Results 1 to 40 of 51
    Active Member Two Rings DCDJ's Avatar
    Jul 15 2014
    Audi RS5, Audi R8 V10+
    United Kingdom
    Louder Capristo Exhaust System for RS5
    Hi guys,
    I recently had a brand new capristo system fitted to my RS5 and I'm in LOVE with it! So much more than I was expecting. Absolutely amazing exhaust, stunning sound, deep burble at low revs and it screams like mad at high revs - a perfect exhaust in my opinion.
    However... I do want to get it a bit louder (you all probably think I'm crazy) and after reading though thread after thread on this forum, it looks like my best bet is aftermarket non-res downpipes.
    There was some discussion in this thread (http://www.audizine.com/forum/showth...pristo-catback) about fitting AWE Non-res downpipes in place of the existing resonated section, however from reading some of the replies it looks like this will introduce some drone. I'm really not too fussed about drone if its slight as I usually end up listening to the engine anyway rather than music (I think the AWE track extreme introduces similar drone as per the non-res downpipes) obviously I don't want to run into anything that's going to drive me absolutely insane within the first few minutes of having to deal with it.
    So before I go ahead and spend $899 on downpipes... can anyone recommend any other alternatives to making this exhaust louder? Or perhaps your opinion on this AWE non-res dp + Capristo cat back combination?
    I'm looking for that sort of "feel it in your chest" kind of sound...
    Dan
    EDIT: Video of result:
    2014 Audi RS5: Capristo Exhaust • Satin Blue Wrap (Originally Suzuka Grey) • H&R Sport Springs • Reflective Blue Calipers • Dynamic Ride Control • Matte Black Alloys • 20% Tint All Round • Bucket Seats
    www.dcdj.co.uk
    Jul 25 2011
    If you don't want to go for downpipes you can delete the center box (resonator) and straightpipe it. Another member has done the same with his awe track exhaust and it's now on a different level. Another member has the awe non res dp paired with his akra exhaust and he says no drone just so you know. It sounds amazing also.
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    I removed the center section on my AWE kit and it is really loud outside but not bad inside. Maybe consider removing the center section.
    I believe this guy removed the center section of his capristo....
    https://www.youtube.com/watch?v=8XkBbclEHL4
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Senior Member Three Rings AirmattRS5's Avatar
    Jun 05 2014
    Irvine
    remove center res ^^^ and straight-pipe it. Even with the sports exhaust, it sounds like a bomb went off when i downshift.
    The name is Paul, not Matt // @rs_cinqo
    '14 Sepang Blue RS5 / Res-delete Sports Exhaust / Black Optics / Nav / Adaptive Cruise Control / KW H.A.S. / Forgestar F14 20x9.5 +22 offset / Huper Optik 30%
    Apr 26 2005
    Houston
    mental! best sounding exhaust for this car no doubt. Now I need to find a used capristo system
    • eCode headlights
    • Eventuri intake
    Jul 25 2011
    Quote Originally Posted by chrissurfr View Post
    dibs on first one that pops up :D
    Jul 15 2014
    United Kingdom
    Thanks for all the replies guys, really appreciate it. Looks like removing the centre section + straight pipe is the way forward.
    Funny you mention that video as that is what I'm trying to get a closer sound to!
    Sounds gorgeous. Do you notice much drone and how much louder is it than standard Capristo? (I've learn that videos don't do exhausts much justice!)
    I've contacted my local garage to see if they can remove the centre section and fit a straight pipe. If its a go then I'll post back here with clips.
    www.dcdj.co.uk
    Jul 25 2011
    Check this out, I wonder what exhaust this is!
    Jul 15 2014
    United Kingdom
    Quote Originally Posted by Beast View Post
    I believe that's an X-Pipe HMS! Amazing sound but so pricey if I remember D:
    www.dcdj.co.uk
    Jan 23 2011
    Planet Earth
    Mehh. The Capristo is borderline raspy and this makes it really raspy but to each his/her own. The other issue is that the RS5 is waaaaaaaaaaaaaaaaaaaaaaaaaaaaay too slow of a car to try to sound that loud. If it were a 600hp car, yes but when it can't keep up with a chipped s3 then it needs to play down the sound and focus on what it is good at and that is looking good and sounding great. Loud isn't it. Again, just an opinion.
    Apr 26 2005
    Houston
    HMS is too loud....and my car is loud
    • eCode headlights
    • Eventuri intake
    Jul 15 2014
    United Kingdom
    Yeah... police over here in the UK are REALLY cracking down on loud supercars, especially in London (where I spend a lot of my driving time) and those that break the dB law limit, so I don't want to go for anything obviously over the top that's going to get me intro trouble! Thank goodness for valve controlled systems..
    www.dcdj.co.uk
    Jul 15 2014
    United Kingdom
    So I'm currently at the garage.. The tech guys are telling me that they don't know if removing the Capristo center resonator is the best of ideas as they're telling me it's what "makes the Capristo what it is" and that if I removed it, the exhaust would sound raspy and droney and generally terrible. instead they recommend removing the two mufflers/resonators before the cats further on up front and just straight piping that.
