improvement (about the same as an upgraded filter/tube on the stock airbox). Roc-Euro, CTS, and ECS were all slightly better, but really close to each other.
    Jun 26 2012
    Rockford, il
    Thanks guys for keeping this thread going I'm real curious myself now to see what the difference is between this one and the stock intake. I already started making another one tho one that's got a blocker plate like the CTS turbo intake, I've just been busy lately and haven't had time to do any playing around yet, but as soon as I do I will post it. I might just keep this one for the winter and use my CTS replica for the summer we will have to see. Plus I don't really think it matters whether the filter opening is 3" or 3.5" in the end it goes in the same size hole which is 3" I'm sure that .5" is very negligible. I'll update soon I hope.
