Hi folks,
My 04 A4 1.8t Avant has been running a bit lean for a while, long term fuel trim varies around 7-10%, plugs and O2 sensors are white, pinging when hot... I replaced the Mass air sensor, the O2 sensor and the Kombi valve, none of which helped.
Now I've pulled the vacuum line at the N75 valve and pressure/vacuum tested the line to the waste gate actuator and found it leaks so it seems the diaphragm in the waste gate actuator has failed. I will check the vacuum line closer although the materiel looks pretty good so I don't think the hose has cracked, I'm pretty sure its the diaphragm.
I have searched far and wide for waste gate actuators and only see $200 aftermarket options from ECS or $30 Chinese options from Roth or ebay, don't these things ever fail? What do people typically do when the do fail? I found a good DIY which pretty much says you have to pull the turbo to replace the WGA; one person said the did it without pulling the turbo but it was a lot of work getting at the bolts.
The car seems to run fine with exception of pinging, particularly when hot (80+), it still has ~12psi boost and boost seems to be smooth.
Does anyone have any good links for a OE quality replacement or does anyone have a used actuator they'd sell? Or, any general suggestions on this subject? How do I adjust the replacement when I get there? Do I just run it up until it closes the Penny valve and then give it just a tiny bit more tension for pre-load?
