Originally Posted by
HyperM3
This is probably one of the dumbest things Ive ever heard. If its pre-paid for, why wouldnt you bring it in when its supposed to go in? Its not just an oil change, its a full safety check as well as diagnostics. If you dont bring your car in and there is a TSB or something that needs to be changed on your car, you can LOSE your warranty because you didnt bring it in at the pre-determined times you were supposed to. Go pull out your manuals and look at the book specific to warranty and maintenance. Then turn to page 21/22. This will explain everything that is done during those required service intervals....its not just an oil change.
Its absolutely mind boggling how people decide to treat their 80k+ cars.
I know you must understand TD1... For me to pull up to the Audi dealer garage, tt's a 2 hr roundtrip in my case to the APR dealer, re-flashing back to stock and then flashing back again at APR dealer. If a 25k service is basically an oil change, I would rather do it myself then go through the hassle - not to mention the last time the dealer changed the oil, they didn't replace all the screws on the plastic underbody, sloppy work not to mention they use the cheapest approved oil available. All scheduled services do not have to be done by an Audi dealer.
I have reviewed all the schedule maintenance in the owner's manual and know what's covered. Sure, I understand the value of the 35k service, safety inspection and TSB benefits - thanks for sharing.
I started this thread seeking some feedback on a fastener so I could do my own oil changes at 5k intervals instead of the 10k done by the dealer. I'll do my 20k oil change, which you won't find in the service manual. I'll probably have Audi do the basic 25k service (as you recommend) but it's going to require I get re-flashed before going in there because they will hook the car up to the computer - already had that discussion with the Audi tech. Seeing that you are an Audi Brand Specialist - you probably have more flexibility with your Audi service techs in not getting flagged TD1 / hooked up to a the computer for basic services?
