Results 1 to 25 of 25
    Aug 12 2015
    2012 Ducati Monster 1100 Evo (red)
    Tampa, FL
    Any imput on BC Racing coilovers ?
    Thinking of pulling the trigger on the BC Racing coilovers: http://www.modbargains.com/bc-racing...i-b8-a4-s5.htm
    Thinking of putting these on my 2015 AllRoad. They are compression AND rebound adjustable for $1,000. Just wanted to know if anyone is running them, or if there is a cheaper option since these are just to hold me over until I go Air Ride.
    Senior Member Two Rings eirebob's Avatar
    Apr 13 2010
    santa rosa ca
    I've had them on my 09 since February. The build quality appears to be very good. The springs are linear, so even at the softer shock settings, the ride will be firmer than that of my stock sport suspension. I'm currently set at 8 in front and 10 in the rear, so I could venture into fairly harsh territory at stiffer settings.
    I got mine from Modded Euros. With their 5% Audizine discount, my cost shipped was just under $950. Unfortunately, they don't carry the BC's anymore, or at least it's not shown on their website.
    You may want to consider Megan Racing coilovers offered by ESC. They seem very similar in function to the BCs, and at $899 are a little cheaper.
    2009 A4 Quattro, Manual, Prem Plus, Sport Package
    Mods: APR Stage II, Stratmosphere short shifter, Alu Kreuz, Tips, Tint, 034 Turbo hose, Cocomats. EC Intercooler pipe, hose kit. RS 5 pedals. Apikol rear diff kit. Vag.com mods. Stoptech slotted rotors, Akebono pads. Interior LEDs, BFI heavyweight knob, CF trim. BC BR coils. P3 Guage. ECS SS brake lines, 10/15 spacers. CR 15 brace. USP HFC.
    Veteran Member Three Rings RiCHV382's Avatar
    Dec 22 2007
    Palm Beach, FL
    I ran them for a few thousand miles before I switched to airride. They were decent riding coil overs for the money but they didn't ride anywhere near as nice as the KWs I had in my B7. Id say for the money you cant go wrong though. If your looking to go super low these aren't the coils to do so on. I ended up getting shorter springs in the front and taking out 2 perch rings to get the ride height I wanted. Picture for reference.
    New: 2018 A4 Prestige / Black optics / moonlight blue /
    toatled: 2014 A4 Prestige / Black optics / monsoon gray / ecodes / Accuair elevel / Airlift / 20x10 Fifteen52 Alexi wheels
    sold: 2008 A4 s-line quartz gray / KW V2 / Bentley Continentals
    sold: 1992 audi 100CS quattro avant
    Aug 12 2015
    Tampa, FL
    What spring rates?
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    02-BC coils have been around for a while and are a good mid-level coilover system. As bob indicated, the springs are a linear rated so you'll definitely feel the harshness of the ride. PM me if you need some feedback on the 15" allroad setup. I Just installed a set last weekend.
    Aug 12 2015
    Tampa, FL
    What spring rates did YOU go with? It sounds like I need to come down a little bit on the rates from what you guys have. I'm not running this car on a track, so I still want to maintain a factory-like ride
    Aug 12 2015
    Tampa, FL
    Will I need the SPC adjustable control arm kit?
    http://www.modbargains.com/awe-tunin...audi-a5-s5.htm
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    We are a BC dealer and they have been getting great feedback on them lately. Lmk if you want a set for a little less than $1000 shipped.
    Aug 10 2015
    Orange County
    Quote Originally Posted by Mwhit02 View Post
    I did not go with BC, I went with a different manufacture that offers a progressive spring rate. It suits my needs much better.
    No, you do not need adjustable control arms. I actually had my alignment done today and the rears are within factory spec. The fronts have a tad more negative camber than factory but the cost of adjustable upper control arms would be cost prohibitive to get back .2 degrees of camber. Toe is the most important factor and my setup is within factory secs.
    Aug 15 2014
    For this reason, I wouldn't get BC coilovers. Linear coils arent as forgiving for a daily driver You can read more here
    http://blog.modbargains.com/linear-r...best-4-street/
    With that said, they perform better on the track where there's less road inconsistencies. If you're looking for a factory ride and eventually plan on going with air, I'd just go with ST or Solowerks. I installed ST coilovers with the eventual goal of going air.
    This depends on if you can live with having your front end alignment a little off. Our upper arms aren't adjustable, so while they may be within factory spec, your passenger side may be -1.3 and your driver side at -1.9. If thats acceptable to you then they're not needed. I'm too meticulous, so I installed a set. My alignment is perfect and I can definitely tell the difference.
    For Sale: Mini Part Out
    Aug 12 2015
    Tampa, FL
    I like the ST coilovers, but it say it lowers the front 1.8" and the rear 1.4"...I have a 4x4 Allroad....I don't think that's going to allow me to go as low as I want.
    Aug 12 2015
    Tampa, FL
    It looks like the Solowerks go 2.5" front AND rear.
    Veteran Member Three Rings bakerrrr's Avatar
    Apr 01 2014
    2016 Silverado
    If you want something that goes low and its going to be temporary get solowerks. They go pretty low, I'm happy with mine. I'm going to switch them though pretty soon to some custom coilovers.
    I can still go lower on the coilovers.
    Bagged Moonlight Blue S4 / CTS Turbo Intake / Air Lift 3P / HRE 540R / Custom Exhaust /
    Aug 15 2014
    they go decently low... i wouldn't necessarily go by those posted specs. There's a user on here running them and he's pretty low with an allroad. I'm not sure if he's on 20s or 19s tho.
    Aug 10 2015
    Orange County
    If you can wait 3 more weeks, I'll give you a "no-holds bard" review on the Solo Werks coilover setup. I'm pretty sure the ST coils will go plenty low for you. On my allroad, I still have at least an 1 1/2" left to go down.
    Aug 12 2015
    Tampa, FL
    Quote Originally Posted by zcspec View Post
    You have pics with your current setup?
    Aug 10 2015
    Orange County
    Scroll up Mwhit02. Mine's the white allroad. That's the current height with plenty of room to go up for down. To give you an idea, here are the specs I sent over to Solo Werks for their database:
    FL: 26 1/4” GTF
    FR: 26 1/8” GTF
    RL: 26 5/8” GTF
    RR: 26 5/8” GTF
    Jun 23 2013
    PacNW
    Your final height is determined only by the weight of your car and the stiffness of the springs, published drop numbers are based on testing a single vehicle, likely the non-sport A4.
    Because you are starting at a higher point your drop will be greater.
    Compare your stock GTF to zcspec's numbers and you get a ballpark for your expected drop as these coilovers are all in the same ballpark on ride height.
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    So the ST or Solo Werks give you a much smoother ride?
    Oct 04 2012
    Everywhere
    Most people complain that the STs go too low, but yes they still ride great.
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    Quote Originally Posted by chris@fifteen52 View Post
    People complain about that? But.... they're adjustable, lol.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
    Oct 04 2012
    Everywhere
    Some people complain that the highest setting is too low, ST offers different height spacers to help alleviate. It is just funny that most every other platform people complain that the STs don't go low enough.
    Apr 26 2014
    San Diego, CA
    Ah, gotcha.
    Sep 27 2015
    BRONX NYC
    Hey, wassup? I have this issue now. What perches do I take out to get a lil lower. The front is where I ran out of space to lower it. I just need a little more lower. Do you have pics or any info helps.
    Sep 27 2015
    BRONX NYC
    Why can’t I go lower in my b8 s5? This is the 1st time I’m having an issue with going low with bc’s. I’m kind of upset being stuck at that height. I need MOAR LOW lol
