Page 9 of 9 FirstFirst ... 789
Results 321 to 352 of 352
  1. #321
    Senior Member Two Rings Natejo91's Avatar
    Apr 05 2017
    Porsche Cayman S, Toyota 4Runner, Suzuki SV650
    Quote Originally Posted by PSI NRG View Post
    I have a custom air box and intake. Attachment 122518
    Looks like your snorkel is more tapered where it goes into the front carrier so you might not have to trim the hard line for the SJP.
    But you won't know until you mock it up on install!
    You will definitely need those standoffs though unless you want to fab up your own lines for the PRV and SJP.
    I learned the hard way...I forgot that this manifold thread was in the B5 forum and the intake/vacuum geometry must be different because I didn't see this issue mentioned anywhere.
    2003 B6 Quattro MT | Polar White w/ Ebony interior | B7 seat swap | B7 Center Console | JHM + Black Forest Shifter | B8.5 MFSW | RNS-E | Brembo 18Z calipers front | S4 rear calipers | S4 front sway bar | RS4 rear sway bar | Bilstein B8 kit w/ H&R sport springs | Bosch 550cc injectors | Tubular high flow exhaust manifold | K04 | 3" MAF | 034 Motorsport 3" test pipe | B7 Dual Sidemount Intercoolers and Motoza K04/Hybrid tune
  2. #322
    Veteran Member Three Rings PSI NRG's Avatar
    Feb 24 2008
    Interesting. Thanks for the heads up! I know there were a few pics posted of a guy still using the PRV lines but didn't see any mention of a standoff being used.
    BTW what coating is on your manifold? Looks sweet!
  3. #323
    Apr 05 2017
    It wasn’t the PRV hard line that was the issue, I think that one clears the manifold. But the hard line for the SJP is welded to the hardline for the PRV. (See Image blow, there is a couple of welded standoffs connecting the lines)
    The coating is a ceramic coating that I had done at a shop by me. It helps keep the heat in the exhaust stream rather than letting it radiate thru the manifold and into the engine bay. I had my manifold and test pipe ceramic coated to help with heat.
  4. #324
    Feb 24 2008
    Ahh OK I see what you mean. I'll have to take a look at that tonight and see if there's a way I can work around that or add some spacers like you did. Maybe even put some silicone hose where it connects behind the head and run that round the other side by the intake manifold around the front.
  5. #325
    Apr 05 2017
    Rerouting and using a silicone hose around the front would also work. You could just tuck it into those prongs on the timing belt cover where the coolant return line for the turbo gets tucked in.
    I just didn’t have a silicone hose long enough and just wanted something quick and easy so I could get my car back on the road and reap the benefits from all these mods!
  6. #326
    Established Member Two Rings ohg's Avatar
    Oct 16 2018
    Bnd OR
    This thread isn’t exactly dead so I’ll bump it with a somewhat related question, sorry in advance...
    For you B5 guys what did you guys do with the PCV system? I know OP (A1 A2 German) has the scavenger system, but what other catch can set ups are you guys running to clear the manifold?
  7. #327
    Veteran Member Three Rings HUFset's Avatar
    May 08 2014
    B5 A4 GTRS, MK4 Jetta F21T
    CLFX, Denver
    Crankcase T’d to head to catch can to pancake valve on TIP.
    2000 A4 1.8TQM|GTRS Elim|550cc Maestro|034 AEM WMI|ECS RA4|Carbonio CAI|034/Borla TBE|CTS FMIC|2.0T/AWP harness|Toy Guy/JHM duo SS|034 mounts|034 CAs/Links|ST Coilovers|A6 Strut Brace|ECS RDiff Mount|Apikol Rear Diff Bushings|A4 Sport Cloths|Euro S3 FBMFSW|B6 S4 Rearview|Euro Bolster|All S4 Interior/Exterior Bits|Sport Mirrors/Trim|M3 Spoiler|Aero Arm Wipers|OEM Votex Rack and A4 Bra|A8 Fat Fives|S4 Cluster|P3 VIDI Gauge|Pioneer AVH-X4700BS|Alpine PDX-V9|6 Polk DB Mids|Eclipse 12"
  8. #328
    Feb 24 2008
    Got it all installed. Took forever but got it done!
    Pile of parts left over which I no longer need haha
    Didn’t even have to remove the turbo or exhaust at all. Just undid the coolant and oil feed lines.
