Tnx for the good feedback
You can go to my Facebook plage
https://www.facebook.com/pages/TE-MO...75841709140746 to see more pictures as my new web is under construction.
The engine is going in the dyno in a couple of weeks so will post the numbers then,but we will dyno it to about 2bars boost to see what it gives approx 1150-1300 HP and the boost to be used is about 1bar.
The engine internals and modifications Are done with my engine builder VS Motor.
All parts that we have designed an got manufactured Are 1class brands an Are available for purschase.
The flywheel kit we have made will be a Direct bolt on kit on OEM engines also..
We got the pes kit working quite well with self modifications and found out that the numbers the tuners with SC kits Are just doing a wrong estimate with the cars running on wheel dynos.
As the weightreduction on the car i threw out all OEM equipment,replaced doors and trunk with GFK this is also available for purschase,each parts is 4kg
The original frontbox and radiators also needed to go.
New for this year also is the GFK/carbon roof with airintake as all the cooling happens in the rear now besides engine oil,Powersteering and intercooler.
Dont hesitate asking questions
Regards Trond