    They're not promising that this is going to make it much louder but I've told them to go ahead and see what the outcome is..
    What do you guys reckon? I'll post back with results once they're done.
    www.dcdj.co.uk
    Veteran Member Four Rings Hippyshakes's Avatar
    Mar 19 2014
    2022 BMW 4 Series Cabrio (Wife); 2020 Mercedes GLE
    Atlanta GA USA
    Just a question how long have you had the Capristo? It does change a bit after 500-1000 miles ) although I admit it sounds like you want more than some change)
    I could hear a difference.
    Good luck.
    Build Thread []RS5
    Stock: 2014 RS5 Cab. | Panther Black | Driver Assist | MMI Pkg. | Alu Optic
    Mods: Signature SV302's | Capristo Exhaust | eCodes | Eventuri Intake-Manifold-Slam Panel | APR Stage I | 034 Trans. Mount
    Jul 15 2014
    United Kingdom
    Fairly new, about 500 miles I'd say.. I was told it would get louder but bought I'd try a delete anyway as I do like a loud system
    www.dcdj.co.uk
    Veteran Member Four Rings ttusqrl's Avatar
    Dec 06 2014
    Dallas, TX
    Remind me, which is louder -- akra or capristo
    Sold (sadly)
    "Luna" 2014 []RS5 Tiefseeblau Pearl Effect w/ Drivers Assist, MMI Nav + Pkg, Sport Exhaust | Suntek Full | Bel STi-R Plus | Parking Sensors
    Mojo31 - "And, everyone needs a badass car. It's a necessity if you want to keep your man card. Mods can make a badass car badder, but cannot make a bad car badass."
    Jul 15 2014
    United Kingdom
    So I've just had the two resonators/mufflers (whatever they are?) removed (the ones further on past the capristo resonator)
    Result: AMAZING. Very happy with it. Exhaust is super loud now with valves open, just as I wanted it. No drone! Valves closed, sounds like stock, still quiet. Absolutely incredible result.
    I believe most drone is caused by the center resonator delete (which I imagine would give a similar result), removing the mufflers on the downpipes seemed to give equally what I wanted, and I don't have to worry about voiding warranty on the Capristo.
    A little raspy (expected) since we have no mufflers now, but still got that great V8 sound.
    Here is a picture of what I had done.
    I'll try and record a vid with a decent mic at some point...
    Quick vid: https://instagram.com/p/6xudAJNz7w/?taken-by=thedcdj
    @ttusqrl I believe Capristo? Never heard an Akra on an RS5 IRL so don't quote me on that, but from what I've read Capristo is louder, Akra is deeper/more like a more refined sports exhaust.
    www.dcdj.co.uk
    Jul 15 2014
    United Kingdom
    Thought I'd report back here now that I've filmed a decent quality video...
    www.dcdj.co.uk
    Jul 25 2011
    sounds amazing! So you have capristo + non res downpipes. so you basically added AWE non res dp lol
    Veteran Member Three Rings Racedoc11's Avatar
    Sep 26 2012
    2013 Rs5 , 2008 M3 Vert
    PA USA
    good thread a lot of info.
    Apr 26 2005
    Houston
    sounds crazy - would love to hear that cold start on a cold day
    • eCode headlights
    • Eventuri intake
    Veteran Member Four Rings adbender's Avatar
    Jun 13 2009
    2021 911 Turbo and 2023 Q5 Technik
    Quote Originally Posted by DCDJ View Post
    Sounds fantastic...
    2024 S5 Sportback Technik
    2023 Q5 2.0 Technik
    2018 Q5 2.0 Premium Plus (Totalled)
    2015 RS5|Stage 2 (Sadly Sold)
    2013 Q5 2.0T|Premium Plus (Sold)
    2010 S4|6MT|APR Stage 2+Everything (Loved but Sold)
    2005 A4 UltraSport (My First)
    Veteran Member Four Rings B8 S FOR's Avatar
    Feb 15 2011
    Pittsburgh, PA
    damn... awesome
    AUDI 4 LIFE.........B9 S5 Cab Prestige/ Mythos Blk Met
    Gone but not forgotten:
    2015 B8.5 S5 Cab
    2011 B8 S4
    Jun 13 2009
    https://www.dropbox.com/s/qefr09anq2...ghway.MP4?dl=0
    For comparison this is the AWE track extreme. Windows and back seats down with the mic in the trunk.
    2023 Q5 2.0 Technik
    Apr 26 2005
    Houston
    Capristo is super deep sounding. It has no x-pipe, right?