  9. #329
    May 27 2016
    Westchester, NY
    Quote Originally Posted by Natejo91 View Post
    Attachment 122472
    Attachment 122473
    Attachment 122474
    So the suction jet pump (SJP) line is the smaller hardline underneath the larger hardline for the PRV (pancake valve). You will need some standoffs and longer bolts so this line will clear the exhaust. Additionally, if you run the OEM air snorkel, you will have to trim about half an inch off the SJP hardline with a dremel or something. Otherwise the air snorkel won’t fit into place since the SJP line is higher off the valve cover now. I do not have the SAI system anymore but if you do, I imagine it would also need to be on the standoffs to clear the exhaust manifold. Disregard the exposed vacuum and silicone hoses, those will be shielded or replaced :)
    Very clean. What exhaust manifold are you running? I have the K04 and Motoza 550cc tune as well, with the VR6 MAF. Your numbers look great!!
  10. #330
    Apr 05 2017
    Quote Originally Posted by Ephry73 View Post
    Thanks, much appreciated!
    I have the tubular manifold purchased off the XS power website. I welded a brace on (as advised at the beginning of this thread) and then I also went a step further and had the exhaust manifold and my 3” 034 test pipe ceramic coated.
  11. #331
    May 27 2016
    Westchester, NY
    Thanks for the reply. Have been reading the post. Looks like the manifold is the way to go. Any logs yet?
  12. #332
    Apr 05 2017
    I’ve got a few logs that I’ve been sending to Motoza for some tune revisions. What kind of data are you looking for?
  13. #333
    Veteran Member Three Rings b6a41.8tbagg's Avatar
    Oct 07 2010
    Nashville
    So are you able to run this manifold on the B6 1.8t? Ive read the whole thread just wasnt sure if this was only for the B5. I want to buy the manifold to run on my 71R eliminator its the only thing i dont have to compliment all the other mods.
  14. #334
    Oct 07 2010
    Nashville
    This is the one i want to buy but all the vendors say it wont fit which is strange. And this is my motor a tubular manifold would help out a lot.
  15. #335
    Apr 05 2017
    Quote Originally Posted by b6a41.8tbagg View Post
    I’ve got the XS power version of the manifold right off of their website and I’ve had it installed on my B6 for months now without issue. The manifold you posted looks very similar to mine.
  16. #336
    Veteran Member Three Rings b5v6's Avatar
    May 08 2004
    '05 Volvo S60R, B5 A4 1.8TQM Avant, '06 Toyota Tundra
    San Diego, CA
    Quote Originally Posted by ohg View Post
    Here's my catch can install, one more rubber hose to connect to the TIP. My cat is relocated under the car otherwise I'd be hesitant to use rubber over the downpipe and turbo.
    Sent from my Moto Z (2) using Tapatalk
    99 A4 1.8TQM Avant
    Stroked/Built/Elim71r/NS intake gasket/port matched head and mani/Big PNP/ECS pulley/FMIC/Relocated DV
    Full 3" stainless/relocated cat/Vibrant res & muf
    Neuspeed/Bilsteins/AWE DTS/17" Enkei/Bridgestones
    TT carriers/A8 rotors (front)/B5S4 (rear)/Goodridge hoses/PBR ceramic pads
    Rieger RS4 bumper/Painted rear valance/Valeo one-piece
    Facelift/Pioneer DA120 Apple Carplay/Infinity Reference (front/rear) (Bose deleted)
    awaiting: side skirts/paint job
  17. #337
    Nov 02 2008
    A mess.
    Grapevine,TX.
    Quote Originally Posted by b5v6 View Post
    How is the quality of the cast manifold? Have you noticed a difference in boost onset or turbo lag?
    2019 VW Tiguan 4mo SE. Orange, stock for now.
    Former: 91 SHO, 83 5000S Turbo, 78 Supra, 86 Golf, 69 Chevelle SS, 2 Taurus wagons. 72 Olds Toronado
    2001 B5 Passat 4Mo Wagon, 6sp/1.8T swap. Sold.
  18. #338
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    Any long term updates to report on the XS Turbo manifolds?
  19. #339
    Veteran Member Four Rings Stock B6's Avatar
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Literally just wondering this the other day as well. I believe Nate has had his on for over half a year now without issue.
    Personally, I'm trying to decide between a 3mm tubular Ebay version and the TC18L cast version. Both are nearly $300, making the tubular a lot less appealing to me tbh.
