Results 1 to 11 of 11
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Engine Cradle : Which one works?
    This makes me sick, $36 and Free Shipping, how?
    http://www.jegs.com/i/JEGS+Performan...YAkaAlUC8P8HAQ
    I'm looking for one of these that work with our motors and work with the motor mount installed (block subframe brackets with motor mounts installed).
    I need it to work off these brackets (motor mounts) as this clears room for all accessories, as I don't want to suspend a bare block in the air, there needs to be room on both sides of the block.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Wow, good deal there!
    Don't you have a welder? A couple bars across there with some extra mounts to bolt to your mount and you are good.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Actually, upon a closer look, it would be pretty cool to make a mount. The motor mounts look like they would almost drop into the angled plates, and you could put a bar across the other plates for the snub mount. I dont think much fabrication would be need to adapt it to a 1.8
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    "Get one today for yourself...and your baby."
    Nov 03 2011
    All Over!
    That's a good buy.
    I purchased a similar one 2 weeks ago. I had my BFM motor on a regular engine stand, good enough for certain jobs, but leaving no room to install flywheel, clutch and transmission.
    It took some adapting, but it works a treat.
    1986 Type 85 Audi 90 quattro
    Oct 30 2009
    Miami, FL
    Quote Originally Posted by redline380 View Post
    Might be better to modify those 2 vertical brackets so that you can bolt them to the back of the block where it attaches to the bellhousing. If I needed an engine stand I wouldn't think twice about buying one of these and modifying it, the stand is only marginally more expensive than what I would pay if I were to buy the steel stock and casters myself.
    2018 S5 Coupe - stock for now
    Nov 03 2011
    All Over!
    Looking at this motor cradle, I would not advice you go with it. It's fixed height, width and length, kind of limits configuration and flexibility.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Mad Cow View Post
    But a little bit of time and you could make a nicer one....
    I wouldnt worry about height. Says it is 18" tall. Add in the height of the mounts, and the top of the head would be right around your chest.
    2000 S4- Working?
    Nov 03 2011
    All Over!
    When I say height adjustable, I'm not really referring to working height. Mine is height adjustable at the angled-bracket ends, meaning you could tilt the motor front to rear, which would be beneficial depending on what you were working on.
    Also the motor may sit too high at the mount end, and you may wish to lower it.
    Sometimes a level motor may not be ideal.
    Feb 28 2005
    Tempe
    Well, I was just throwing out that Jeg's cradle as a reference and not specifically looking at that one but show casing how cheap they are and how it sucks how everything under the sun exsists for everyone else. I have a stick welder, yet no experience and not sure I want to suspend a built motor off a "I know nothing about welding." built engine stand. I understand I need to learn but probably need a mig & was hopefully looking to find something out there someone has found. What I need is 80 hr days to exsist, my time is 1000% invested into building and building I'm trying to buy something opposed to building something as I don't have enough time in a day. If I wasn't at work typing this I'd be in the garage, not typing this :).
    I was thinking that a prebuilt stand would be bought, then the "arms ( cradle mount mounts)" would be cut off and rewelded to fit the ~oem longituide position.
    I did see a cradle where the base was built, and the "arms" were bolted to the lower cradle. The lower arms were 3 way boxed and fit over the lower dolly base section and then bolted to predrilled holes. So technically they would fit 100% everywhere and would just be a matter of redrilling holes to secure the cradle arms to the cradle dolly base. Maybe a solution. The question is if you could swing the "cradle motor mount mounts" out far enough to mate to the engine motor mounts.
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    All you need to know is at what point you blow through the metal. Back it off from that a tad and you have full penetration ;) I only oxy acetylene and mig, but if you have multiple points where it rests I wouldn't worry about your welding abilities with the stick. They don't weigh very much.
    You could make and bolt plates to the existing flanges if you've got a torch.