    Here is what my AWE track with the center muffler removed sounds like. I still have the downpipe section you removed on there car. AWE has an X-pipe which I think makes it higher pitched.
    https://www.facebook.com/cmw1983/vid...73398999991533
    • eCode headlights
    • Eventuri intake
    Jul 15 2014
    United Kingdom
    Correct - this setup basically did just end up with non-res downpipes, resonator + the full capristo system.
    www.dcdj.co.uk
    Senior Member Three Rings TomPaul10's Avatar
    Aug 04 2014
    albany, new york
    what do you guys think of Armytrix.. surprised no one said that one
    Current: 16 mythos black S6 prestige
    past:
    13 S5 stage II+ awe track/ H&R
    2016 SQ5
    2016 Sepang S3 premium
    2010 Ibis White S4 P+ / A.W.E Track /
    2010 Stage II A5 / G.I.A.C. / A.W.E. / H&R /
    Veteran Member Four Rings jkownz's Avatar
    Jun 15 2011
    2015 RS 5
    Quote Originally Posted by TomPaul10 View Post
    Google them. Got a bad wrap
    MODS 2015 Audi RS5 / Custom Made Headlights / Full Xpel PPF / Tinted / Blackvue DR650G / Eventuri Intake / BLK 501GTR'S 20X10.5's All around / Storage Bins / Euro Folding Mirrors / Capristo Exhaust / A.W.E Non-Res Downpipe / CF Engine Cover / 034 Transmission Mount Insert / Apikol Rear Differential Mount Insert / 034 Rear Diff Carrier Mounts / Euro Tail Lights + Sweep Module / L.E.D Interior Lighting / Airlfit 3H Bag Suspension /
    Veteran Member Three Rings patmusk's Avatar
    Mar 27 2014
    2013 Audi RS5, 2013 Subaru BRZ, 1971 Volvo P1800
    Central NJ - USA
    This sounds great!
    I've been debating various alterations to my capristo also. But it sounds so amazing as-is and when it "broke in" I was over-the-moon.
    I'd LOVE to hear the DCDJ modified capristo in all the different conditions (valves open, closed, accelerating, shifting).
    2013 Audi RS5
    Daytona Grey | Black | MMI | B&O | Capristo Exhaust w/ Non-Res DPs | Eventuri Intake | H&R Coil Overs | Alu Kreuz | EC Sways | E-Codes | V1 | Llumar 35%
    Summer: 20x10 BBS CI-R | Winter: 19x9 Forged OEM | BBS Spacers 10mm~5mm
    Build Thread :: Instagram
    Jul 15 2014
    United Kingdom
    Cheers patmusk - Funny you say that as I'm planning to shoot a video of some valve controlled conditions, acceleration, shifting and some tunnel runs with the capristo. Just waiting for the weather over here in the UK to improve a little. Will report back here when I have it all edited and uploaded :) Meanwhile here are a few instagram videos of various sounds from the capristo
    https://instagram.com/p/7Pys5Jtzyf/
    https://instagram.com/p/7GBk1cNz2m/
    https://instagram.com/p/675y1uNz-K/
    www.dcdj.co.uk
    Mar 27 2014
    Central NJ - USA
    Excellent! Looking forward to any videos. I'm getting some high quality stuff done soon as well... waiting for the leaves to be all over the road so I can get some cool footage :)
    2013 Audi RS5
    Jul 15 2014
    United Kingdom
    Had a load of car spotters in London that wanted to hear the exhaust so did I few flybys/revs:
    www.dcdj.co.uk
    Jul 25 2011
    wow that sounds godly
    On a side note, are you running spacers?
    Jul 15 2014
    United Kingdom
    Nah no spacers although thinking about it
    www.dcdj.co.uk
    Nov 19 2012
    Irvine, CA
    Do you happen to know what color your car is wrapped with? or the company name?
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Jul 25 2011
    Quote Originally Posted by zhclvn View Post
    Yiannimize!
    Nov 19 2012
    Irvine, CA
    Yiannimize!
    Brand of the film is called Yiannimize? LOL
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
    Mar 27 2014
    Central NJ - USA
    Dan,
    I'm confused (sorry to keep bothering you ). According to the thread here, you removed the resonators as shown above and left the center capristo section in place. But according to this video, you took out the centre section.
    I'm assuming you did BOTH (center capristo res delete/x-pipe + downpipe res delete/straight-pipe). Can you please confirm? Also - do you have any pics of the final system while the car was lifted?
    Thanks for sharing. Car sounds ridiculous.
    - Pat
    2013 Audi RS5
    Jul 15 2014
    United Kingdom
    @patmusk - Right, so I actually filmed that video after a SECOND modification to the exhaust system which I haven't gone into detail on here.
    I bought full Capristo, it wasn't loud enough. For the first modification, I had the secondary resonators removed and straight piped (not the single big Capristo resonator, at this point that still exists) and it got louder. Then I wanted to be a bastard and make it even LOUDER. Obvious decision was to remove the Capristo resonator as well, however I didn't want to lose the Capristo quality/sound so I had Capristo refer me to a custom Staineless Steel X-PIPE to replace the Capristo resonator (little pricey), which is now what my exhaust system looks like. Originally I straight piped the main resonator but it sounded seriously raw. You can probably just do that if its volume you're looking for.
    So the final product is original Capristo mufflers, then an X Pipe, then straight pipe on the secondary resonators. Car sounds beautiful. I'll try and get a pic if I can, getting some H&R springs fitted soon so car should be up on the rack again at some point.
    Dan
    www.dcdj.co.uk