    Racecar: Nogaro B5 S4
    Daily: C5 Allroad 2.7TQM
    Past: 71R E85 B6
  20. #340
    Established Member Two Rings avantkrazy's Avatar
    Jul 17 2018
    Catskill's New York
    Quote Originally Posted by Stock B6 View Post
    TC has none, talked to him on Monday. Guess his supplier overseas is not working during the Covid-19. He has no clue when he will be getting them again.....
    I got 99 problems and my B5 is 98 of them...
  21. #341
    May 25 2018
    Noggy B5 S4
    Twin Cities
    Quote Originally Posted by avantkrazy View Post
    Yeah messaged them too and got the same response. The one good thing they told me is that it comes with a 12 month warranty and should handle high boost with ease. Still, just for the price I think I'll have to go with the XSPower. Especially since they're currently available.
    Past: 71R E85 B6
  22. #342
    May 08 2004
    San Diego, CA
    Quote Originally Posted by BARRY View Post
    Mine is holding up and it's just as good as any other option out there. I'm only working with an elim2871r so can't really attest to whether it would flow better than competitors. It feels good but real data for comparison and/or bigger turbo might be necessary.
    Instagram: @oliepyle
    99 A4 1.8TQM Avant
  23. #343
    Nov 02 2007
    SF Bay Area, CA
    thanks guys!
  24. #344
    Active Member One Ring Beastlyb6's Avatar
    Apr 04 2019
    Connecticut
    XS Power Tubular Manifold For KKK / OEM Flange Turbos.
    I just received my XS manifold and XLB. First time hearing about getting a brace welded...I will have to look into getting that done. Also will be installing a catch can and FMIC setup. What is the solution to a 02 sensor relocation...I run a CTS test pipe and the bung is welded directly upright. Possibly to run it in secondary 02 bung?
  25. #345
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    A CTS's bungs should clear, if not you can look into getting thread in 02 90's to point your 02's in a different angle.
    At worst weld in 02 bungs are $5 shipped Ebay.
  26. #346
    Apr 04 2019
    Connecticut
    Quote Originally Posted by A1 A2 German View Post
    I bought a eBay one originally and learned the hard way fitting my Thermal R&D exhaust. This is the CTS but I still don’t see how it could possibly fit. And prefer to not run a spacer off as I feel that affects readings. Also hard for me to find the ideal spot for a new bung with out the manifold bolted on. But I’m just trying to avoid down time installing this setup IMG_8617.JPG
  27. #347
    Feb 28 2005
    Tempe
    Yeah that's an issue had the same problem, so maybe the E-Bay models are copied from CTS versions. Not all test pipes have the bungs in the same location so got another, and yeah only use a rear 02 spacer.
    My bung ( like yours) seemed like it was tilted slightly towards the head, so I couldn't use it. Mount the new bung straight up and down, 5" back from the test pipe flange. 5" will be more enough clearance to thread, rethread, tighten.
    Or, look at post #266 page 7..only slight issue it may angle over and hit an aftermarket heatsheild.
  28. #348
    Apr 04 2019
    Connecticut
    Okay well that will have to be my plan then. I’ll try to get it all fitted an if it clears great if not once I have everything mounted where it’s suppose to be I’ll make and drill a hole for the new 02 location an have it taken to get welded in. By any chance do you know the 02 bung thread type? I’ll order some up tonight as I planned to add another bung for a AFR gauge down the line anyways. And I will be running your setup with the Oil feed line but keep all other lines Oem. Does the .035” restrictor screw directly into the oil feed then an fitting attached to that? Was a little confused these. AN lines arnt my specialty
  29. #349
    Oct 07 2010
    Nashville
    Quote Originally Posted by Beastlyb6 View Post
    Where did you order the manifold from? Everywhere i check says out of stock.
  30. #350
    Apr 04 2019
    Connecticut
    I got mine through a seller on eBay. But this was about a month ago. Still sourcing parts before it all goes together. I’ve seen them on amazon also id check there.
  31. #351
    Oct 07 2010
    Nashville
    Ill check thanks. I have been looking for one of these for a while it would be a nice upgrade the stock manifold is kind of a choke point on my 71R eliminator
  32. #352
    Apr 04 2019
    Connecticut
    No problem! Yeah they look pretty good in person. I’d love to go actual BT but not comfortable pulling the motor in my gravel driveway an letting it sit while I did rods. One day maybe...XLB will do for now.
