I've had a front left "clunk" at low speed that's gotten progressively worse over the past 1.5 years. It's nearly unnoticeable when the car is cold, but as the car warms up it gets worse and worse. It happens over bumps going straight and even more when turning to the left. My warranty ran out in May and it didn't get really bad until this summer so I'm on my own diagnosing this. I have a two post lift and when I get under the car while it's in the air and warm, I tug on the front suspension...nothing. Sway bar, nothing. Subframe, nothing. I have not tried to move the engine as I didn't think about it until now. I replaced my springs and dampers last Summer and it didn't change the clunk at all. Sway bars and end links are OEM and in great shape. Car only has 40K miles and this started around 25k.
This has led me to the possibility of a bad engine mount on the left side. I can't see it to confirm though. Has anyone else had this symptom with a bad mount? I think the rubber in the mount softens up when it warms up and then the possibly broken mount really starts to move. Before I order some 034 mounts and spend the better part of a weekend putting them in, I want to exhaust all other possibilities.
EDIT: I have no brown staining or fluid leaking from either mount.
Anyone?
